Question about GE DBSR453EBWW Electric Dryer
Electric dryer ground strap?
Does the ground strap go behind the neutral cord or in front of the neutral cord behind the screw
    Sergeant:
    Champion:
  • 262 Answers
Put the ground strap along with the screw on the terminal block if you talking about the metal strap that comes with the dryer. if you are talking about the forth wire on the cord it goes to the body on a green screw (usually Green)
Posted on Dec 29, 2007
Kenmore Dryer Model #11060932990 Proper grounding when changing 4 prong cord to 3 prong.
According to the National Electric Code, you will need to install a grounding strap from the frame to neutral in a 4- to 3-wire conversion.
Jan 18, 2014 | Kenmore Dryers
Can u help me please we're do the brown grey and white with pink line wires go
Four-Wire: Green
The green wire is the ground wire, and it is the difference between a three-wire and a four-wire cord. (In the three-wire system, the ground wire and the neutral wire are the same.) The green wire connects to the dryer frame. Look at the cord-connection terminals on the back of the dryer. Very close by, you should see a screw sticking out of the metal panel. It will be labeled "external ground connector" or something similar. Connect the green wire to that screw.
Four-Wire: Black
Most appliances in your house run on 120 volts of electricity, some on 240 volts. The dryer needs both--240 volts to run the drum and heating element, and 120 volts to run the timer, thermostat and other components. For this reason, the dryer cord has two live or "hot" wires--one black, one red--rather than a single hot wire. The dryer draws 120 volts from each hot wire to get the 240 volts it needs for the heavy work, then pairs one hot wire with the neutral wire for the 120 volts to run the smaller functions. Look again at the connection terminals on the back of the dryer. There should be three screws in a horizontal row. Connect the black hot wire to the terminal on the left.
Four-Wire: Red
Connect the other hot wire, the red wire, to the terminal on the right. (In truth, you could connect either hot wire to either hot terminal, but it's standard procedure to put the black on the left and the red on the right, so do so.)
Four-Wire: White
The white is the neutral wire, and it connects to the center terminal. There may be a metal strap attached to this terminal. That's a ground strap. When a three-wire cord is attached, it serves the same function as the ground screw mentioned above.
Three-Wire: Gray
If you have a three-wire cord, then all three wires will be gray. They're arranged side-by-side with the hot wires on the outside and the neutral wire in the middle. Attach the hot wires to the left and right terminals and the neutral wire to the center terminal. Make sure the ground strap is attached to the center terminal.
Nov 20, 2012 | Dryers
Kenmore 700 dryer with a three prong cord is being converted to four prong. Is there a drawing of what wires by color going to the proper screw location?
There's a ground strap wire (green/yellow) attached to the dryer cabinet and connected to the center terminal where the white neutral wire of the power cord is connected. Disconnect this ground strap wire and remove the 3-prong power cord from the terminal block taking note where the wires are connecedt to. Connect the 4-prong power cord in the same way same wire colors of the 3-prong cord are connected to the terminal block. Connect the ground strap wire to the remaining fourth wire (green/yellow). Just do the reverse when converting 4-prong to 3-prong. The link below might enlighten you further on this matter.
Electric Dryer Prong Conversion
Aug 13, 2011 | Kenmore 700 6972 Dryer
Change a three wire to a four wire.
To change from a three to a four wire cord you will need to remove the ground wire/strap that is currently connected to the center connection at the back of the dryer. This ground wire is going to look like a flat piece of either copper or aluminum that connects to the center peg and is screwed to the dyer cabinet right next to the cord terminal block SAVE THE SCREW. Doing this separates the electrical neutral and the cabinet ground.
Now when connecting the four wire cord, put the red and black wires on the outer connection posts (does not matter which goes on which side) and the white neutral wire connects to the center connector. The green or sometimes green with yellow stripe wire from the cord will connect to the cabinet where the ground strap you removed used to connect use the same screw that you removed earlier.
Oct 07, 2010 | Maytag Neptune MDE5500AY Electric Dryer
I need to convert a 3 prong dryer cord to a 4 prong
Hi. Ok, with the rear terminal block cover open, you will see three wires. Black on one end, white in the middle and red on the other end. Use your 3/8′ nut driver to remove the nuts or a Phillips screwdriver to remove the bolts (depending on your dryer) and remove each dryer cord wire from the terminal block. When you remove the nuts or bolts, be careful not to drop them down into your dryer. Next, you need to disconnect the bonding jumper on your dryer. The bonding jumper is either a metallic strap (typically copper or copper clad) or a green wire that is connected between your dryer’s neutral (white wire) terminal and the green ground screw connected to your dryer’s frame. If you removed a ground wire instead of a bonding strap from the neutral terminal, you need to connect this ground wire to your dryer’s frame. Loosen the screws at the connector and pull the cord out. Now thread your new cord through the connector and tighten down. This only needs to be snug do not over tighten. Sometimes the old connector will work with the new cord and sometimes not. If not, your new cord will include a connector that you may use. Now,to hook up your new 4-wire dryer cord, connect each wire to the dryer’s terminal block matching color for color (white to white, black to black and red to red). Connect the green wire to the green ground screw on your dryer’s frame. Once the wires are connected, simply recover the space, and secure the cove with the screw provided.
Aug 24, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Connecting 4-wire cord to GE profile dryer
The following link explains how to properly install a 4-wire power cord to your appliance:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
The main difference between a 3-wire and 4-wire configuration is how the ground and neutral wires are terminated.
In a 3-wire configuration the wires are terminated together at the terminal block via a ground strap.
In a 4-wire configuration the two wires are independent of one another. Match the corresponding colored wires at the terminal block and attach the ground wire to the ground lug on the equipment cabinet.
I hope this explains it well enough for you. If you still have questions, please let me know.
Oct 02, 2009 | GE Profile Harmony DPGT750EC Electric...
Plug problem
On a three wire configuration, the ground and the negative are tied together at the center position, using the dryer ground strap. Following is a description of the difference between three and four wire. Hope it helps you.
These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one on top is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown on the bottom.
Besides the number of wires in each cord, there are two important things to notice. First, in the four-wire configuration, notice that the dryer's grounding strap is folded back on itself. The whole point of the four-wire cord is to separate the ground from the neutral. The green wire (the "new" extra wire in the four-wire cord) is attached to the dryer cabinet. In the three-wire configuration, the grounding strap is left intact and the neutral and ground are tied together.
Sure hope this helps you find a resolution to your delimma! Best wishes.
Oct 01, 2009 | Whirlpool LER4634J Electric Dryer
Repairing 3 wire drop cord
Sep 09, 2009 | Whirlpool LER5636P Electric Dryer
How to install a 4 wire cord on a 3 wire dryer
This is a common question we receive and a common mistake most every general contractor makes that we work with. With a 3-wire system your neutral terminal will have a copper clad or aluminum strap or green wire connected between it and the frame. You need to remove this when changing to a 4-wire cord.
Terminate the wires from your new 4-wire cord as black to black terminal, white to white terminal, red to red terminal and green to ground screw on frame. This is the other end of that strap or green wire you need to remove from the white (neutral) terminal.
When changing to a 4-wire cord it is very important to remove the strap or wire that connects between the white terminal and the dryer’s frame. If you do not remove this, your neutral or grounded conductor will allow electricity to flow through your dryer’s frame and shock you each time you touch your dryer.
Jul 15, 2009 | GE DCSR483EA Electric Dryer
4 wire to 3 wire dryer cord
usually the grounding strap is still on the machine after the installation of a four prong cord (they just bend it out of the way), if not you can use a wire to connect the neutral to the case or just buy a ground strap when you buy the cord.    (hot wire 110v) neutral wire (hot wire 110v) neutral wire is always in the middle. both on the cord and on the machine
Jun 28, 2008 | Whirlpool GEW9250 Electric Dryer
GE DBSR453EBWW Electric Dryer Logo
722 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
