Maytag MSD2454G Side by Side Refrigerator
Problem for Maytag MSD2454G Side by Side Refrigerator
My coils are red hot through the freezer vent. Is
By professio979 on Oct 12, 2009
My coils are red hot through the freezer vent. Is it okay to leave plugged up until I can repair this?
Best Solution
posted on Oct 12, 2009
Very Helpful)
woodchuck789
Rank: Guru  Maytag Refrigerators  Expert
Rating: 91%, 597 votes
It may cut off by it's self. Your defrost timer is part 13 on this diagram. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?diagramPageId=00002&documentId=M0310055&modelNumber=MSD2454GRQ&productCategoryId=0165000&brandId=3048&modelName=&blt=11 I would turn the timer till the compressor started running again. This should cut the defrost heater off. The timer should stay in defrost mode for only about 20 minutes. The timer may be the problem. Here's an explanation of the defrost. The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Very Helpful)
dave_jewell
Rank: Guru  Refrigerators  Expert
Rating: 91%, 30 votes
The defrost heating element will sometimes get red hot when activated. This is normal. There is nothing else inside a freezer compartment which is supposed to get hot.
Was this helpful?
Yes
No
Popular Solutions for Maytag MSD2454G Side by Side
Questions and Unsolved Problems for Maytag MSD2454G Side by Side
Do you recommend Maytag MSD2454G Side by Side Refrigerator?
Answer
Answer
maytag msd2758dr not cooling correctly have to turn both sides up all the way. even with that not... (More)
Answer
my maytag refrig/freezer side by side started leaking water from the inside and now does not make... (More)
Answer
maytag msd2454gr refrigerator how turn filter light off after replacing filter?
Answer
I have been noticing water leaking from under my fridge. I just now saw in the back of my freezer... (More)
Answer
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Refrigerators Experts
Top Refrigerator Repairmen
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(619) 564-4488
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
