HP Pavilion dv6000t PC Notebook
Problem for HP Pavilion dv6000t PC Notebook
How come my Dell laptop won't turn on? The lights
By chao_sabrina on Oct 12, 2009
How come my Dell laptop won't turn on? The lights are on, but the screen is blank.
Solution #1
posted on Oct 12, 2009
Somewhat Helpful)
parrotheadpc
Rank: Guru  HP Computer Hardware  Expert
Rating: 89%, 624 votes
This is a sample of what you can try to do to diagnose a non-starting computer, If these don’t work, realize that most likely a system board (motherboard) has failed or the actual power trim strip above the keyboard has failed.
  1. Unplug the computer, then take the battery out, push the power button and hold it for about 30 seconds. Plug the system back in (leave battery out) and push the power button. If it starts, Great! If not unplug go to the next step.
  2. You should still have the battery out and the power unplugged. Now turn the laptop over. Take off all the covers and pull out the hard drive and ram and wireless card. Find the screw that has a symbol kind of like a circle with a wedge cut out, it’s the CD rom drive screw. Now pull the drive out. Pick one stick of ram and put it back in the computer. Flip it over open it plug it in and hit the power button. If it does not fire up then unplug it and switch the ram. Plug it back in and hit the power button again. If it doesn't start up, unplug the computer and go to the last step.
  3. Pull the memory out and find the screws that hold the keyboard on. There are symbols in the plastic there should be 2 screws holding it in. Now in the battery compartment, there are several screw at the back edge of the computer take them out and also the ones in the battery in the center strip. Some are silver and some are black. Once you have the screws out of the battery area flip the computer over and open the lid. The strip just below the LCD with the power button and controls will now be able to be lifted up. You will probably have to lightly get an edge started before it will come up. There should be several little cables hooked to it. Flip the control panel over and look for some screws holding the keyboard in. I think there's 2. Lift up the keyboard. Making sure there's nothing touching anything important and then plug the computer in. Carefully hit the power button and see if the computer tries to start. If it does try it will probably beep at you. Unplug it and put a stick of ram in it. Plug it in and try to start it again. If not, unplug the computer and Go to the next step.
  4. Carefully put the keyboard and control strip in place. Flip the computer over and loosen all the screws that hold the computer together. Flip the computer over again and pull the keyboard and control strip up again. Flex the inner aluminum plate that was under the keyboard lightly. Plug in the computer and then hit the power button. If it tries to start, Great! put it together again in the reverse process.
If it does not, there are 2 possible things I would suspect the Control strip or the mainboard. If you don't get the computer to start back up please put it back together so you remember where all the screws go. Even if you plan to get another mainboard put it back together.
Was this helpful?
Yes
No
Solution #2
Not Rated)
lucgalman
Rank: Guru
Rating: 92%, 26 votes
hi there! since you were able to see the LED lights, it indicates that the power of your laptop is okay.
you may isolate the functionality of your built in display by connecting is to an external monitor or by connecting your pc to a docking station. if it is working fine while on docking station or when using external display then there must be something wrong on the built display. you may also need to check if there is any physical damage on your display. if you are familiar enough i suggest that you open the display and reset the flex cable connecting the display to *********** board.
Was this helpful?
Yes
No
Popular Solutions for HP Pavilion dv6000t PC
Questions and Unsolved Problems for HP Pavilion dv6000t PC
Do you recommend HP Pavilion dv6000t PC Notebook?
Answer
Answer
cam driver is not supported in divice manager not shoe imaging divice
Answer
laptop keeps shutting down after a couple of hours of using it, I have only had it a couple of... (More)
Answer
I just noticed that my DVDRW isn't working and device manager says that the dvr k17b driver is... (More)
Answer
Anyone know where I can download a manual for this computer? The one that came with the machine has... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptop Experts
Top Computer & Laptop Repairmen
in , CA
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
