Question about Onkyo TX-SR502 Receiver
No apparent sound from subwoofer preout
Here is what I have done to troubleshoot.
I made sure that "A" speakers were selected (sub does not work on B). I made sure that the subwoofer setting in the speaker config was set to yes. I checked the decibel level setting. I connected the subwoofer to an older receiver I have and it worked. I connected an older subwoofer in working order to the current receiver and still no sound. I reset the receiver settings to factory defaults and started over again. I made sure that "A" speakers were selected (sub does not work on B).
If this is in fact a problem with the pre-out, are there any "simple" solutions. This product is no longer covered by factory warrenty and I was given a $150 estimate from a local repair shop. For that price I would just put it toward a new one and open this one up and tinker around if you have any suggestions. Much appreciated!
  • Official Brand Answer
  • 333 Answers
Hello, if the settings are correct and the subwoofer has been tested and working.the receiver would need to be serviced. Thank you, Onkyo USA
Posted on Mar 21, 2017
3 Suggested Answers
djnick989
  • 1067 Answers
SOURCE: The subwoofer preout is not working
does sub woffer have speaker wire in and outs run the fronst throw ther back up to front speakers pass throw it that would work
Posted on Jan 07, 2008
SOURCE: very low ouput from subwoofer preout
Onkyo to Onkyo, sub/receiver, problem fixed by inceasing volume on receiver. Seems the sub audio input does not pick up LF's below a certain output level from the receiver. So, guess I have to live with that. I only hope my nieghbor in the apartment below me can too!
Posted on Apr 29, 2008
Yamaha RX-V1800 and Kenwood SW-505D Subwoofer No sound
I think you need to re-read the manual before attempting correct wiring.
Nov 27, 2017 | Audio Players & Recorders
Where should I plug in my sub woffer
There should be two jacks on the back that say SUBWOOFER in the "preout" section of the back panel that is directly above the speaker jacks. Either of these jacks should work for your sub hook-up. Also make sure that you set your front speakers to small in the speaker setup menu, otherwise there will be output to the subwoofer jacks.
Dec 27, 2012 | Pioneer Elite VSX-52
No sound from Sub Pre-out on Onkyo TX-SR606
Also, it could possibly the preout terminal itself that is not working. One way to prove that is by transferring the subwoofer cable from the preout and temporarily transfer it to the tape out section. If it ouputs sound from there, then that means the speaker and the cables are working fine and it's just the preout terminal itself that is not picking up anything. ^_^
Dec 16, 2008 | Onkyo TX-SR606 Receiver
Pioneer DEH-P3000IB... Hook up RCA cables to 2, 2 channel amps for front and rear control. Supposed to be able to set rear to either rear full or sub... can't find how and all I'm getting is sub response.
Here are the directions according to the manual:
1 Use MULTI-CONTROL to select
SW CONTROL.
2 Press MULTI-CONTROL to display the
setting mode.
# Press BACK to return to the previous display.
3 Press MULTI-CONTROL to select the segment
you wish to set.
Press MULTI-CONTROL repeatedly to switch
the segment in the following order:
REAR SP (rear speaker setting)—PREOUT
(RCA output setting)
4 Use MULTI-CONTROL to select the desired
setting.
Turn to change the setting.
When REAR SP (rear speaker setting) is selected.
REAR SP:SUB W(subwoofer)—REAR SP:FULL
(full-range speaker)
When PREOUT (RCA output setting) is selected.
PREOUT:SUB W (subwoofer)—PREOUT:REAR
# When no subwoofer is connected to the rear
output, select REAR SP:FULL.
Hope this helps.
Oct 13, 2008 | Pioneer Audio Players & Recorders
Very low ouput from subwoofer preout
The problem was that some subwoofers (inluding my velodyne model) cannot process the LFE signals through the line level inputs on its amps, so the other way to run your subwoofer is to run the front left and right speaker outputs from your receiver to the speaker-level inputs on your sub, and then plug your front and left speakers into the soeaker level outputs on the sub. you have to set the onkyo receiver to "Subwoofer: No". that way the LFE signals are sent through the front speaker channels and you will get the same BASS output as if using the line-level input. O So yes it does require a bit more speaker cable, but it works fine now.
Mar 18, 2008 | Onkyo TX-SR304 Receiver
Rampage BA-100 200W amplified subwoofer
Actually. I don't think you have to wire a remote switch from the radio to the amp on this product. This powered subwoofer supposedly has automatic signal sensing turn-on circuitry. I have the same problem. So I think I'll try to just hook up the power (to the battery), ground and the + / - speaker wires to one of the back speakers in the car and see if that works.
Jan 22, 2008 | Audiovox BA100 Car Subwoofer
Jan 06, 2008 | Yamaha RX-V2700 Receiver
Onkyo 805 sub hook up problem
Talked to tech support at Onkyo and there seems to be two (2) places you can hook your sub up to. I placed mine in the wrong slot. So please double check where you placed the sub connection.
Jan 05, 2008 | Audio Players & Recorders
Subwoofer preout and bass
did you tell the receiver that you have a subwoofer connected (thru the quick setup)?
Apr 02, 2007 | Pioneer VSX-D514 Receiver
Onkyo TX-SR502 Receiver Logo
90 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
