Question about Toshiba Satellite A105 Notebook
No power i was working with my A105 - bttery was fuly charged and it was plugged in when it sudenly turned itself off. Now, I cannot power up - all of the blue lights are off. Any suggestions?
  • 689 Answers
Take the Battery Out, unplug the power while its unplugged and battery released press and hold the power button about 7 seconds and put back the battery and the power cord turn it on. If still issue persists check the power connection and the actual outlet if it has connectivity problem. and last solution will be replacing the AC Adaptor (After ensure that DC input jack is not damaged)
Good Luck
Posted on Dec 28, 2007
Turn signal ,horn,stopligth,gas gange,sudenly doest work and sudenly comes back and work
You have a dodgy connection in the wiring, probably at the fuse box or may be the fuse itself is loose or dirty. When all is working, grab the wires near the fuse box in different places and tug them firmly, if the problem happens on one tug, look closer at those wires. Then when it is all working spray the bike with water from a hose, concentrate on small areas at a time until you find an area the cuts the lights.
Dec 20, 2013 | 2002 Harley Davidson VRSCA V-Rod
My toshiba satellite a105 laptop won't power up but the charge light is on.
Good day!try removing the battery and plug again..see if it works..
mastergani
Mar 21, 2010 | Toshiba Satellite A105 Notebook
For laptop: Toshiba Satellite A105: My battery won't charge/computer won't turn on when plugged in. No lights show when plugged in. Don't know if it's a problem with the chord or the computer. Don't want...
Start by trying another power outlet.
The power adapter should have its own light. If it doesn't light up then the adaper is bad. Kensington.com sells very inexpensive universal power adapters. You might also find a good deal on eBay.
If the adapter lights up then it may be your battery. Notebook batteries are only good for 2-3 years. If you let them sit for a long time without a charge they may only last 1-2 years.
Vote for this solution if it helps.
Aug 18, 2009 | Toshiba Satellite A105 Notebook
Toshiba Satellite A105-S4048 problem with AC Adapter When I turn the laptop on with the AC adapter, after checking the BIOS freezes and does not boot Windows. If I turn the laptop in only with battery boot...
There's not much you can do. The problem is definately with your motherboard. I'd recommend a bios update, but normally you can ONLY run a bios update if the battery and the ac are both plugged in.
This problem is pretty common among Toshiba's A105 and P105 models.
Besides replacing the motherboard there's not much you can do.
Sorry.
Mar 10, 2009 | Toshiba Satellite A105 Notebook
Dell inspiron 9300 lights up for 5 sec.it turns off
If the battery is fuly charged and the power supply is functional, my experience has been that the system board has gone bad.
Dec 30, 2008 | Dell Inspiron 9300 Notebook
Laptop won't turn on
No I think U have problem with ur mother board..
Nov 29, 2008 | Toshiba Satellite A105 Notebook
Problem with laptop- no power
The battery needs to be taken out once in a while. It is possible to use the ac adapter and power cord without the battery to power your laptop. Please press on the power button for 10 seconds for your computer to turn on. Check if you can see any message on the screen.
Sep 04, 2008 | Toshiba Satellite A105 Notebook
Toshiba Satellite A105-S4064; can't get battery to charge
If you put strain on the jack (e.g. hang power adaptor from it whilst using or charging) then the socket on the mainboard can get hot due to poor contact and melt.
There is no way to fix this except to completely dismantle the laptop and fit a new socket - most likely a repair centre will charge you for a new mainboard.
Try another adaptor to see if that is the problem (broken wire in cord) - otherwise look closely at the socket in the notebook.
Aug 08, 2008 | Toshiba Satellite A105 Notebook
The most common problem on these units is the ac connector solder joints break away from the motherboard. If you're sure the ac adapter is working, and the correct one, and it's not charging the battery (assuming the battery is good), it's most likely the problem. They don't have to appear loose to be loose.
Otherwise, it's motherboard time, or a loose screw, etc has caused a dead short on the board.
Good luck, if you have additional info, let me know.
Feb 09, 2008 | Toshiba Satellite A105 Notebook
Toshiba Satellite A105 Notebook Logo
46 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
