Question about Sharp AR-5316 Advanced Digital Imager Copier
Need some help
Hi, I got a sharp ar 200s and it is giving mi an error code h2
I'd changed the fuser and the power supply already but still
gives the error, can You help with it please. thanks.
  • cathacho Feb 15, 2008
    thank you! for every thing the printer was fixed,
To get rid of this error pls enter simulation mode by doing the following steps:-
press # , interrupt , C, interrupt consequently . when the display is off, enter NO. 14 and press start button
Posted on Dec 28, 2007
Sharp AR- m205 error code h2
Hi
Should probably read H2-00, which is your thermistor in the fuser. Open door on right, three screws hold the fuser in (hot bit), release fuser slightly, being careful as it is still connected, the thermistor is sat in the top, you should be able to reset it by pressing the little button and you should here it click. re-fit fuser and secure.
To reset the code, press these buttons:
Hash, interrupt, clear, interrupt., enter 14, then the print button.
Cheers
Andy
Feb 17, 2014 | Sharp AR-M205 Copier
SHARP AR-M237 H2-00 ERROR CODE---HAVE INSTALLED NEW FUSER UNIT WITH SAME ERROR/CODE PROBLEM.
check harness and connector betwen thermistor and control PWB.
clear the error code by using SIM 14 if all didn't work you may have defective AC power supply
I hope this help
Feb 10, 2011 | Sharp AR-M237 Digital Copier
Sharp 5320 H2 error code
this is a fuser error message. You must fix the problem causing the fuser to post an error. Then clear the message.
Jun 19, 2009 | Sharp AR-5320 Black and White Copier
Sharp AR-168D H2-00 error code
Check
http://www.copier-help.com/copier-help/ecs/sharp/ecsar161.html
Thanks.
Jun 11, 2009 | Sharp AR-168D Black and White Copier
I just buy it and whene i plug it ,it gives code ou-80,h2-00
Your error code indicates that the Fuser is not at the correct temperature, which can lead to smeary smudgy copies or scorched paper and a fire hazard, depending upon whether the fuser is too cold or too hot.
Replace the Fuser Unit.
Apr 26, 2009 | Sharp AR-C150 Copier
Sharp AR-5127 H2-00 code reset
Sharp Fuser
H2-0 Fusing unit temperature error
H4-0 The fusing unit doesn't heat up.
***ALWAYS DISCONNECT POWER WHEN WORKING ON MACHINE***
You have to reset fuser errors with simulation 14. Push P * C * then 14 then Start (the button you use to make copies) and it should reset the code. If not then replace the fuser.
SM 5-1 should turn the lamp on. If lamp blinks on and off it is the thermistor, if it does not it is the lamp, but check the contacts on the lamp/fuser -- they have been known to erode.
Also check thermal fuse, if defective replace.
Feb 01, 2009 | Office Equipment & Supplies
Sharp AR-275 Getting H2-00 Erron on power on
In AR 275 Sharp copier H2 00 is very common problem, U have to only reset the above fuser error code as fallows
press # then intrrupt then c them intrrupt then display will show simulation mode then enter 14 then press ok key
If this is not enough then press press thermostat on fuser unit by removing the unit from machine this requires tech knowledge
OR you can try by replacing thermistor of fusing unit
If by above procedure the prob is not solved then and then you replace the fusing lamp
Even though u can check the lamp by removing back cover and turn on the machine u can observe the light of fusing lamp
pl ask for any difficulty.
Sep 18, 2008 | Sharp AR-5320 Black and White Copier
H2-00 Error Code, cant clear
Sounds like a tough one, take off the back cover and make sure all connectors are making good contact. You may have a fault in the main logic board.
This might need a tech to check out.
Hope that helps...
Apr 25, 2008 | Sharp AR-M277 All-In-One Printer
H2 Error
You have a thermistor open. That means that the device that reads the temperature in the fusing unit, has broken. You will need to replace the fusing unit to fix this problem. You could try a Sim 14 reset. Push P * C * then 14 then Start (the button you use to make copies) and it should reset the code. If not then replace the fuser.
Dec 31, 2007 | Sharp AR-5320 Black and White Copier
Sharp AR-5316 Advanced Digital Imager Copier Logo
159 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
