Question about RCA Lyra RD2763 MP3 Player
RCA Lyra H125
Hey, I have a Lyra H125 and I fixed once by formatting it. But, nowe it is saying the files system is corrupt again or after resetting it, the hard disk temperature is too low. How can I get it back to format it again?
Hay 1 solución segura hay que desarmarlo y con tooooodo el cuidado del mundo sacal el disco duro o microdrive, hay unas computadoras que tienene la ranura para el micro drive (md) lo conectas ahy y lo formateas, el problema que yo tuve es que tuve que conseguir la carpeta lyra_sys que se encuentra oculta en el mp3.
Asi que si alguien tiene la carpeta, podria facilitarmela.
Gracias
Posted on Aug 09, 2008
Not working
Posted on Nov 15, 2008
Creo que estps RCA son algo medio problematicos y salen defectuosos :S
Posted on Feb 01, 2008
It says 'File system corrupted' I don't know what to do.
back up your files, format the storage of the player, put the back up files back to the player
Apr 09, 2010 | RCA H125 MP3 Player
Mp3 wont work
If the file system is corrupted, you have put files into the wrong folders.
To fix it, simply copy over all of your files from the mp3 player to your computer, format the mp3 player, then synch the files back onto it.
Oct 14, 2009 | RCA Lyra RD2763 MP3 Player
Everytime i try to turn it on it says file system corrupted. It Does not go any farther then that.
Manual for Lyra RD2762 in pdf format:
http://www.voxxsupport.com/images/manuals/RD2762/media/RD2762_UMEN.pdf
Troubleshooting from page 53:
In case of a corrupted file system: player must be formatted.
FIRST BACKUP YOUR PLAYERS' DATA BEFORE FORMATING !
How to reformat the player is explained on this site:
http://voxrightnow.custhelp.com/app/answers/detail/a_id/1529/kw/lyra%20format/p/158/r_id/103795
Home page on all support for RD2762:
http://support.rcaaudiovideo.com/manual.aspx?product=202
Sep 19, 2009 | RCA Lyra RD2762 MP3 Player
Rca mp3 player h125
plug it into your computer and re-format it
Jan 24, 2008 | RCA Lyra RD2765 MP3 Player
Rca H125PA mp3 player
I had the same problem and went through RCA support to get a solution which (to my surprise) actually worked. Here's what you need to do. Connect your USB cable to your computer but do not connect to your mp3. Hold down the toggle switch on the mp3 while turning it on. Then insert the other end of the USB cable to the mp3. This should allow your computer to recognize the mp3.
Now go to website: support.rcaaudiovideo.com (no www. prefix). Go to "software updates". Click on "mp3 players" a couple of times and then your model "H125". Then click on "H115 and H125 Lyra Hard Drive Upgrade Utility" and follow the directions from there.
Jerry
Nov 13, 2007 | Audio Players & Recorders
RCA H125 MP3 player
Renee,
Jerry
Nov 12, 2007 | RCA Audio Players & Recorders
RCA H125 File System Corrupted
I've had this problem twice now and fixed it once. I'm in the process of fixing it again. Here's what you do, and this is a slow process so have some patience with it. Hook it to your computer then power it off. When you power it back on, with the cord still connecting it to the computer, hold down both the front buttons and the power button. You should now see it saying connecting. It will take a LONG time for your computer to recognize the device and give you access to it in My computer. Once it does, you can then remove the file system and replace it.
Jun 07, 2007 | RCA (T120PAK12) VHS Tape (12-Pack)
File system corruption
I actually fixed this!!! Mine had been giving me the "file system corrupted" error. So, I opened it up (unscrew the screw on the back, pry the back cover off with a small flat head screwdriver or a key, etc.) and saw that the connector between the CF drive and the motherboard had come apart.
I re-inserted the cable into the groove of the connector on the motherboard, pushed the broken/separated piece of plastic that serves as a retainer for the cable back down, held it in place, and taped it down with a 1/4 inch wide strip of duct tape (taped all the way around the connector/cable to help keep it in). I put the Lyra back together and then turned it on... and it WORKED! It came right on into the normal menu! Yay!
Good luck other people, I hope that this is the same thing that happened to your player and that you can also fix it! =)
Dec 05, 2006 | RCA Lyra RD2763 MP3 Player
RCA Lyra RD2763 MP3 Player Logo
239 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
