Gateway laptop not working
Hi
My original 65 w ac adapter for my Gateway MA2 6021GZ notebook caught on fire for no reason a year ago. I went back to Best Buy and they sold me a Targus 90w adapter. A few weeks ago my notebook stopped working. the blue light on the Targus adapter still comes on though. Is my notebook damaged or is it the Targus adapter. I call Gateway support but they really don't know what they're doing. Can you help? I'm desperate. Thanks.
John
2jhum@rogers.com
    Novelist:
  • 188 Answers
What is the problem with the notebook?
Do you get any lights on the notebook when its plugged in?
Have you tried another power adapter?
Posted on Dec 31, 2007
Gateway wont power up the batt has been failing ,if pluged in the charging light comes on for a while then goes out if you try to start it tries then shuts down. could a bad batt cause this
If your battery is more than 2 years old, then it is a distinct possibility. Every battery type has a certain number of charge cycles (drain->recharge->drain) or time period. Lithium batteries run about 2 to 3 (tops) years. NiMH run about 10,000 charge cycles (or it could be 50,000 cycles if you know what to do). But if you're NOT using the original Gateway charger, then plug it into your laptop and see if it works. The 3rd party charger may have burned out the internal power components over time. In the worst case, you'll have to replace either the motherboard (hope you still have the product key!) or the motherboard's power connector, inside the laptop. At best, you might have to continue using the original power adapter. It will probably turn out to be a worn down battery, which needs replacing.
Feb 19, 2011 | Amstron Gateway P170X Laptop AC Power...
Gateway laptop mx6437 turns on but won't boot
It migt be resolved by a power drain. Disconnect the AC adapter, takeout the battery, and press the power button for 30 secs. Put everything back again and try to turn it on.
If your Noterbook is still not turning on, then you might need a phillips screwdriver, or if its in warranty you might want to take it to Gateway technicians, as opening the notebook by urself might void the warranty.
** Before trying the steps below, disconnect the AC adapter and take out the battery.
Turn your notebook upside down, and look for bays, look for screws which has a rectangular comb like structure next to it, unscrew it and you will find RAM chips in there take it out and put it back in. Do this for all the chips you have in the notebook.
Put everything back again and your Notebook might be up and running, else there might be some hardware issues and you need to go to gateway or some local tech.
Regards,
Shrey
Jul 14, 2010 | Gateway MX6437 Notebook
I need a power adapter
If you want real cheap, then an universal AC adapter is your best option. Targus has one that you can purchase for 24.99 USD, which you can find here.
That adapter works for a wide variety of manufacturer's including Gateway. Also, this particular adapter can provide up to 70 watts of power. So any adapter that fits into that range will be fine on power consumption.
Your AC adapter takes approximately 65 watts of power and should be okay.
I hope this help.
-Ernest
Apr 22, 2010 | Gateway MX6436 Notebook
Gateway MX6428 Power Problem
faulty wiring in the wall (hopefully not) or the AC adapter try another adapter or outlet
Aug 12, 2009 | Gateway MX6428 Notebook
I have a Gateway 4525GZ power problem
your ac adoptor is not correct it is low amh
please check for original adoptor
Jul 30, 2009 | Gateway 4525GZ Notebook
My Gateway 7510GX shuts down after ten minutes. I
i think there are two causes for this reason.1/ ur processer fan is not working properly. at that time u should get this message as thearmal heat. then ur computer shutdown. 2/ setting of power option my be fixed 10 minnutes. we should kee poweroption always never shutdown.
Jun 11, 2009 | Gateway 7510GX Notebook
I have Gateway MX6027 laptop. My ac adapter get real hot. i went through 2 chargers in the last 2 months. I am wondering if I got a short on the motherboard, or maybe if there is a voltage regulator that...
Does the AC adapter get hot if you use it to power the notebook with the main battery removed? If not, the battery or internal charging board may be faulty/
Mar 03, 2009 | Gateway MX6027 PC Notebook
Charging Led issues
So, in other words, The system works fine with the AC adapter and battery installed. Have you tried a different battery? Ray CompuGuy44
Jun 20, 2007 | Gateway MX7118 Notebook
Computers & Internet Logo
241 people viewed this question
Alun Cox
David Payne
David Payne
