Question about GPX HM3817DT Shelf System
Right speaker jack
The right and left speakers work fine for CD and radio, but when the input (side jack) is used for MP3, only the left speaker produces sound. ...Already tried swapping speakers, sound comes from left only... (and problem occurs only when using mp3 (portable device) jack).
  • Anonymous Dec 20, 2008
    only works with headphones
The patch cable may be shot i had the same problem all i had to so was get a new patch cable (Best buy has them for 2.00) hope this helps
Posted on Jan 02, 2009
    Problem Solver:
  • 5 Answers
Are you using the same cord for the mp3 player as you are for the cd and radio? There could be a patch cord problem or it could be the output jack of the mp3 player. If using headphones with the mp3 player works both right and left then it must be the patch cord. Try using a different patch cord.
Posted on Dec 26, 2007
1998 buick regal stereo what are the wire color codes
showgif.do?image=73222
Connector Part Information
12110115
32-Way F Micro-Pack 100 Series (Blue)
Pin
Wire Color
Circuit No.
Function
E1
DK GRN
835
Entertainment and Comfort (E&C) Serial Data Communication
E2-E5
Not Used
E6
DK BLU
1796
Steering Wheel Controls Input
E7-E8
Not Used
E9
LT BLU
1405
Remote CD Changer Common Input
E10
ORN/ BLK
1406
Remote CD Changer Left Channel Input
E11
LT GRN
1407
Remote CD Changer Right Channel Input
E12
BRN
199
Speaker Feed-Left Rear
E13
YEL
116
Speaker Return-Left Rear
E14
DK GRN
117
Speaker Return-Right Front
E15
LT GRN
200
Speaker Feed-Right Front
E16
BLK/ WHT
351
Ground
F1
ORN
640
Fused Battery Feed
F2
YEL
43
Fused (Retained w/KP2) Accessory Power Feed
F3
DK GRN
145
Radio Switched Power
F4
GRY
8
Interior Lamp Dim Switch
F5
YEL
32
Fused Interior Lamp Dim Signal
F6-F10
Not Used
F11
BARE
2011
Remote CD Changer Drain
F12
TAN
201
Speaker Feed-Left Front
F13
GRY
118
Speaker Return-Left Front
F14
LT BLU
115
Speaker Return-Right Rear
F15
DK BLU
46
Speaker Feed-Right Rear
F16
Not Used
Dec 20, 2014 | 1998 Buick Regal
Problems with int 5.1-Channel Home Theater Speaker System
yes u will need to chandge input jack from mono to stero radio shack $4 part u need y headphone splitter this should fix ur problem
Aug 07, 2009 | JBL 5.1-Channel Home Theater Speaker...
The right speaker stopped working..i tried unplugging it and plugging it back in and nothing!
1. Check that the speaker input cable or input jack is not damaged. Do this but plugging in some other speakers or headphones into the computer and plugging the speakers into a MP3 player or cd player.
Do that to verify a hardware problem
Jul 09, 2009 | Cyber Acoustics A-3780 Computer Speakers
No output from right side speaker jack
audio board located inside the mainboard console to the right trace your speakers wire to bd, disconnect the three leads, 3 phillips screws, and examine bd for burns. If yes, ebay the board id for a replacement.
Apr 24, 2009 | Dell W4201C 42 in. Plasma HDTV
Brookstone Wireless Outdoor Speaker with Bose 123 System Problem
AUX usually refers to an INPUT, such as a CD player, etc. No signal comes out of a standard AUX jack, unless it specifically says "Aux speaker output". Instead, look for another speaker output jack, such as remote speaker, B speakers, etc. You may only have one set of speaker output jacks, in which case you would need to connect your wireless speaker to the speaker output jacks along with your main speakers, or buy a little speaker selector switch box to switch between main and wireless speakers. There's usually no harm in connecting more than one speaker set to the same outputs, though it is technically not recommended. In the real world, just don't crank it too loud and you'll be fine. The wireless speaker MIGHT run off of a standard line output also, if the wireless speaker has its own power amplifier.
Dec 15, 2008 | RCA WSP150 Main / Stereo Speaker
Stereo theft
try this to see if the right wires are there it normally cost about 130 to get a professional to do it
Radio Constant 12V+ Wire: Blue/Yellow
Radio Switched 12V+ Wire: Gray
Radio Ground Wire: Brown
Radio Illumination Wire: Dark Green
Dimmer Wire: White/Green
Antenna Trigger Wire: None
Front Speaker Size: 6 1/2′
Front Speaker Location: Doors
Left Front Speaker Wire (+): Pink
Left Front Speaker Wire (-): Purple
Right Front Speaker Wire (+): Green
Right Front Speaker Wire (-): Blue
Rear Speaker Size: 6′ x 9′
Rear Speaker Location: Rear Deck
Left Rear Speaker Wire (+): Black
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Red
Right Rear Speaker Wire (-): White
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
May 25, 2008 | Sony CDX-F7710 Car Audio Stereo CD MP3...
Right side speakers don't work
if you are using RCAs as inputs to your amp.Swap the R to L @ RCAs to see if its comming in okay from radio.If both RCAs have audio then amp is bad ,If amp has any type of switches , move swithces to see if it comes back .Also if both RCAs inputs have audio .Move the RCAs when connected on amp to see if amp has bad connection in board to RCA jacks..If audio comes back on bad side when jack is moves .Then you have bad solder joints on board..If not then you must have bad outputs on amp..
Dec 22, 2007 | Car Audio & Video
Wiring a pyramid 903G
red - power
Black - Ground
Blue/Black - rear Left Speaker Positive
Blue - Rear Left Speaker Neg
White/ Black - Front Left Speaker Positive
White - Front Left Speaker Neg
Brown/Black - Rear Right Speaker Positive
Brown - Rear Right Speaker Neg
Yellow/Black - Front Right Speaker Positive
Yellow - Front Right Speaker neg
Green - Left Input Positive
Green/White Left input Neg
Gray Right Input Positive
Gray/White - Right input Neg
Nov 16, 2007 | Pyramid 903G 10-Band Car Equalizer
Mp3 player only plays on right side speakers
Have you tried a different jack? It could be faulty.
Aug 11, 2007 | Pioneer DEH-P6800MP CD Player
GPX HM3817DT Shelf System Logo
108 people viewed this question
Top GPX Audio Players & Recorders Experts
Sandy Moore
Sandy Moore
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
