Security Systems and Surveillance
Problem for Security Systems and Surveillance
Generic problem for all Security Systems and Sur...
Our horizon dsx gate system suddenly los...
By jim_blandfor on Oct 12, 2009
our horizon dsx gate system suddenly lost power, no display and key pad is not working. What can I check to possibly fix this?
Solution #1
posted on Oct 12, 2009
Not Rated)
sparktgo
Rank: Guru
Rating: 89%, 22 votes
First of all check circuit breaker supplying the gate to see it has not tripped.
Also check power is coming out of the circuit breaker in case it is faulty.
You now know if supply is being sent to gate transformer.
Check supply is arriving at gate with mains tester. if so check low voltage side with small multimeter.ONLY DO THIS IF YOU ARE COMPETENT WITH ELECTRICS.If all power is reaching the pcb (printed circuit board) then a call out will be needed as the fault may be in the board itself.
here is a link to a brochere that may help.
http://www.sentexsystems.com/pdfdocs/6001037.pdf
Was this helpful?
Yes
No
Popular Solutions for Security Systems and
Questions and Unsolved Problems for Security Systems and
Answer
i need wireless security that i can record to my computer (etc) that i use a/c power as main power.... (More)
Answer
i cant install phone number to intellisense 236
Answer
lost my code for Sentry safe B351822
Answer
The green light on one of the alarms is flashing. Should I just press the reset button? I have a... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Security Systems... Experts
Top Audio & Video Equipment Repairmen
in , IL
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
(785) 842-6626
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
