Question about Sony Playstation 3 (PS3) Console
PS3 - HDMI to SD change issues
I am based in the UK. Over Xmas I took my PS3 to my brother-in-laws house. He has a HD TV and we connected the PS3 to the TV using the HDMI cable. However we have come back to home today. At home we have SD TV. We connected the TV to the PS3 with the standard AV conector. Now it does not come up on the screen at all. What should i do?
  • 1 more comment
  • cacournay Aug 26, 2008
    I went to my sister's house and brought my PS3 to her house and switched the console to HD and when I brought it home I hooked it up with the AV cords to my standard television and there was only sound and no picture.  Then I brought it back to someone who did have HD and tried to switch the settings back to SD but I must have messed up somewhere, because I brought it back home and had the same problem.
  • Anonymous Feb 04, 2009
    my sisters boyfriend brought his PS3 over and we cant play it on the tv because it is a standard tv, NOT an hd tv..so i need an answer on how to change the settings without buying an hdtv
  • jabeelm786 May 11, 2010
    Will this only reset the video output and not reset/delete all of the memory e.g. game saves, music etc?
    I do have a HD TV but i can't seem to change that to the original SD settings (which is what i want to do) without the video output from the HD tv dissapearing...
While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.Good Luck!
Posted on Sep 16, 2008
    Problem Solver:
  • 10 Answers
There is an explanation on how to fix this in your PS3 manual - I cant remember off the top of my head, but it is really easy to sort out.
If you cant find your manual you can access them from the PS3 website.
Happy Gaming!
Posted on Dec 26, 2007
You have to find hd tv and make change settings to sd tv
Posted on Jun 16, 2009
Ps3 hdmi is saying format not supported on my 32"
hi
there maybe some problem with ur tvs resolution. ps3 outputs full hd high resolution video(1080p) through its hdmi. may be your tv is not supporting that resolution. connect ps3's component video out to ur tv and then try. if it ask for any resolution selection. select 720p or 1080i, above that resolution ur tv will not support. ur tv is hd ready one, not full hd. ps3 's hdmi out is full hd (1080p).
or try this
connect ur ps3 to any full hd tv and then goto video setup of ur ps3. change resolution to 1080i (down scaling ). then connect to ur tv via hdmi. surly u will get the video.
ok
Dec 14, 2010 | Emerson LC320EM9 32 in. LCD HDTV
My ps3 was working fine four days ago. I took it to my brother-in-laws two nights ago and hooked it up. We played it on his tv with an xbox hdmi cord and it was fine. I took it home and plugged it up to...
Ok you must be using a a/v cable at your house? And the hdmi cable at your brother in laws? If this is the problem its not the xbox hdmi cable. It doesnt matter all hdmi cables work the same. Its your settings. You need to hold you power button down and it should come on and beep twice then release it and a settings menu should pop up if it doesnt hold the power button down until it comes on and shuts off then hold the power button down again until it beeps twice. Hope this helps.
Nov 29, 2010 | Sony Playstation 3 (PS3) Console
Ps3 starts and the green light is on but no image omes up on my
Try connecting the PS3 to your TV with a scart cable first and go to the appropriate channel. The problem you are facing is probably because the default output is not HD. So you must change it to HD you can do this by going on your PS3 display settings, whilst your operating on standard definition, AV1 or something like that. When the you are on display settings plug the HD cable in the PS3 while still being on AV1 and then plug the cable in, this may prompt a message saying that a HDMI device has been detected and you can change to HD, if this message appears switch to the HDMI output and then select yes and automatic on the PS3 for optimal settings in HD. If the message does not appear then select the HD output yourself after plugging the HDMI cable in and then change to the channel and do the same.
Jul 20, 2009 | Sony Playstation 3 (PS3) Console
Unable to use PS3 on HD channel
1. Connect PS3 to your TV
2. Select the Correct HDMI input on your TV
3. Press and hold the [power] button on the PS3
4. perform setup.
These are the steps to setup the video output for the PS3, It is possible that it is set to a resolution that your TV does not support.
If this doesn't work, you may want to contact Sanyo to ask if they have some protection circuit for the HDMI input. Some manufactures TV's will deactivate(turn OFF) the HDMI input under certain conditions. Unplugging the TV or some other procedure usually turns it back ON.
Apr 29, 2009 | Sanyo PDP-42H2W 42 in. HD-Ready Plasma...
Ps3 doesn't work propley with samsung hd tv
keep ypur finger on the off button for 20sec
Jan 11, 2009 | Sony Playstation 3 (PS3) Console
Played ps3 on my brothers hd tv
do u have hd?
if not u need to change ur settings to video instead of hd! but when i had to i needed it hooked up to hd first then went through settings to change it or it will be blank screen!
Dec 26, 2008 | Sony Playstation 3 (PS3) Console
JVC LT-32DS75SJ issue with HDMI
Try this
1. Turn ON TV
2. Connect PS3 to TV HDMI input
3. select TV HDMI input for PS3
4. turn OFF PS3 if it is ON
5. Press and hold the [I/O]Power button until the PS3 until you get the "HDMI Detected" message.
Also, this TV has a circuit that deactivates the HDMI if the rear cover is removed. It is possible the HDMI may have been turned OFF. This is reset in the service menu of the TV.
Dec 17, 2008 | JVC LT-32X575 32 in. HD-Ready LCD...
Shadowing on screen
You should get a good surge protector. Sometimes some areas have a spike in the power. That will cause interference in the TV signal coming from your PS 3. Try out different surge protectors that should solve your problem.
bimmerhp
Jan 23, 2008 | Sony Playstation 3 (PS3) Console
Elder Scrolls!!
Supposedly games arent region encoded. In fact my brother has an american ps3 and a Resistance: FOM bought in Spain and its working fine. Yesterday I bought a Dream Theater DVD encoded for zones 3, 4 and 6 and it didnt play in my PS3 (Zone 1) so in fact the zone issue can be the problem. Regards
Dec 19, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
1,512 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
