ViewSonic OptiQuest Monitor
Problem for ViewSonic OptiQuest Monitor
How to open case of Optiquest q7
By grema on Oct 12, 2009
Q7
Solution #1
posted on Oct 12, 2009
Not Rated)
micromend
Rank: Guru
Rating: 89%, 296 votes
Almost all LCD monitors use kind of the same enclosure. On the back or on the bottom there may be two screws. If so, remove them. If not, no worries. On the bottom you should find a couple of indentations in the plastic where the front and back join. I like to use a Radio Shack fiberglass flat bladed diddle stick. Put this into the indentation and push up. This should release the bottom. Now the trick. Use this diddle stick (it must be flat bladed) on the front. Using only your fingers gently lift the plastic case on the front away from the screen. You should see the metal case of the screen. Begining at the local right or left put the diddle stick between the metal only part of the screen and the plastic front. Reminder. This stick must be between the metal screen enclosure and the plastic front only. Once in this position, you can slide the stick upwards along the metal case. As you do the plastic case will pop away from the rear case. Provided there are no screws you missed. Now do the same on the other side and then the top. You should now have separated the front case from the rear case. Next take apart the metal shielding (usually screwed together). There may be metal tape placed in strategic places, make sure you gently unloosen this tape and reapply when you're finished. Hope you know what you're doing from here! If not check out my website www.micromendllc@live.com
Was this helpful?
Yes
No
Popular Solutions for ViewSonic OptiQuest Monitor
Questions and Unsolved Problems for ViewSonic OptiQuest Monitor
Do you recommend ViewSonic OptiQuest Monitor?
Answer
Answer
hi, i have a monitor Optiquest Q7B-3 Model #VS11147. my monitor can't stay on more than 20-35... (More)
Answer
Hope I could piggyback on the response
Answer
at the top of the screen the picture bends down like an upside down rainboow, same thing at the... (More)
Answer
To replace Caps in Optronics Q7 requires opening case. removing screws and using credit card around... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Monitors Experts
Top Computer & Laptop Repairmen
in , CA
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
