Question about RCA F36650 36" TV
RCA P52920BL My RCA 52" rear projection tv tries to turn on a couple of times, but doesn't. This started as an intermittent problem. Model # P52920BL, chassis 829351257...At first the set would turn on, but after a minute would shut down then restart. Did this a couple of times then stayed on....Then one day it tried to turn but wouldn't. Help Me...Henry I have an RCA F36650, Entertainment Series, Guide Plus Gold Gemstar tv that I bought new in about 2001. It just started to do a similar thing. It just went black as I was attempting to change from watching a Tivo show to a channel by remote, and it won't turn back on. It attempts to turn on 3 times - whether by remote or by the "on" button. You can hear a quick pop/sizzle noise and the green light goes on for a second, then off, then it tries again 2 more times. I've never had any other problem with this set. Is it dead ... or worth having a repair person out to look at it? Thanks.
  • shedahl Dec 26, 2007
    Note from shedahl:
    This may be obvious (or just the way this site works), but the first 5 lines above weren't part of my post. It should begin RCA F36650. I've read some other answers now (sorry - should have done that first) and wonder if the problem and part number are the same as F32650. I'm a novice, but assume the first 2 numbers are only the size, and the part numbers are the same for various sizes. ???
    Is this a "flyback" transformer failure, and need part #257805? Is there more than one type of transformer in the tv? Thanks again!
  • shedahl Jan 05, 2008
    To: Terryfic
    Thank you for taking the time to reply to my post. I really appreciate it. That will help me to zero in on a repair estimate by phone, so I can figure out if it's even worth paying someone to come out to look at the tv and/or take it into their shop.
    Thanks again!
    Genius:
  • 1,694 Answers
F32 or F36650 = same transformer = 257805 or Asti 2078
P52920BL = need service number = P52920BLXXX then I will
confirm flyback part #..................................T.
Posted on Jan 04, 2008
  • Vista Electronics Jan 04, 2008
    P52920BL probable flyback part # 239111.....
rscimeca,
This could literally be anything. I have a tip at http://www.fixya.com/support/r6396176-projection_tv_troubleshooting which will help you isolate the problem and tells you where to get the parts.
Thanks for using FixYa and for the great rating.
hardrocko
May 23, 2011 | RCA P52920BL 52" Rear Projection...
SET TRIES TO TURN, BUT DOESN'T
The RCA P52920BL uses the PTK195 series chassis. The most common reason for the set not turning on is a shorted flyback transformer. To check this, measure the B+ when the set is plugged in - it should be around 145 volts. When you turn the set on, see if the B+ drops down at all. If the flyback is shorted, the set will try to start but the flyback draws too much current. The microprocessor senses this and immediately shuts the set back off. To confirm, unsolder the jumper wire bringing B+ to the flyback and put a 100 Watt bulb in its place. Turn the set on and if the flyback is shorted, the set will now stay on but the bulb will glow as bright as if it was plugged into the wall. If this is the case, replace the flyback. Let me know what you find and we will take it from there.
Aug 25, 2007 | RCA P52921 52" Rear Projection Television
TV WONT TURN ON
try unplugging and plugging back in but wait 2 minutes in between. this will reset it.
Nov 14, 2009 | RCA P52920BL 52" Rear Projection...
RCA 52" projection P52920BL no volume, if you turn it up can hear speaking chirping
check the back of set to see if there' an internal external speaker switch- also check on screen audio menu to see if speakers are set to off
Oct 18, 2009 | RCA P52920BL 52" Rear Projection...
RCA 52" projection tv convergence problems,can i fix it?i try auto convergence? the model is P52920BL and is a 1998 i try the green centering blue & red convergence in the setup of the tv,and it goes back...
My RCA 52 rear projection TV has the letters getting blurry on top and bottom, Picture is OK but visually losing my eyesight staring at blurry numbers and letters.
Is this a bulb or simple fix ??
Mar 28, 2009 | RCA P52920BL 52" Rear Projection...
Tv will not stay on
there is nothing you can do but get rid of it
Dec 26, 2008 | RCA P52920BL 52" Rear Projection...
No Power to Model # P52920BL
Sounds like the flyback transformer and horz output,the output shorts and the set will just tick when its pluged in to the ac
Dec 30, 2007 | RCA P52920BL 52" Rear Projection...
RCA P52920BL
i'd like to help.that model# looks familiar.but that chassis num you gave looks more like a serial num all my rca prints go buy chassis # is there anothe num like ctc197 exet or ptk19 doc
RCA 52" Big Screen TV model;P52920BL Chassis;PTK195KB PICTURE BOWED AFTER FUSE BLOWN.
You have bad convergence IC's.. If your not experienced in troubleshooting electronics or soldering, you should have a trained tech take a gander at the set. Its not worth risking life and limb to save a few bucks, Good Luck
Jul 30, 2006 | RCA P52920BL 52" Rear Projection...
RCA F36650 36" TV Logo
192 people viewed this question
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
