First....try unplugging the set for about 2 minutes-- the plug it in...and see if it will "boot up' after that. It should take LESS than 2 minutes for the set to boot--and the light to stop flashing after the power is applied to set. If this does not help...you may have a problem with the DM module or bad capacitors on the power supply board. Sometimes...the DM module can be repaired with capacitors, like the PS--but other times...it will need to be replaced.
Model WD52825: No sound when connected to ANT-1 which is local digital TV or to TV hard disc. . Had...
(More)
Model WD52825: No sound when connected to ANT-1 which is local digital TV or to TV hard disc. . Had sound previously on ANT-1 and hard disc. until last night. Do have sound when connected to all other devices : cable, DVD/VCR, cards, PC Computer etc. Do you have a resolution?
My tv is off with a blinking light, when I turned it on, there was no image in the screen but there...
(More)
My tv is off with a blinking light, when I turned it on, there was no image in the screen but there were lines at the top and jumping pictures. Then it turns off after a few seconds. I tried to turn off the timer but the remote does not respond. Can somebody help me?
replaced the bulb with my old one and still have shaking line for picture. I wouldnt think the...
(More)
replaced the bulb with my old one and still have shaking line for picture. I wouldnt think the problem would be with the bulb. any thoughts?
