Question about RCA Scenium HDLP61W151 61 in. HD-Ready Television
Philips 42PF5321D/37 We received this tv yesterday. We set it up and it worked fine for a few hours then the screen went blank and it buzzes now. I see a small crack at the top of the screen. Is this the problem? Why would it work at first and then out of nowhere shutdown?
    Genius:
  • 1,067 Answers
Cuse its a philps bad trasiters in back i would take it back get your self a real samsung or sharp ok best on market if that buzzes now u just got it also take it back no good wile u can asap today ok get a nicer samsung u love it on sale circuit city
Posted on Jan 19, 2008
  • nick helpap
    nick helpap Jan 19, 2008
    samsung plasma thats it 42 in is on sale 1099 circuit city best price
I have a Philips 42pf5321d/37 that won't turn on.
send me a email sonny@tvcircuitboards.com and I can assist you with troubleshooting it to determine whats happening with the set.
Aug 07, 2012 | Televison & Video
Phillips model#42PF5321D/37 black screen and red light flashes.unable to turn on. sonia
Power supply board is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Apr 21, 2010 | Philips 42PF9431D/37 TV
50PFP5332D/37 has sound and no picture.
try restting push the menu button in on the side for 5-6 second
Sep 05, 2009 | Philips 50PFP5332D 50 in. Plasma...
42 Philips Plasma 42pf5321d/37 green light on no AV no Menu nothi
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung, Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Link to a photo of the PCB. Make a note of the location of all cable connections then unplug them all. Un-install PCB, Check a Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H. 2nd more of a long turn approach to your system. You might look at a Power conditioner to ensure constant clean Voltage & current to your Set, Price I know running about $150 to $200, but this will protect your set from a Spike and under voltage swings from the 110V plug. Surge protectors only help the Spikes on the 110v Line not the Drops. Hope this helps
May 29, 2009 | Philips 42PF9630A 42 in. Plasma Television
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsun. Know to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio conections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Link to a photo of the PCB. Make a note of the location of all cable connections then unplug them all. Un-install PCB, Check a Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
May 16, 2009 | Philips 42PF9630A 42 in. Plasma Television
Screen goes blank, audio still works
I had this problem on my 42" Philips. Just got it yesterday and worked fine on the tv stand. As soon as I mounted the TV to the wall via wall mount system, I had the exact same issue you did. Figured it out today.
The wall mount was putting pressure against the center of the back of the tv (tv set had a slightly rounded back plate, and the mount was a flat plate). As soon as I put spacers (part of the wall mount hardware set) between the wall mount braket and the tv so there was no contact except at the mounting holes, the tv worked fine.
My theory is the pressure pushed the tv back plate against some board components which caused them to overheat (no air flow); or put pressure on internal connectors. I dont know.
Hope this helps, may not apply to your situation.
Oct 26, 2008 | Toshiba 37LX96 37 in. LCD TV/DVD Combo
We just set up our 37 in sharp and get no picture
If this is a new set, return it for an exchange. This one sounds like an LCD set which uses a "back light". This back light is not working. This is a warranty repair or exchange.
Dan
Mar 17, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
15PF9936/12 Flat TV
check the small fuse on the underside of the board that is the high voltage drive for the CCFLs
Jan 16, 2008 | Philips Epic 15PF9936-37 15" Flat Panel...
RCA Scenium HDLP61W151 61 in. HD-Ready Television Logo
79 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
