Question about Kodak Office Equipment & Supplies
SCANNER IMAGE TOO BIG
I am using a Kodk I660 along with Paperflow to scan documents however the image is too big on the monitor, it is cutting off about a 1/2 inche per side of the paper and only scanning a portion
remt23c
  • 78 Answers
SOURCE: Out of paper :CDT009 Load mroe paper to continue scanning
on the admin utility go to the errors tab and remove the out of paper action, return error
the disadvantage of that is you have to click on the scan icon to start scanning.
Posted on Oct 15, 2007
mohanchennai
  • 490 Answers
SOURCE: DR 2050C
This has something to do the brightness chosen. In the manual mode, if you choose a dark output, the output will have tis area also; if you choose, lighter output, it will omit. In the auto scan mode, the scanner decides what is the best output.
S. Mohan
Posted on Mar 05, 2008
SOURCE: I'm using a HP Scanjet 2400 scanner. After I
THIS THE PROBLEM OF YOUR DATA THIN CABLE WHO HAVE INTERLINK WITH CCD BOARD WITH PAWER BOARD PLZ CHANGE WITH CABLE AND 100% SOLUTION
ASHOK RANA JALANDHAR
9815424965
Posted on Apr 02, 2009
SOURCE: using epson v500 and can't get it to change the
I had the same problem and have found my answer. I don't know if it's the technically correct one but it works.
When you open the scan page and it shows you the mode, setting, original document type, destination, adjustments, and then the preview and scan buttons. Under the Preview button you will see a box check marked for thumbnail. Remove the check and then do a preview scan. You should end up with a complete scan showing the slide (if you only scanned one), the open side and the surrounding blackened area too. Click on the picture in the preview and then draw an outline around the part of the picture that you want to use. Do this just like it you were going to do cropping of the photo. Once you have the box around the part you want click on zoom. Your next preview will be the picture that you want. I haven't figured out how to remove the remaining blackened area with out going into a photo edit program but it must be able to be done. Then you can scan to where ever you save them to and have the whole slide. I hope that this gets you at least some what further along.
Posted on Apr 08, 2009
SOURCE: Epson Artisan 800 Scanner leaves blue/grey stripe on side.
I had this exact same issue with two Artisan 800's. I was told it was a hardware issue. Both were returned under warranty to Epson. Have since had problems with ADF and that printer was returned. Warranty has now ended. Expecting to buy a new printer shortly: they last about 4 months before having problems. It won't be an Epson even though that's all I've owned for 10 years
Posted on Dec 15, 2009
5650c not scanned. making paper jam. rollers replaced. making big noise.document page stop halfway through
PDF]fi-5650C Image Scanner Operator's Guide P3PC ... - Fujitsu
www.fujitsu.com/downloads/.../scanners/.../fi-5650c_ops-guide.pd...
FujitsuThank you for purchasing the fi-5650C fi-5650C duplex color scanner product. ... 6.1 Removing jammed documents ..... store where you purchased the scanner or an authorized FUJITSU Image Scanner service provider to make repairs to this .... It is adjusted to the width of the paper in order not to scanned skewed pages. 5.
Okidata User's Guide OKIFAX 5650 Error Messagesmy.okidata.com/man-OF5650.../006B738F6240C3BF8525678500678C...Make sure a new drum is available, and replace the drum ... to be faxed or scanned hasjammed in the scanner. Refer to the "Problem Solving, Clearing aTroubleshooting - Oki Printing Solutions in New Zealandwww.oki.co.nz/support/printer/.../index.aspxOki Electric Industry... MB491 ES4191. FAQ: Paper Jam Clearing MB451 MB471 MB491 ES4191 ...MC361 MC362 MC561 MC562 How to setup scan to email. Open the attached ..... Can I disable Colour Copying and make only B+W Copying available? No, it not possible to disable Color Mode when copying via the Scanner Operator Panel.
Jan 29, 2016 | Office Equipment & Supplies
Kodak i660 black line on scanned document
The black lines are caused by either marks on the scanning strip or a fault with the scanner. If there are no marks on the scanning strip then there's nothing that can be done without sending it for repair. Details of the cleaning procedure are shown in the instruction manual.
Jul 19, 2012 | Kodak i660 Scanner
How do you scan a picture into the computer with a lexmark P6250?
SORRY, I COULD DO ALL, SAID TOO BIG, Using a computer 1. Make sure your All-In-One is connected to a computer.
2. Load your document face down on the scanner glass. For help, see Loading your document on the scanner glass.
Open the Lexmark Imaging Studio. For help, see Using the Lexmark Imaging Studio
4. Click the Scan button.
The All-In-One Center appears with the Scanning & Copying tab expanded
5. Click Preview Now in the upper right corner of the All-In-One Center.
An image of the scanned item appears in the preview section.
6. Click and drag the dotted line box to select a specific area of the preview image to scan.
7. Click Display Advanced Scan Settings to review and change the scan settings. Click OK.
here is the web site where the info was. If you want to see better images just click on link below. good luck :0)
MORE LOOK AT WEB SAYS TOO LONG
http://www.lexmark.com/publications/
pdfs/2007/6200/winug/en/frameset.html
Nov 19, 2009 | Lexmark P6250 All-In-One InkJet Photo...
We have a Canon Scanner Canoscan N124OU. We have
hey try to crop it, once the scan image is been previewed the sides of the scanned image can be resize, try to resize it by using your mouse.
Oct 25, 2009 | Canon CanoScan N1240U Flatbed Scanner
The document size is too big when scanning
I'm assuming that you mean the scanned image is to big to fit the screen, and not that the document you are scanning is too big to fit in the scanner...
Try reducing the resoloution of the scan, this will redce the size of the scanned image.
EG: at the moment your probably scanning at 1200 dpi, when 300 dpi might suit the application better.
Oct 06, 2009 | HP J4680 Office Jet All-In-One Printer
Scanning docs & size of pdf files on Mac w/HP l7680 All-in-one
The scanner produces a "picture" of the document, much as if you laid it flat on a table and took a picture of it with your digital camera. If you did this, your .jpg from the camera would be several hundred K at a minimum - comparable to the file size off the scanner. That's why the file is so big, it contains a picture and not text data - even though it's still a .jpg file.
If you reduce the scan resolution you will save space, but at the expense of legibility of the document image. To get it down to the smallest possible size, you will need to run the scanned image through OCR ( Optical Character Recognition ) into a Word document for example, and then print it out to a .pdf file. If you have a clean source document with few graphics this isn't as difficult as it may seem. Microsoft Office has an excellent OCR process known as Document Imaging. You need to carefully proof read the result but with a clean input Document Imaging is amazingly accurate in Office 2007.
In short, there is no easy solution to your problem.
Dec 30, 2008 | HP Officejet Pro L7680 All-In-One Printer
Question about copying direct from scan to a Word document
Check if your Canon software creates a PDF image. A scanned image is a RASTER image, a series of dots, that 'appear' like text or drawing. You cannot use Ctrl-C or Ctrl-v. If the software creates a PDF file, you can cut & paste. Usr any good OCR (Optical Character recognition) software ad convert the raster image to editable text. Then you can cut & paste.
S. Moha, Chennai
Dec 02, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Pentax DSmobile 600 scanner cuts off image
Try recalibrating it. If you don't have calibration sheets, buy them at:
Calibration Sheets and Cleaning Kit $2.98 plus shipping.
http://www.opticsplanet.net/pentax-dsmobile-600-calibration-cleaning-kit-206717.html
Jul 30, 2008 | Pentax DSmobile Path-Through Scanner
Documents scanned as 256 grey scale/TIFF show up as black pages.
Grey as you know is different shades of black. Uncompressed TIF can store this information. Compressed TIFF is not designed for this. Compressed TIFF is for blck & white only. Try JPG option. JPG can compress Color & Grey. For pure black & white chose TIFF compression.
S. Mohan, Chennai , India
Jan 05, 2007 | Canon DR-9080C Path-Through Scanner
90 people viewed this question
Top Kodak Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
