Question about Garmin StreetPilot c340 GPS Receiver
Battery Charging How do I know when the battery is fully charged? And when I reset it, do all of my Favorite Locations get deleted?
    Problem Solver:
  • 5 Answers
You can tell the battery is fully charged on this model from the Where to go and View map page. It displays battery status in the upper right corner when disconnected from the cable or charger.
Don't know on the reet as I have not done that. You might try the garmin website and post a question to their support group.
Posted on Dec 27, 2007
Nikon d300s
Refer to everything that has to do with battery. I wonder if you can see anything on the control panel. If nothing is there you battery is dead for sure.
If you can see symbols on the control panel, it could be your on on / off switch is defect.
The Battery
Check the battery level be focusing the camera and replace or charge the battery if necessary. Do not continue charging once the battery is fully charged as this will result in reduced battery performance. Whenever possible, carry a fully charged spare battery when taking pictures on important occasions.
Do not use the battery at ambient temperatures below 0 C (32 F) or above 40 C (104 F).
Charge the battery indoors with an ambient temperature of 5 C to 35 C (41 F to 95 F) before use.
Note that the battery may become hot during use; wait for the battery to cool before charging.
Failure to observe these precautions could damage the battery, impair its performance, or prevent it from charging normally.
On cold days, the capacity of batteries tends to decrease. Be sure that the battery is fully charged before heading outside to take pictures in cold weather. Keep spare batteries in a warm place and exchange as necessary. Once warmed, a cold battery may recover some of its charge.
Dirt on the battery terminals can prevent the camera from functioning. Should the battery terminals become dirty, wipe them off with a clean, dry cloth before use.
If the battery will not be used for some time, insert it in the camera and completely exhaust it before removing it for storage. The battery should be stored in a cool location with an ambient temperature of 15 C to 25 C (59 F to 77 F). Do not store the battery in hot or extremely cold locations.
Nov 16, 2013 | Nikon Cameras
Xperia x1 won't charge. The charging symbol will appear on the screen for a short period of time (perhaps 2 or 3 minutes) before disappearing a showing the full battery symbol. This shouldn't appear...
First try to replace the battery, a drained or low voltage battery won't charge up.
For infos on how to fix the Sony Ericsson Xperia X1 Not charging:
Aug 31, 2010 | Sony Ericsson XPERIA X1 Smartphone
Navigon 2100 doesn't pick up any signal. Tried by keeping it on for more than an hour at various locations outside.
Nine minutes is the maximum time a GPS should take to lock on to a signal. Longer periods are caused by a failing battery or a battery that is not fully charged.
Either charge it via AC or USB, car chargers do not charge them fully they are just mainhtenance charging.
Please rate my help++++Thanks for using FIXYA
Dec 06, 2009 | GPS
Tom tom will not switch on
try charging the tom tom fully and then reset while it is charging. a tom tom will not reset unless the new battery is fully charged which may take some time if you only have a car charger.
please give me a fixya! rating if this helped.
Apr 04, 2009 | Tomtom ONE 3rd Edition GPS
Microtek Inverter not fully charging the batteries
xenion pure shinewave inverter not charging fully
Jan 17, 2009 | Computers & Internet
Jan 07, 2009 | Samsung YP-Z5 MP3 Player
I have a Panasonic KX-TG6051CM
I had the same problem, and it seems that the battery charging circuit in the handset had locked up, constantly charging the battery until it overheated. I was able to reset the circuit in my handset by completely draining the battery. Here is the procedure:
1. Remove the handset from the charging cradle, and leave it on for a few days until the battery runs out, and the handset finally turns off. At his point, the battery will be very low, BUT NOT COMPLETELY DRAINED.
2. Next, you must manually drain the charge remaining in the battery by shorting out the two contacts on it. Shorting won't damage the battery, since it is holding very little charge at this point. An easy way to physically do this is to remove the battery, and place a piece of thin wire across the the two contacts of the HANDSET. I am referring to the contacts inside the handset that connect to the battery, NOT the contacts on the bottom outside that connect the handset to the charging cradle. Next, put the battery back in, sandwiching the wire between the battery's contacts and those inside the handset. This will hold the wire in place. DO NOT PUT THE HANDSET BACK INTO THE CHARGER, WITH THE BATTERY SHORTED OUT.
3. Wait about 30 minutes for the battery to completely die. Remove the jumper wire, and but the handset back into the charger.
4. If the battery was fully discharged , you will get a message on the handset telling you that you should let it will charge for 7 hours. If you do not get this message, then either the battery was not fully discharged, or your problem is different from mine. Try the procedure again in Step 3 for another 30 minutes to discharge the battery some more.
5. If you get the "Wait for 7 hours to charge" message on the handset, then leave it in the charging cradle for the 7 hours requested. After that, it should work fine.
Let me know how you make out.
Mar 24, 2008 | Panasonic KX-TG6051M Cordless Phone
Palm Charging
Synchronize your E2, then work on draining the battery all the way down in order to reduce the effect of battery memory. Memory happens when we repeatedly partially charge a battery. Over time the battery will forget how to keep a full charge, but will remember how to be partially charged. That's usually when users realize there's a problem. The first step is to drain the battery and FULLY charge it at least fully on the battery's indicator, but if you can, let it sit for 24hrs. The second step is to try to use the battery more before charging it and let it charge fully (ie-overnight) before using it when you need to charge it.
Good luck and let me know how you make out.
Jan 09, 2008 | Palm Tungsten E2 Handheld
Battery indicator/charging defect
Do you have a Treo desktop charger/sync cradle where you can drop the battery into the charger?
Jun 14, 2007 | Palm Treo 650 Handheld
Garmin StreetPilot c340 GPS Receiver Logo
74 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
