Question about Garmin StreetPilot c340 GPS Receiver
Charging How long do I have to charge my Garmin before it is charged completely?
    Problem Solver:
  • 5 Answers
From a complete drained battery it took me about 2 hours of charging via the USB cable hooked up to my computer to fully charge it.
Posted on Dec 27, 2007
  • 35 Answers
SOURCE: When you are charging the Garmin Nuvi 660 how do you know when its done charging?
No way to know except you disconnect and watch your 4 baterry bars.
It take almost 4 hours to be full charge.
Posted on Jan 21, 2008
SOURCE: Charging a Garmin Nuvi 260W
Generally most batterys are left on the charger overnight, thats a good way to ensure a full charge, but as you will be using it in your car, it doesn't matter much as power is always available.
To ensure best possible battery life when you have a brand new battery, charge it fully and then drain it almost to 0% Draining most batterys into 0% will be harmfull instead of helpful, I assume the nuvi uses a Li-ion battery so draining it fully is not a good idea, drain it almost fully and then charge it fully.
And you are good to go, repeat the process if you leave the unit unused for a month or two for best battery life.
Thank you,
IwillFixIT!!
Posted on Nov 15, 2008
SOURCE: cant use the garmin 350 while charging
The solution is really easy. Works in the car or usb charger or whatever.
Once you insert the car charger, wait till the pc connection picture comes.
Than unplug the car charger.
Re-insert it as soon as the picture goes off.
Voila. It is ready to use now!
Posted on Mar 04, 2009
ginko
  • 19396 Answers
SOURCE: garmin gps won't charge while driving
If the Nuvi won't charge when connected to charge but charges on USB, then the charger port is faulty.
If the Nuvin does not charge at all , then the battery must be replaced.
Posted on Apr 13, 2009
  • 44 Answers
SOURCE: Is m Garmin nuvi 200 GPS charging
Merritt, Your Garmin Nuvi does not have a charging indicator similar to say your Cell ph. Simply a battery charge indicator scale. Normal full charge time is approximately 3 to 4 hr. If you looking to ensure your unit is in fact charging Plug in & then remove the connection, Your unit will pop-up a screen to request if you wish to remain on battery power. I hope this helps you.
Posted on Jun 02, 2009
My Garmin Nuvi 1300 is turned off and charging. It charged all night and still says its charging. Will it ever read fully charged?
Most likely not. I've been repairing the 1300 series for several years and I've never seen it. The older units would say "battery charge complete". I would go by the green battery icon in the upper right corner of the screen at the main menu. There should be 4 green bars to be fully charged. Of course to see them, you have to unplug the charger.
Sep 11, 2013 | Garmin nuvi 1300 Car GPS Receiver
Garmin 205nuvi ; plug in charger @nd screen shows charging. push on button to left nothing. freind using it ,i think he might have left it on
Let the unit charge; the battery could have be completely drained. It should charge in a few hours.
Thanks for using FixYa.
Sep 06, 2011 | Garmin GPS
When charging my Garmin 265WT, is the screen supposed to show when the battery is fully charged? e.g. charging complete
While it's charging it doesn't show the battery indicator. When the charger is plugged out it shows the battery state on the screen that shows WHERE TO and VIEW MAP
Feb 25, 2011 | Garmin Nuvi 265W GPS Receiver
Unit shuts down while navigating with power cord plugged inalso seems to have dead pixels in screen
Dead pixels you can't do anything about without replacing the COLOR LCD TOUCH SCREEN. Which will probably cost as much as replacing the whole unit anyway.
As for shutting down while plugged in, that may be one of two things. Either the charging cord has gone bad (and they do go bad), or your not plugged into the lighter/charging port in your vehicle completely. Lastly, the charging cord for a Garmin GPS has a fuse in it, at the head that plugs into the charging port. Check it to see that it's not blown. Chances are it may be.
Jul 10, 2010 | Garmin nuvi 1300 Car GPS Receiver
Garmin nuvi 260w is not charging with car charger
You have a short in the wire that runs to your unit. Other than holding the wire in the exact location until your charge is complete you would be better off replacing the charging cord. They should be available at your local shop for around $19-$29.00.
May 29, 2010 | Garmin nuvi 260W GPS Receiver
Hi All, I replaced the battery of my Garmin with an iPod battery. When I place the watch on the charging station the watch displays "charging" for 3-4 seconds but then displays "Charging process...
Since you used an Ipod battery instead of a Garmin compatible one, I would guess to say that it is not quite compatible. Even within the Ipod family, notwithstanding the physical limitations, the battery are not usually compatible because of variations some of which I would describe below:
- Battery has two wire and the regulator is on the device itself.
- Battery has two wires and has an inbuilt regulator (small circuit board fitted to the battery).
- Battery has three wires of which one is used by the device to control the charging
- Battery has three wires and inbuilt regulator (small circuit board fitted to the battery) of which one is used by the device as status indicator.
Hope it helps you do your own diagnostics but be very careful especially if the rechargeable Lithium battery is bulging as they do explode when not charged correctly! NEVER PIERCE A BULGING LI BATTERY!
Jan 02, 2010 | Garmin Forerunner 305 GPS Receiver
Nuvi 200 when charging never says charging complete .
HI, I have the same NUVI. Mine does the same. I haven't had any issues with it. It still charges fully when I unplug it.
Jul 25, 2009 | Garmin nuvi 200W GPS Receiver
Mar 09, 2009 | Garmin nuvi 200W GPS
How do i charge my garmin 750
Plug the charger into the mini-usb jack. The unit should turn on and when you come to the main menu, you should see a lightning bolt over the battery bar graph. This indicates that it is charging. If you don't plan on using it and want to charge it over night, if your Nuvi has a push down power switch on the top, press and hold it briefly until it goes to a black screen and says charging. If your Nuvi has a slide switch, slide it to the left until you get the same charging screen. A few seconds later, the screen will go dark but if you touch the screen, it will light up again and say its charging and go dark again. After several hours, when you go to touch the screen it will say Charging Complete". Yiu will also notice then when you go to use it, you will see ALL of the green bars on the battery bar graph will be lit.
- Jim
SHARCNET-USA
Dec 05, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin StreetPilot c340 GPS Receiver Logo
89 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
