Question about Panasonic Lumix DMC-FZ7 Digital Camera
Remove Lens Cap
My camera keeps coming with message, yet the lens cap is not on. It appears that the lens is not retracting.
The camera is less than a year old, and I have taken about 200 pictures. I am not going to spend hundreds to repair it. Is there anyway that I fix this?
  • 3 Answers
We had the same problem with our FZ8. My wife had dropped it and it must've knocked the lens barrel sensor out of whack. I searched google and found a suggestion saying this message occurs when the lens barrel is out of alignment. (http://www.fixya.com/support/t186189-some_reason_camera_keeps_comming_up)
With the lens barrel out, I gently pushed the barrel up, down, left, right and put a little pressure in. Somehow, the barrel worked itself into the right position! The camera works perfectly know. Its worth a shot to save $$$. Be gentle!!
Posted on Dec 31, 2007
  • 51 Answers
Http://www.instructables.com/id/Repair-Stuck-Lens-on-Panasonic-FZ5/
Posted on Mar 26, 2008
Lens cap error message
hello,you actually need to remove the battery for a while,say about 10 minutes,check the contacts where the battery connects,if any sign of corrosion,then use a fine grade of wet and dry(available from any car accessories shop) and gently remove the corrosion,have the battery checked,as lithium batterys suddenly die off at a critical stage,although they appear to run for ages without any undue problems,replace with a known good battery,switch on your camera,but don't do any snapshots for a while,then switch off again,do this a few times,before you begin using the camera,as i had exactly the same problem,and cured my anomaly .hope that helps, cheers.
Jan 02, 2014 | Nikon COOLPIX L810
When i t turn on my Nikon coolpix L810 i keep getting a message to"turn off the camera, remove the lens cap and then turn back on." it seems like the lens starts to expand and then retracts as if it's...
I'm afraid that you are right about the lens being stuck.
The camera has several checks to make sure the lens can zoom freely in and out. If the camera detects there is a blockage of some kind, the lens will retract and switches of the camera to prevent more damage.
I'm afraid there is nothing you could do to fix it, other than bringing it to a repair shop and have them take a look at it.
Lumix DMC FZ35 Lens Opens and Retracts Continually When Turning the Camera on.
it sounds like it has slipped a gear in the lens.. you could try to manually push the lens in when it comes out and that might reset it but it also might break it.. best is to send it back to panasonic.. is a easy fix
Oct 01, 2012 | Panasonic Lumix DMC FZ35 Digital Cameras
When turn camera on get message turn camera off then turn camera on again. did that and repeatedly get same message.
Check to see if your lens cap is on. If the cap is on, the lens cannot extend and you will get that message. If your lens cap is off, check to see if there is something impeding the lens and keeping it from extending. Your camera may "think" the lens cap needs to be removed.
Jul 28, 2011 | FUJIFILM FinePix S4000 / S4050 Digital...
After my kids dropped camera on carpet (it was on but lens was not out, they were viewing pictures). The lens will not move, it's stuck and makes grinding noise like it wants to move in and out. After it...
hi dear alexanderesma, your lens have the pin roller's out of cylinder helicoid,some case maybe repaired, otherwise change of lens unit become necessary.
Please send to Nikon service.
Regards
Mar 11, 2011 | Nikon COOLPIX P90 Digital Camera
My fujifilm s1000 keeps showing "zoom error." I don't know what happend. It's like one day it's working, the next not. I have a family member graduating Friday and can't afford a new camera. I've taken out...
Hi.
If you try turning on the camera with the lens cap on, you may get zoom error. Ensure that you are removing the lens cap before turning on the camera.
If the autofocus ring is held while taking the picture, or operating the lens this will also cause the Zoom error message coming up.
If that is not the problem, then the lens has troubles extending. This may happen because of dust stuck in lens mechanism, or because of a mechanical fault concerning the lens.
Any cause preventing lens from full extention or retraction will trigger zoom error.
Here a basic manual in PDF format.
Here Owners manual.
May 20, 2010 | Fuji FinePix S1000FD Digital Camera
Wide angle cap vs wide angle lens
The cap is a plastic disk, usually black or silver, that snaps on at the end of the lens to keep the lens clean. Some lenses have two caps, one for each end when not attached to the camera.
Some cameras don't use a "loose" cap; those cameras generally retract the lens into the camera body and "close" a door in front of the lens.
Many, if not most, camera users do not use a cap (my guess).
The wide angle lens is generally an "optional" lens that can be used for group or scenery pictures when you want to shoot a "wide" picture. A "normal" lens is generally around 50mm (plus / minus 5mm). A wide lens is anywhere from 17mm to 24mm (or so).
I recommend obtaining a wide lens... with a cap.
Hope this helps!
Sep 10, 2009 | Casio Exilim EX-Z57 Digital Camera
Error message- remove lens cap and press > button
Is your lens not retracting?
I've got the same problem and with the lens not retracting - this is why i get the message.
Jul 29, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
FZ18 Lens Cap error message with telephoto converter
I have the same camera, and had the same problem. Make sure the camera is switched off. Then take 2 hard pieces of plastic with sharp ends. Carefully try & jam the outer ring with one, and try turning the converter with the other. I used a mini screwdriver, and left some marks on my camera. Thats why I recomend using plastic of some kind.
When you use the converter, switch off the battery saver in the camera. That way the converter won't jam again, as the camera won't switch off automatically. There is also a programme in the menu that is used for converters and external lenses. It also prevents the lens from retracting completely.
Hope I have helped you.
DaveSA
Mar 21, 2008 | Panasonic Lumix DMC-FZ18K Digital Camera
Panasonic Lumix DMC-FZ7 Digital Camera Logo
197 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
