Question about Bose 3 2 1 GSX System
Popping sound from speaker when changing channels
When i change channels fast on the TV i hear a popping sound coming from the speakers.
  • 3 more comments
  • bungalow Dec 30, 2007
    I sometimes get the same popping noise when I change channels quickly.
  • jaybird56 Nov 18, 2008
    My Bose 3-2-1 makes a loud clicking sound when changing channels on my cable TV box. It is intermittent. Sometimes very loud, othertimes seems normal. The system was set up by the merchant. Using the Bose remote to change channels.
  • jholl Nov 21, 2008
    same problem popping noise from the speakers
  • dbrown2161 Dec 29, 2008
    bose 321 when changing channel with cable box , there is a popping noise
  • JJNYC Mar 18, 2009
    Loud popping noise like a static discharge when I press play after fast forwarding on the cable DVR. Sometimes I get a white snowy static background noise as well that goes away if I restart the system. And occasionally I the whole system gets super loud with some crazy feedback distortion noise that freaks me out.
  • 132 Answers
This noise is normal with the cable box unless you set the cable box on HDMI sound
Posted on Feb 01, 2009
Apparently this happens with some cable boxes and receiver combinations. When you change the channel the intermission period cuts the sound and starts back up again when the signal goes through or picture appears. I know its annoying I have a samsung 720 and trying to figure this out switching hdmis and switching speakers and same problem. There is nothing wrong with your box or receiver just something you have to deal with or get some other reciever i don't think Denon recievers do this
Posted on Mar 12, 2009
  • Derek johnson Apr 02, 2013
    My denon does this.. and it is also brand new. This drives me nuts.. I use a Tivo and it does it all the time.
Speakers pop when changing channels
Posted on Feb 01, 2010
2010 VW CC factory stereo amp popping sound
If the amplifier itself is making the popping sound I suggest you disconnect it immediately, as it could be an electrical short within the amp. If the popping sound is actually coming from the speakers, it could be due to a crossed wire, blown amp channel, or blown speaker. If you posses the technical know-how, you can test the amp channel and speaker by connecting a different speaker to the channel responsible for the popping sound. If the new speaker makes the same popping noise then it is most likely a blown channel. I hope this helps =)
Cracking and poping with Yamaha surround sound system
Try put a ground line from any metal of your stuff to the any metal direct to the ground. these eliminate noise of the speaker.
Jan 03, 2008 | Pioneer VSX-54TX Receiver
I have no sound from one channel. I have swapped speaker leads (sound just swops with the speaker). I have taken lead out of CD player and touched ends of leads for "earth hum". Only get hum on...
If the sound stays with the speaker, then the problem is with the speaker not the receiver (unless I misunderstand). You state that changing the speakers that the sound stays with the speaker. This means that both channels are producing sound, it is the speaker which is defective. You can verify this by using a 9V battery. Quickly touch the leads from the speakers to the battery. You should hear a pop or click. If the speaker is defecive, you won't hear anything.
Let us know what happens.
May 08, 2011 | NAD C350 2-Channel Amplifier
In chennai free kalaignar tv sound not coming i changed sound ic an 17823a still sound not coming ples sen me the detail of this sub!!
you replaced the power amp ic before that you need investigate the condition of power ic and it's very simple when you terned on the tv set you can hear the small pop noice from the tv speaker means the power ic is good other way is just tuch the screw driver to sound if output stage you can hear the DERRR sound from the speaker
if it ok pls check the mute transistor
Aug 27, 2010 | Televison & Video
Speaker popping using Videologic ZXR 500's
for the popping, go to windows sounds and switch it off so you wont get any sounds by clicking.<goto control pannel-> sounds -> goto 'sound' tab -> under 'sound scheme' select no sounds. this will solve your problem temporarily.
Jul 11, 2009 | ASUS Xonar HDAV1.3 Deluxe 7.1 Channel...
''Hotel'' Viewing mode on Akai TV Model #CTS2550
Did you get an owners manual with the television?
Jul 01, 2017 | Akai CTS2550 25" TV
Panasonic Home Theater SC-PT760
This is not a problem, this means that your system is working. Polar Express was recorded in Surround Sound with separate tracks for each speaker channel. In most movies you will find that the rear speakers will only play certain sound effects so that it appears they are coming from behind you (gun shot, train, fireworks). Most of the diaglouge will come through the center channel and music/effects through the front left and right, with bass coming from the subwoofer.
Now, you can still hear more from the rear speakers if you like this enveloping effect, or if you like your music coming from all directions. There are Sound Effects options to have the front and back speakers always playing the front track, there is Dolby Pro Logic II that turns stereo sounds (like many TV shows) automatically into 5.1 Surround Sound, and you can also individually change the volume of each speaker.
These are all explained on page 29 of your owner's manual under Sound Options. If you need specific button to button help, let me kow.
Jun 29, 2008 | Audio Players & Recorders
Popping noise coming from tv
shut off the sap in the audio settings and place it into stereo
Mar 30, 2008 | Akai LCT3285TA 32 in. LCD Television
Poping sound when channel is changing
hi, Jewtastik
well, is a generic problem to see ...but starting with your TV, hometheather, you should check if you have a lot bass on it, down a little the bass to see, and check if your sub is not bad.
I dunno know the brand nore the TV , so you should go and play a little with settings on sound fields on the hometheather.
good luck
Nov 18, 2007 | Durabrand 5.1 Surround Sound Computer...
Bose 3 2 1 GSX System Logo
3,810 people viewed this question
Top Bose Audio Players & Recorders Experts
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
