Question about Xerox DocuColor 12 Printer
XEROX DOCUCOLOR PRIN 12
DOST AND STAIN ON PAPER WHEN PRINT. BAD QUALITY TO PRINT
PLEASE LET ME KNOW WHAT I NEED REPLACE. I TRIED TONER, CLEANED TANK TONER PLEASE HELP ME UP.
THANKS
Gracias por el tip. Logre arreglarla gracias a ti. De verdad te agradesco. Pedrotena59@hotmaill.com
Posted on Jan 02, 2008
    Problem Solver:
Check the blade (knife) , maybe dont clean all residues, sorry form my english, check the fuser roll, this roll have a teflon, mabybe need change!
XEROX Docucolor 12 Color Developer PN needed HELP
DEVELOPERS:black 5R616 ; yellow 5R 619 ;magenta 5R 618;cyan 5R617
TONER : magenta 6R1051 ; cyan 6R1050 ;yellow 6R1052
Sep 14, 2009 | Xerox DocuColor 12 Color Copier
Dc 12
Did you check the sensors?
Feb 28, 2008 | Xerox DocuColor 12 Printer
Prints aren't plain, it have some texture like crayon
its problem of toner
its of good quality
and also check proper supply of toner into develper assembly
trying to add some extra ink directly in developer assembly
if problem solve
check
cartridge motor running
and supplying toner proeprly
May 24, 2009 | Xerox DocuColor 12 Color Copier
Black stain shadow from the same image print
a fault or an error has occurred see user guide for information on fault code 042-326  Docucolor 250
Mar 26, 2009 | Xerox DocuColor 12 Color Copier
Xerox docucolor 12 copy/print printing all black
If you moved the printer, make sure the conections from the printer to the Fiery are secure. If loose the prints will be black but when copying will be fine.
Jul 19, 2008 | Xerox DocuColor 12 Printer
Docucolor 12 error 9-356
That is a yellow toner empty message
Jun 09, 2008 | Xerox DocuColor 12 Printer
XEROX DOCUCOLOR 12
Remove drum unit. check charge wire for contamination. clean or replace. Visually check fuser for an even glossy appearance. If it looks dry or damaged in any way a service is needed. IBT is a bit more difficult to check. If you have the know how to remove it. You should see a very shiny surface free from contamination of toner or paper dust, ect. clean if necessary and replace. If contamination reoccurs suspect cleaner. Last is the BTR check for proper operation and clean, repair or adjust if necessary.
May 26, 2008 | Xerox DocuColor 12 Printer
Print Quality
The developer housing has failed.
Mar 25, 2008 | Xerox DocuColor 12 Printer
Dc 12
error code is 14 376 plese solve the problem
Feb 05, 2008 | Xerox DocuColor 12 Printer
Docucolor 12 error code HELP
9-357.
Black toner problem.Probably You have low toner sensor defect.
But try first to vacuum and clean black toner dispenser.You must vacuum whole path wich is used to transport black toner to developer unit.Then if printing B/W print only, you must print 10 full color sheets every 100 copies.
Sep 13, 2007 | Xerox DocuColor 12 Color Copier
Xerox DocuColor 12 Printer Logo
129 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
quennie732
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
