Problem qdi p4i865 pro
Hello having problem with my p4I865 pro. motherboard dosent reconized my ram memory have them going in dualcahnnel but they only go in 133mhz not 400 as they should and shouldent it be 800 in dualchannel? in my bios setting i cant change the ram freqence. thanks for answer
Fredrik sipuri
/Sweden
As map9966 says check the link, allthough it's not working for me now i would guess your problem is that you are currently running on PC2100 RAM sticks which has a default bus speed of 133MHz and may not perform well in dual channel. it could also be that you are running a processor (CPU) with a lower bus frequency. example: Intel Celeron 2,6GHz with 400MHz Bus frequency wouldn't run at top speed because of the difference in the FSB and memory bandwidth.
Note: DDR in dual channel is not indicated as 800MHz anywhere; however in dual channel (with PC3200) both memory modules run at 200MHz each which results in a "dual channel" = 400MHz.
I think you might be mixing up the FSB on the processor with the RAM frequency:
CPU - FSB on this board is 800MHz (P4 exists in 400, 533 and 800MHz)
Memory on this board is 200MHz per channel (400MHz in dual) (PC3200)
Posted on Nov 04, 2008
    President:
  • 2,351 Answers
Check your manual and find the QVL list. Memory tested to work in your board is listed there. I found a link that shows your board. Click the Download on the left & check your manual.
http://www.qdigrp.com/qdisite/eng/news/20030521.htm
You Max speed is 400Mhz memory as you will see at the link.
Please vote...
Posted on Feb 01, 2008
Hallo, i need the manual for mainboard QDI P4i865. Thanks for help E. Harbeck
There are several submodels of that Mainboard but they are listed here. Pick the one that matches your exact model.
http://www.easyhelpguide.com/manual/QDI.html
Mar 05, 2011 | Computers & Internet
PEASE SEND TO ME THE DRIVERS FOR MOTHERBOARD QDI P2PE/800
the drivers are easly available in internet go to google type the model no and down load the drivers save it in to hardisk and dont forget to burn them in to cd
Nov 29, 2010 | Intel QDI P2PE/800 PRO 82845PE SOC 478 M...
Hello again.I have an old home pc and I want to upgrade the cpu processor without changing motherboard.Wich is my best options?I want to know if I can to upgrade to PENTIUM 4 3.00 GHz.Also I want to put...
If new processor supports your old motherboard then you will upgrade system with your old motherboard.
If its not supported to new mother board then you have to buy new motherboard to upgrade your system.
Thanks.
Happy to help you.
Apr 30, 2010 | Intel CPU
How to add memory? what is the proper memory?
Here is the stats on your bored
Memory Memory Type dtrquestion.gif SDRAM Max Supported RAM dtrquestion.gif 1.5 GB
your bored takes sdram and is only upgradable to 1.5gigs total
To upgrade your bored. you will see on you bord some long slender black sockets. that should already have a stick of ram in it. You will see on the end of each one like a pin that holds it in place. Just push them down, and it should open them up. You can pull the old one out and put a new one in. Or just simply push a new stick down into it, tell those little pins snap back into place holding the stick of ram. They will only go in one way so don't force them.
if this was helpful and answered your question please mark it fixya and rate me as well as recommend me.
Dec 06, 2009 | QDI Group QDI KuDoz 7 Motherboard
QDI Group QDI Advance 6T Motherboard memory
make sure you are putting in the correct ram and make sure both are in good, may be registering only one, or maybe one is bad. try them one at a time in each different slot. should tell you if both chips/slots work
Dec 01, 2009 | QDI Group QDI Advance 6T Motherboard
How can i know if a ram suits my Legend QDI
you got to options
1. following the indications of your motherboard documentation (recommended/best), if you need to find out details about your motherboard you can possibly download and use one of this tools to get info about your motherboard and possibly find the manual online in the manufacturer's website
2. the following page will check your system to find out what memory you have and what you need and up to how much you can go http://www.crucial.com/promo/index.aspx?prog=uslp_intel_fbdimm
3. checking on ebay: in the following links indicates that it should be low density:
Module Size: 512MB
PC133 SDRAM
UNBUFFERED
Non-Ecc
168 pins
3.3 Volt
Structure: 64Mx64=512M
Low Density: 2 Banks of 32Mx8
SPEED: 133MHz
CAS Latency: CL3
hope this helps
Nov 22, 2009 | QDI Group QDI Advance 10T Motherboard
Can work Memory SDRam 128MB PC100 with SDRam 512 MB PC133
It wont work, it will hang ur system. Ur motherboard supports but using Mutli-frequencies RAM is not possible, either u use SDRAM 512 BM PC133 or ur 64/128 PC100 RAM, You cant use all together.
Apr 20, 2009 | QDI Group QDI Advance 10T Motherboard
Memory
It means the most your motherboard will support per slot is a 256 RAM. Also, on older systems, some RAMs are not compatible with others.
Apr 28, 2008 | QDI Group QDI Advance 6T Motherboard
Computers & Internet Logo
1,035 people viewed this question
Alun Cox
David Payne
David Payne
