I have a underwire from a bra stuck inbetween the tub and the metal interior. Is there an easy way to remove the metal interior, or will I need to call in a repair man?
Comments:
Oct 12, 2009
- Thanks DesertDeuces, My problem is that the wire went in through one of the holes in the agitator drum while in a spin cycle and got hooked on something before I could get the machine shut down. The entire wire has gotten pulled through the hole and is lodged into something between the tub and drum. I have tried repeatedly to work the drum back and forth trying to get the wire to poke itself back through one of the holes so I could grab at it..
If it got in, it should be able to come out. Just gently rotate it and try to manipulate it out. If worse comes to worse, you may have problems turning the wire because of its shape. If that's the case, cut the wire to remove the curve, MAKING SURE TO LEAVE PLENTY OF LENGTH TO WORK WITH.
With a little persistence, you should be able to work it free.
Comments:
Oct 12, 2009
- Since it's a front-load washer, there's a lot of disassembly to remove the inside drum. I certainly recommend calling a repairman. Sorry about that problem. :(
Was this helpful?
Yes
No
Popular Solutions for Bosch Nexxt Premium WFMC6400UC
Bosch Nexxt washer - makes a signal at start of a load and when it ends with no error code. When I...
(More)
Bosch Nexxt washer - makes a signal at start of a load and when it ends with no error code. When I opened front plate and removed 3 inch drain cover, a lot of water drained out and so did little ball bearings. What do I do?
wahing machine keeps beeping drain blockage. I know from my wall to septic is flowing. I try on evey...
(More)
wahing machine keeps beeping drain blockage. I know from my wall to septic is flowing. I try on evey cycle and even spin. any ideas
