Question about Sony STR-DA50ES Receiver
Protector error message comes on when i powered for about 10secs
  • 3 more comments
  • Anonymous Jan 03, 2008
    protector error message problem
  • Anonymous Feb 13, 2008
    I have the same problem. There is this PROTECTOR message and then I can't do anything except switching the receiver off.
  • siziller Feb 24, 2008
    aiwa stereo receiver axr-002-
    protector error message comes on about 5 seconds after powering up and i cant do anything with it except turn the receiver on and off
  • kajtek Sep 02, 2008
    I HAVE THE SAME PROBLEM (PROTECTOR FAN)
    PLS HELP ME!!!! email me.
  • hds oz Dec 20, 2008
    I have the same problem..."Protector" message after 5 secs....
Lexmark x544 108.02 printhead error
1. Power off the printer/MFP, wait 30 seconds, and then power it on again. Did the error message return?
Yes: Continue to Step 2.No: Print a test page. If the page prints, the printer is working correctly.
If possible, connect the printer/MFP's power cord directly into a grounded wall outlet. In rare instances, a surge protector or uninterruptible power supply (UPS) can generate false error messages.Did the error message return?
Yes: Contact Lexmark @ 1-800-(539-6275) No: Print a test page. If the page prints, the printer is functioning correctly.
Aug 16, 2011 | Lexmark X544n All-In-One Laser Printer
HP PSC 2355 does not "boot up".
Is it connected directly to the wall socket for the power supply or thrugh a surge protector.. if its through surge protector try connecting directly to the wall jack ..
Oct 19, 2009 | HP PSC 2355 All-In-One InkJet Printer
Model c6180 printer gives improper shutdown error
The printer is not getting enough power. When you get this error message it means the printer is being turned off by unplugging the power cord. In this case it maybe that the printer is not getting enough power due to being in a surge protector or perhaps the power module is no longer holding power correctly.
First step is to disconnect printer from any power strip, surge protector, or extension cords and plug in so directly to the wall. If printer still will not stop looping cycle you may need to contact hp for a new power module.
Sep 25, 2009 | HP Photosmart C6180 All-In-One InkJet...
Power protector on sony surround sound system
Power protect is an error message that some thing is wrong in your sound system and requires qualified tech.
Normally that error message appears when unit got problem in amplifier output section, either it is speaker problem or some output chip is fried.
Feb 25, 2009 | Sony DAV-S400 System
Fujitsu error message
From service manual -
Error message condition one = fan protector operated.
Check:-
Fan,
Main Power pcb,
Main digital pcb.
Feb 21, 2009 | Fujitsu (pds42trs) Monitor
My HP 6300 xi all in one just died.  Will not turn on.  Any clues as to what could be the problem?
Did you connect the printer directly to a walloutlet to  a power source or do you use a power surge protector. Try to connect the machine directly to a wall outlet. Try to disconnect the power cable from  the back of the machine while the machine is powered on. Reconnect the power cable after 10secs than the machine should reboot by itself. This resolve your issue. Else try to  use  a different power cable,may be the power cable is defective.
Jan 26, 2009 | HP OfficeJet 6310 All-in-One Printer...
Error Message: 0xc18a101
The Ox error you are describing is an issue being seen in quite a few hp printers. The only known fix is to try is while the printer is turned on unplug from power source. Unplug the power cord from the back of the unit as well and hold the power button down for 5 seconds to drain any remaining power the printer may be hanging on to. Wait another 30 seconds and plug the cord into the unit first and then directly into the wall - not a surge protector or power strip.
After you have plugged it back in if the error message comes back up then it is a fatal error within the printer. Call hp and see if they have any upgrade units available - usually refurbished but they come with a 1 yr warranty and are significantly cheaper than buying a new unit from the store. They will also take your unit and pay to have it returned to go to an environmental recycling facility.
Feb 20, 2008 | HP Photosmart C6180 All-In-One InkJet...
Printer stopped printing. Error message
Thjis is indication the Waste in collector pades need changing eventually.- but no now. you have plenty of warning
Reset Epson R300/200
press three buttons to reset the counters
The buttons are "STOP" "Maintenance" and "POWER"
or down load the epson utility www.ssclg.com and use the reset counter feature
The printer will sound like its going to blow up, but thats normal.
You can do this about 5 times before your printer starts to piss out ink over the table because the Waste Ink Ink Pad is full
To avoid eventual flooding go to rear of the machine- remove the little door and rake around for a small plastic pipe buried under some padding under the left side.
Fix to this a thin piece of ploythene tube[Fish tank air supply], extend it to our side the machine and place in a suitable container to collect the waste ink..
Nov 21, 2007 | Epson Stylus Photo R300 InkJet Printer
Printer C760
This error normally requires a service call. However, certain rare occurrences, such as a stray static discharge in the vicinity of the printer or a power fluctuation, can cause a false 103 ITU error message to appear. If possible, connect the printer's power cord directly into a grounded wall outlet. In rare instances, a surge protector or uninterruptible power supply (UPS) can generate false error messages.
Aug 13, 2007 | Lexmark C760 Laser Printer
260 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
