Question about Sennheiser RS 110 Consumer Headphones
Headhpones-how to connect
Bought headphones Sennheier). They do not seem to be working (picking up sound-but we hear static). we have a plasma TV-the Bose system we use does not have an audio output jack. Where shoudl we connect-off the TV reciever;cable box, etc.
  • 155 Answers
SOURCE: No green On/Off light. Charge light is red. I hear only static.
Two things.. Check the batteries..
Also.. since these headphones have to have a signal sent to them to activate transmission (green light simply indicates they are receiving a signal) it can take a few moments after the signal begins to activate them.
I would hazard a guess that when you unplug the cables and then plug them back in.. the feedback that generates activates the base much the same as a regular audio signal would
Finally.. make sure the source is a fixed output.. if not.. and its will have to increase the output or volume to activate the base..
Posted on Apr 24, 2009
  • 155 Answers
SOURCE: RS120 Can still hear TV when headphones are on
Ok.. first.. the simple thing is to go into your television menu and turn the television speaker OFF.
Then exit the menu and turn the volume up.. try your headphones now.
Next.. check the back of the TV for a FIXED AUDIO OUT.. plut your headphones into these outputs.. if you have these.. you can simply turn the set down.. and use the volume control on the headphones.
  • 155 Answers
SOURCE: audio from tv is not restored by turning off power on headphones
It sounds as if you are plugging the base into a standard headphone jack located on the Television set.
RCA Headphone jacks (incl mini) automatically stop the sound output to the main speakers on almost every set I have seen.. or home stereo.. etc etc
In other words you can take a standard RCA jack.. with nothing connected to it.. plug it in while the music or sound is coming out the main speaker.. and it will cut off the output to those speakers..
If you set has audio outputs on the back.. preferably Fixed Audio Out .. you will need to connect your base unit to those.. turn your set volume to 0 and adjust the headset volume using the control on the right ear-cup.
If you have variable audio out.. you will need to go into your TV sets setup menu.. turn off the speaker.. and turn up the set until you achieve a signal and decent volume through the headset.
If you are missing these connections.. your current “work around” is your only solution.
Best of luck
Posted on Jul 07, 2009
  • 1137 Answers
SOURCE: Do I have any options to get 'audio out' instead of h/p jack?
Try the Audio 1 rear. With the headphones plugged in on some T.V.s the headphone jack unfortunately disconnects the audio from the other outputs. Try looking in the documentation to see if you can change this in the T.V.s menu as some allow you to use both for hearing impaired people. Hope this helps.,
Posted on Jul 10, 2009
  • 3018 Answers
SOURCE: My television does not have an audio output so i
Are you using AV cables from your DVD player to your TV? (the yellow,red and white ones) If you are the is a way to do this, since you have no other outputs at all is you will have to make one. With the purchase of a couple adapters and an additional av (audio only cord which is red and white) you can do this. The first adapter you need looks like this. You will remove the red and white AV cords from the back of your TV that run from the DVD player and insert them in the adapter to their respective colors on the adapter. Then you need to purchase a double female AV adapter that looks like this .,or.&um=1&ie=UTF-8&cid=14119505288159192113&sa=X&ei=S-V1TZPDJIKglAexv-ybCA&ved=0CI0BEPMCMAU# Then you need to put that adapter on the one you just installed so you can add the new AV cord onto it and run the new cord to the TV.That completes the sound of the DVD's back to your TV. Now for your headphones. You will need a double female 3.5mm jack input to put between your headphones and the remaining jack on the adapter. It looks like this Play a movie and enjoy. This is the only way to do what you want with the current setup you have. These adapters and wires can all be purchased for less than $10 off of E-bay. If your not using AV cords then the only other way to do it with the current setup you have is --
You can purchase a reasonably priced receiver and hook your DVD, cable, and TV to it as well as your headphones. With no outputs on your TV there will be no way to hear your DVD's through your headphones. You can also purchase a very reasonably priced shelf speaker stereo. Many made in recent years have some audio inputs and of course inputs for your headphones.
Posted on Mar 08, 2011
  • 100 Answers
SOURCE: i am attempting to use my sennheiser rs 110
What are you plugging your 2 RCA connectors (from the headphones) into on the television?
You are correct, usually:
White = Left Red = Right
In this case
Black = Left Red = Right
Not sure....guess some manufacturers need to be different...
Back to the issue,
You to need to connect the Black to White and Red to Red to the TV BUT you need to make sure you are connecting to an OUTPUT and not to an INPUT on the TV. Most newer TV's do have an "audio out RCA jacks" on the TV but not all. It should be labeled at the connector if it is an output, or just another input. You can always consult the TV manual to be sure.
Few things you can do to test
  • Does your TV have a "headphone jack", use the adapter (2 RCA female - 3.5mm connector) to plug into the headphone jack and see if there is sound
  • Connect the Black and Red RCAs from the headphones directly to the another output, like a DVD player, CD Player etc....
I hope this helps,
Posted on Mar 10, 2011
0 characters
1 Points
Sennheiser RS 120 headphones won't work, only hear static
Adjust the tuning wheel on the side of the headphones so it picks it up.
Mar 20, 2014 | Sennheiser RS 120 Consumer Headphones
Nearly constant static
Your cable or phone jack connection is defective.
Mar 12, 2014 | Sony Mdr7506 Professional Large Diaphragm...
No audio just static
Surely the instructions for your new Samsung TV provide at least minimal information regarding what does what.
Dec 21, 2013 | Sennheiser RS 120 Consumer Headphones
Brookstone wireless headphones have static along w/ tv sound
Well I just plugged into the cable box and that worked. On my old tv as well as my newer one the only audio out was an optical I had bought an optical splitter (one input for my sound bar and the other one to the optical to Rca) and an optical to rca for the headphones. This allowed me to use the headphones on all things going through the tv. For some strange reason it no longer works that way (just got my new tv this week). I bought all pieces on Amazon for a nominal cost. I'm going to doublecheck all connections again tomorrow.
Jul 12, 2010 | Brookstone Surround Sound Earbuds...
Just bought the brookstone wireless tv headphones. I have a Westinghouse 40 inch lcd tv. I plugged in the rca red/white into the audio out and I don't get any sound into the headphones?
I had the same problem with Brookstone wireless headset the only solution I found was plug in the red and white connectors to your cable box it works perfectly that way. Just make sure the red cable connector from the transmitter is connected to right red input connector on the box. I have a Comcast cable box. Now I need a solution for them on my PS3?
May 09, 2010 | Brookstone Surround Sound Earbuds...
I can't hear any of the gameplay audio through my brand new X3s..
You have to connect the red/white RCA audio cables that came with the X3 in-between the audio cables that are going to your TV.
Jun 06, 2009 | Voyetra Turtle Beach Ear Force X3 Wireless...
Innovage wireless headphones/how to connect to TV?
I have a plasma, and found when I plugged my HDR65 to back of the plasma audio out, it worked fine. does this help?
Jan 06, 2009 | Headphones
On/Off not lit when plugged in
There is help for this in the user manual. Possible solutions I would try:
1. Make sure your source sound (TV, amp etc) is up high enough - if the sound is too low the headphones won't detect a signal.
2. Try changing the channel (the switch on the bottom left of the cradle base) and pressing the "Tune" button on your headphones. Try all three positions, pressing "Tune" at least 3 times in each position.
3. Take out batteries & turn off base, leave for 30 secs, reassamble and try step 2 again.
Should all work ok. I've been using mine for over a year and they're great!
Feb 06, 2008 | Sennheiser HDR 130 Consumer Headphones
Acoustic research aw722
No need to plug into the back jacks on the TV or change the out put of the tv audio source to the Front jacks
Dec 29, 2007 | Acoustic Research AW-721 Consumer...
No sound, only static
Hi I had the same problem and just emailed Sennheiser.Go to the menu on your TV and change the variable audio output to fixed. I use the headphones through the home theatre so the volume must be max on the home theatre and then you can adjust your headphone volume. It absolutely worked and I don't get anywhere near the static noise when I go to another room with the headphones on that I got previously. Also be sure your audio cable is plugged into the fixed audio output socket. I did not have to do anything with that.
Oct 18, 2007 | Sennheiser HDR 120 Consumer Headphones
Sennheiser RS 110 Consumer Headphones Logo
Top Sennheiser Headphones Experts
Are you a Sennheiser Headphone Expert? Answer questions, earn points and help others
