Question about Sony Ericsson K800i Cellular Phone
Using the CD
Is the CD compatible with Apple MacIntosh? or only PCs?
    President:
  • 1,017 Answers
Both. It will detect what you are using.
Install the software on the CD.
Then go to the support website to update installed software.
the CD software could be 2-3 years out of date.
Posted on Jan 02, 2008
I DID A DEFRAG AND ERROR CHECKING ON MY PORTABLE 1 TB AND IT SHOWS NO PROBLEMS BUT WHEN I COPY DATA ONTO IT THE DATA SHOWS BUT CAN NOT BE USED HOW DO I FIX IT ?.....
This sounds like a compatibility problem between the computer your using and the format (logical structure) of the portable disk.
Many things can cause this but it sounds like you have a portable disk formatted with the NTFS structure that is used with Microsoft Windows computers and are trying to write to it using an Apple Macintosh computer, possibly a laptop (MacBook, MacBook Pro, etc.).
This may not be your problem but lacking more detailed information I'll give this a try this since it exactly describes your problem and provides a workable solution.
The Problem :-
Macintosh computers are not very compatible with Windows devices. They use an operating system called "OSX". OSX can read data from a Windows "NTFS" formatted disk, even error check it, but it can't write to it or repair it unless a utility program that provides NTFS Read & Write ability is installed.
The Solution :-
I use just such a utility, it is available from Paragon Software and costs about $17.00 and gives native Read/Write capability to NTFS formatted volumes.
While you could "Reformat" the portable disk with the OSX Journaling format to make it compatible with Macintosh computers, doing so would wipe all data already on the disk, I'm sure that's not what you want. Using the Paragon NTFS compatibility utility is better in that you would not have to do anything with your portable disk so you would not lose any data already on It, instead it would just give your Mac the same native Read/Write capability that Windows uses thereby making your portable disk Read/Write compatible with both Macintosh and Windows computers. A far better solution.
That's only one of the many possible compatibility problems that could be causing the problem, most problems like this can be resolved by providing me with more information would with allow a more accurate diagnosis.
Al
Mar 03, 2017 | The Computers & Internet
Tip
For the Mac G3. Are there Windows drivers?
This scsi controller is specifically for Apple Macintosh computers, name for the G3 macintoshes of the time. I am not sure if it will work in PCs, although I'd be interested in the information.
on Dec 22, 2008 | Adaptec PowerDomain 2930 (1796200) SCSI...
Usb not recognized on macintosh powerbook g3
The Powerbook G3 will be using the original USB architecture and I suspect that your flash drives are using USB 2 and are not backwards compatible, so sorry I don't really think it is possible.
Dec 16, 2011 | Apple PowerBook G3 Mac Notebook
A printer error has occurred. See your documentation
What are the system requirements for using this printer? A: PC Compatible Requirements
- An IBM (r) compatible PC with at least a 486/66 MHz (for Windows 98) or Pentium (r) 133 MHz (for Windows 2000) processor (Pentium or higher processor recommended)
- Microsoft (r) Windows 98 or Windows 2000
- At least 16MB (for Windows 98) or 32MB (for Windows 2000) of RAM (32MB for Windows 98 or 64MB for Windows 2000 recommended)
- 50MB of free hard disk space (100MB or more recommended)
- VGA or better display adapter and monitor
- CD-ROM or DVD drive for installing the printer software
- USB connection: a computer running Windows 98 or Windows 2000, with a Windows-compliant USB port and a shielded USB "AB" cable up to 6.5 feet (2 meters) long. Using an improperly shielded USB cable-especially a cable more than 6.5 feet (2 meters) long-may cause the printer to malfunction. Apple Macintosh Requirements
- An Apple (r) iMac (tm) series or Power Macintosh (r) G3 or G4 with USB port
- For iMac: Mac (r) OS 8.5 or later (Mac OS 8.5.1 or later recommended)
- For Power Macintosh G3 or later: Mac OS 8.5.1 or later If your iMac is running OS 8.1, you need to upgrade your operating system before installing your printer software. To find out which operating system your iMac is running, select About This Computer from the Apple menu. If you're running OS 8.5 or 8.5.1 on your iMac, Apple recommends that you install iMac Update 1.1. Download the update for your system from Apple at http://asu.info.apple.com. Contact Apple if you have problems installing an update.
- 16MB of available RAM (more recommended)
- 50MB of free hard disk space (100MB recommended)
- VGA display or better
- A shielded USB "AB" cable up to 6.5 feet (2 meters) long. Using an improperly shielded USB cable-especially a cable more than 6.5 feet (2 meters) long-may cause the printer to malfunction.
Oct 27, 2010 | Epson Stylus RX580 InkJet Photo Printer
Cannot use the scanner with Apple Macintosh - no driver!
Hello, I had the same problem.
The thing is the printer is compatible with the mac the scanner isnt.
Pretty dumb but sadly true.
Hope this helps you!!
May 24, 2009 | Canon CanoScan 3200F Flatbed Scanner
SCANNING WITH A BROTHER DCP 7020
I cant find the machine DCP-7020 but I think this machine is the same with model MFC-7420 if you have the installer CD follow these steps:
For USB Interface Cable Users
For Mac OS® 9.1 to 9.2
& Software
1 Turn off and unplug the MFC from the AC outlet and disconnect it from your Macintosh, if you already connected an interface cable.
2 Turn on your Macintosh.
3 Insert the supplied CD-ROM for Macintosh into your CD-ROM drive.
4 Double-click the Start Here OS 9.1-9.2 icon to install the printer and scanner drivers. If
the language screen appears, select your language.
5 Click MFL-Pro Suite to install.
6 Follow the on-screen instructions, and restart your Macintosh.
7 Connect the USB interface cable to your Macintosh, and then connect it to the MFC.
DO NOT connect the MFC to a USB
port on a keyboard or a nonpowered
USB hub.
8 Plug in the power cord and turn on the MFC.
9 From the Apple menu, open the Chooser.
10 Click the Brother Laser icon.
On the right side of the Chooser, select the
MFC to which you want to print.
Close the Chooser.
The MFL-Pro Suite, Printer driver and Scanner driver have been installed.
To install Presto! PageManager, click the
11 Presto! PageManager icon and follow the on-screen instructions.
Presto! PageManager has been installed and the installation is now complete.
You can easily scan, share and organize photos and documents using Presto!PageManager.
Dec 11, 2008 | Brother DCP 7010 Multifunction Laser...
CD is doesnt fit into An media apple comuper
Don't worry about the CD not fitting - the software is not compatible with Apple or Macintosh computers.
Nov 30, 2008 | Sony NW-E405 MP3 Player
CX9400 Windows 98???
Unfortunately, Windows 95, 98, and Me are not supported with this printer.
Listed below are the system requirements for your printer.
Windows Requirements
- A Microsoft Windows compatible PC with an 800MHz processor (1GHz or faster processor recommended)
- Microsoft Windows 2000, Windows XP, Windows XP Professional x64 Edition, or Windows Vista
- 256MB RAM for Windows 2000, Windows XP, and Windows XP Professional x64 Edition (512MB recommended) - 512MB RAM for Windows Vista (1GB recommended)
- 300MB free hard disk space (550MB recommended)
- 4x or faster CD-ROM drive for installing the software
- A Windows-compliant USB port and shielded USB "AB" cable up to 6.5 feet (2 meters) long. Using an improperly shielded USB cable may cause the Epson Stylus CX9400Fax Series to malfunction.
- An Apple Macintosh with a PowerPC or Intel processor
- Macintosh OS X 10.2.8, 10.3.9 to 10.4.x or later
- 256MB RAM (512MB recommended)
- A USB port and a shielded USB "AB" cable up to 6.5 feet (2 meters) long. Using an improperly shielded USB cable may cause the Epson Stylus CX9400Fax Series to malfunction.
May 25, 2008 | Epson Stylus CX9400 Photo Printer
Suporting for macintosh
See first the label package of your printer. There you can read all OS compatibility issues. If macintosh OS included on it, then you can. Insert the CD driver unto your CDrom, locate the driver Compatible with your system then double click it and thats it...
Mar 19, 2008 | Canon LASER SHOT LBP-5200 Printer
JVC Everio GZ-MG145 backup on mac - files are .mod
The software iVerio might help you. It transfers and converts automatically all your videos from your HDD camcorder.
Have a look on the site http://www.convertmod.com
Feb 21, 2008 | JVC Everio G Camcorder
Sony Ericsson K800i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
