Question about Protron PD-DVR100 DVD Recorder
Pressed the progressive scan button during set up.
I now have a black and white screen and can not reset the unit. I have tried pressing and holding the enter button but it does not work. The unit face reads either internal or initial (not sure). I have tried unplugging the unit for a period of time and it still comes back the same. I have no way to open the disc drawer either. Help
Mpaul
  • 1 more comment
  • terpfan Jan 06, 2008
    I set mine up today and made the same "fatal" mistake. I spoke to "tech support" 3 different times with no luck. After the third call he told me it was "simple fix" but I had to call a "senior tech" on Monday after 1 PM Eastern time. If it was so simple to fix why couldn't he fix it? What a joke! DOes anyone out there know how to fix this problem?
  • coachmrpaul Jan 06, 2008
    please let me know also how to fix this problem after you talk with a senior tech.
  • IndigoHawk Jan 21, 2008
    Pressed progressive instead of interlace in the set up menu and now can't do anything. Set up button doesn't work. I have turned it on and off and unplugged it. I can't read what the display says.
Well, I left it unplugged all night. As soon as I got home, I called tech support, thinking I would be on hold for awhile. I plugged it in and turned it on and hadn't even gotten to the TV to turn it on when a guy came on the line.
He told me to press P.Scan on the remote. As soon as everything was turned on, I had the usual Protron screen. I don't know if it was the P.Scan button or the unplugged all night. He thought having it unplugged was the solution.
So I guess I just didn't leave it unplugged long enough when I tried that last night.
Posted on Jan 21, 2008
I set mine up today and made the same "fatal" mistake. I spoke to "tech support" 3 different times with no luck. After the third call he told me it was "simple fix" but I had to call a "senior tech" on Monday after 1 PM Eastern time. If it was so simple to fix why couldn't he fix it? What a joke! Does anyone out there know how to fix this problem?
Posted on Jan 06, 2008
I want to set up my dav-fr10w to 'interlace' option so i can play the dvd's on my tv, but it's set to 'progressive' right now and the instruction manual doesn't give the specific information to change it....
To cancel Progressive scan output or to change output to interlace signal format, follow these steps..
1- Select DVD by pressing Function button on unit.
2- While holding down |<< (review) button, press Function button on unit.
This will change output signal to interlace/ composite video output from yellow pin/ S-Video.
Hope this info will help you.
Thanks.
Feb 05, 2010 | Sony DAV-FR10W System
Turned progressive scan on, can i turn it off without being able
Try these methods for resetting the scan on your dvd."To reset the VIDEO OUTPUT, turn Off the player, turn back On, open the disc tray and press and hold the Stop button on the player for 10 seconds to reset the scan mode." The Reset procedure doesn't seem to work on all versions but you can sometimes get a usable B&W picture allowing you to get to the menu and change the settings by connecting the composite video input of your display to the Red Pr/Cr or Green Y component output jacks on the rear of the cabinet.
You can also go into the Menu and set it blind with the following key presses on the Remote:
1. With the unit Stopped, press Setup.
2. Press Enter.
3. Press the Down Arrow 3 times.
4. Press the Right Arrow Once.
5. Press Enter. Hope this helps you with your problem
Apr 14, 2009 | Cyberhome CH-DVD 300 DVD Player
Side BY Side Picture On TV Black And White
Try holding the stop button and the DVD dubbing button at the same time and waiting about 3 seconds. I had to do this twice, but it solved my problem.
Feb 27, 2009 | Panasonic DMR-ES40V DVD-Video Recorder
DVD recorder: Changed the settings, now
we could go through the setting like, you can see the monitor. using the remote do the following steps:
Step 1. press set up button.
Step 2. press down arrow once. ( playback)
Step 3. press OK.
Step 4. press down arrow once. (video (selection))
Step 5. press OK. (progressive scan)
Step 6. press OK, again.
Step 7. press down arrow once. (progressive scan off)
Step 8. press OK
you have now turned progressive scan off.
Dec 19, 2007 | Philips Magnavox MWR10D6 DVD Recorder
How do you take progressive scan off
eject the tray and press the stop button for 5 - 10 seconds...if not stop then try pause button
Nov 17, 2007 | TruTech TT320
SD-K530SU - Turning Off Progressive Scan Mode
Once the setting for Progressive Scan output is entered,
an image will only be visible on a Progressive Scan compatible
TV or monitor. If you set Progressive Scan to On in
error, you must reset the unit. Pointing the remote at the
player, press the STOP (x) button to stop any disc that is
playing. Next, press the STOP (x) button again and hold it
for five seconds before releasing it. The video output will
be restored to the standard setting, and a picture will once
again be visible on a conventional analog TV or monitor.
Nov 06, 2007 | Insignia NS-DVDR1 DVD Recorder
How to reset recorder
The solution to hold the pause button for 5 seconds is a winner. Just make sure you press the DVD button first. This doesn't work in VCR mode. This button is on the actual unit, NOT the remote. Thanks for this help.
Apr 18, 2007 | Sony RDR-VX500 DVD Recorder/VCR
Stuck in progressive scan mode
You need to be sure to remove the discs from the disc changer and close the disc changer. Make sure that your TV is on the Blue Screen and it should say " Progressive Scan Mode" Press and hold the stop button on the unit....not the remote for 5 seconds or more and it should reset. However, if your TV is a Progressive Scan compatible TV, you may need to refer to the user guide for the TV as well....Many newer TVs Use a Progressive Scan Setup, but this solution should still work for you. Make sure all discs are removed FIRST!!!
Aug 29, 2006 | NexxTech ESDVD100 System
Progressive Scan
SOLUTION #1
you'll need to reset. press stop to stop any playing disc, and press stop again holding it for 5 seconds to reset the system.
SOLUTION #2
works with remote only
SOULTION #3
While Disc is Running,
By using remote control,
Press Stop Button once to stop the disc (Stop in Memory Mode)
Press Stop Button once again to go into Full Stop
Then, Press & Hold Stop Button for 5 Second or So.
GOOD LUCK!
koreanainusa
Jan 21, 2006 | Zenith XBS444 System
PROGRESSIVE SCAN STILL ON- BLUE SCREEN ONLY
Cause: DVD+VCR was turned off while setting the Progressive scan mode. Correction: Keep pressing the STOP button for more than 5 seconds.
Oct 17, 2005 | Zenith XBV443 DVD Player/VCR
Protron PD-DVR100 DVD Recorder Logo
59 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
