Question about Polaroid i733LP Digital Camera
Casio Exilim ex-z700 - lens wont open
I recently dropped my camera and when picking it up spilt coke on it, it continued to work for a few days after then the lens wouldnt open properly, leaving the focus blurred. i can still see all the pics and the motor is still working, ie its still trying to push the lens out. i think it might just be sticky inside from the coke causing the jam. any ideas on how to open it up for cleaning with out wrecking it completely? unfortunately im in cairns and the nearest repair shop i have been told is brisbane over 1000km away so i need to try it myself. thanks for you help. my lens wont open.. what should i do??? please help.. thank you..
  • 667 Answers
Unfortunately, cola in a camera of any kind is almost always fatal to the camera. The sugar residue with eat away at the plastic and electrical connections. Water is the only thing that will clean the soda (cola) from the camera, (also fatal to cameras). Removing the covers to the camera would give you better access to the damaged areas. I believe they used tri-head screws on the case screws. A proper sized flat blade screw driver and a bit of muscle will get theses screws out. Remove the battery as soon as possible. It is possible to flush or soak cameras with water, but you must dry them out quickly and throughly, best with clean compressed air. I wish you luck
Posted on Dec 26, 2007
2 Suggested Answers
jackboy
  • 2985 Answers
SOURCE: Casio Exilim ex-z700 - lens wont open
Chances are you are not going to succeed. Water dissolves Coke but Kills cameras. Dropping them does the lens drive mechanism no good at all. Well now you are in a rock and a hard place. 1st thing to do is to go and buy the next camera. Then remove batteries and memory card from the existing camera and wet a tissue and wrap it around the lens barrel and let it stand face down for a couple of hours. Then find a poly bog. and in it put some salt or uncooked rice wrapped in a cloth[hanky?] Put hanky and camera in the bag close tight shut for a day. The idea is to draw out the moisture But I reckon you will need that new camera. As for a repair -forget it - these things don't get repaired
Posted on Aug 06, 2007
Casio exilim EX-Z700 lense won't open to take pictures
Hi there and thanks for coming to FixYa.
90 percent of the time, it's dirt, sand or grit that has gotten into the lens mechanism preventing it from opening properly. Try this:
Take an air compressor if you have one, or maybe you can use a friends, anyway, put the nozzle up to the camera and run it around the space between the lens and the camera to clean out any dirt or yuk that may have gotten in there. Best of luck. Leave me a comment if you have any other questions.
Rob
Feb 24, 2009 | Casio Exilim Zoom EX-Z700 Digital Camera
Lens Problem
Hi Kento,
Thanks for accurate description, the problem is cristal clear.
As often happens the lens had been damaged by the shock.
All you can do is trying gently to push the lens inside with your finger while turning camera on and off.
This will probably not work, as lens gears are bent and damaged.
The whole lens barrel must be taken apart and remounted. Probably some part need replacement.
If it is still under guaranty it wont be easy get this kind of repair covered, only way to cover it is if the camera came like this in package, I don't think you can get away with it.
Sep 14, 2008 | Casio Exilim Zoom EX-Z700 Digital Camera
CASIO EXILIM EX-Z700 Lens Error
The only way to fix a lens error is to send it into repairs. Call them at 800-706-2534 option 2 and they will tell you the closest place to send it to.
Casio exilimg ez
No, if it's been dropped then the only thing that we can do is send it in to have it fixed because what's happened it that the lens has sustained damage and needs to be fixed. Please call 8007062534 and chose ext 2 and they will tell you where to send it. Thanks. ;)
Jul 27, 2008 | Casio Exilim Zoom EX-Z700 Digital Camera
Len
camera lens has problem.
need repair lens
mydc digital camera reapir
Jun 05, 2008 | Casio Exilim Zoom EX-Z700 Digital Camera
White Lines and blurry Pictures
If the photo shoot out show white , the obscure (quality variation), and even horizontal line ( white lines), and so on over-exposure cases, even if the use of anti-tremor, set to default values are invalid, because the camera shutter fault.
Can't repair by yourself.
It's need repair camera machine shutter.
more detail CASIO Exilim EX-Z700 overexposure
Mar 23, 2008 | Casio Exilim Zoom EX-Z700 Digital Camera
Casio ex-z700
Your lens has sustained damage and needs to be sent in to repairs.
Jan 06, 2008 | Casio Exilim Zoom EX-Z700 Digital Camera
Aug 06, 2007 | Casio Exilim Zoom EX-Z700 Digital Camera
Polaroid i733LP Digital Camera Logo
47 people viewed this question
Top Polaroid Cameras Experts
Steven Wander
Steven Wander
Marvin
Marvin
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
