Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
Inserting needle on old singer machine
Help me thread this maching please
does the flat part of the needle face the left or right?
where does the tread come out of the bobbin?
thank you
please email back to dmterry@aol.com
the machine is an old singer sewing machine about 40 to 50 yrs old
  • 255 Answers
Hi Terry--
If your machine is 40-50 years old, it might be a Singer Featherweight portable. (If it is, you have one of the very best machines ever made!) On the Featherweights, the flat of the needle faces left (and the needle is threaded from right to left). The bobbin goes in a bobbin case; you'll see a small notch when you look down on the bobbin in the case. That's where the thread goes. I'll email you direct with more information.
Lookingpast
Posted on Jan 11, 2008
My sewing machine singer 7256 giving me a problem causing my fabric underside stitches bird nesting and suddenly the bobbin case comes out from its place and thread strangles and stuck, Why?
try changing the needle-- Correct needle insertion is mandatory for proper use of your sewing machine.
Raise the needle bar to the highest point, then loosen the needle clamp screw to remove the old needle.
Place the new needle in the needle clamp with the flat side of the needle facing the back, (round needle, the groove in the needle should face away from the shaft).
Push the needle all the way up as far as it will go. Then tighten the needle clamp screw.
rethread the machine top & bobbin
make sure the thread has not come off the thread take up lever
also check the top thread tension
do you have a manual?
Jun 04, 2012 | Singer Sewing Machines
Singer ultralock 14u64a jumbles thead on bottom
rethread the top thread-- Correct needle insertion is mandatory for proper use of your sewing machine.
also check the bobbin to make sure that it's threaded correctly
& inserted correctly into the bobbin case
Jun 03, 2012 | Singer Sewing Machines
My singer is not dragin thread from eather top or bottom please help
Download a free manual at www.singerco.com under customer service because you need to rethread totally, Once you have rethreaded it, try pulling on the top thread with the presser foot up, it should pull smoothly, now put the presser foot down, pull top thead again, it should barely move. This should seat the thread in the tension discs. Also, check that your needle is inserted right, flat side facing the rear of the machine. Good luck
Dec 06, 2010 | Singer 7436 - INGENUITY
I have a singer machine and I am trying to thread the bobbin but the thread from the needle won't catch it no matter what I do.
Have you inserted a new needle? If so, is it inserted right? Flat side facing the rear of your machine. Those are usually the problems, over that it means take it in for repair.
Nov 01, 2010 | Sewing Machines
I have an old singer sewing machine 401A. The top thread/needle won't pick up the bottom bobbin thread when it sews. What do I do?
You can download a manual for $10 at www.sewingmanuals.com and it should help you. A couple of suggestions though, is your needle inserted correctly? Flat side facing the rear of the machine, fresh needle? Threaded correctly on top and bobbin area? Is your thread good not too old and the same type in bobbin and top? Did you leave a long enough tail in the bobbin thread? 3-4 inches which you hold with your left hand. Is the thread in the bobbin unwinding the right way? Are you turning the handwheel towards you, not away from you at least two revolutions or until you see the thread loop? Try these suggestions, and I am sure one will work unless your timing is off and it needs professional service.
Sep 20, 2010 | Singer Sewing Machines
Needle won't chatch bobbin thread after having to change needle due to it breaking
Make sure that you have it inserted with the flat side facing away from you. And your bobbin thread running the right way.
Sep 12, 2010 | Singer 7442 Mechanical Sewing Machine
Seems to be out of time will not pick up the thread from the bobbin
Hi. This may sound silly, but check to make sure that the needle is inserted correctly. All needles have a flat side and that side needs to face a particular direction, depending on your machine. In my experience, most modern machines need that the flat side of the needle is facing away from you, toward the rear. Unless the flat side is facing the correct way, the top thread will not pick up the bobbin thread.
Another thing to check is that your needle isn't bent, but in most cases the needle is inserted wrong.
Happy Sewing,
Robbie
Apr 15, 2010 | Singer 3116 Simple
I'm not very good with sewing machines and I can't seem to get the bobbin to hook up with the thread coming in from the top. is it possible for me to see a simple (!) diagram? The machine is from 1927....
Hi Rebecca. Yes, I imagine your machine is very beautiful. I have several from that era and they are just gorgeous.
It is most likely that the reason your top thread isn't able to pull the bobbin thread up is that the needle is in wrong. Every needle shank has a flat side and this needs to be installed so that it faces a particular way. It has to do with the mechanics of how a stitch is formed. On most modern machines it's my experience that that the flat side of the needle shank faces the rear, away from the user, but with older machines the flat side could face to the right or to the left. (This is also related to how you thread the needle, from front to back (most modern machines), from right to left (my Singer Featherweights), or from left to right (my White model 844 and Elgin treadle machine).
Do you have a manual for your machine? If you do, take a look at how it says to insert the needle in the machine and thread it. If you don't, may I suggest that you get one? I've found that Relics (http://www.tias.com/stores/relics/) has a lot of manuals for these old beauties.
You can also experiment, changing the direction of the flat side of the needle shank (and how you thread it) until you find a combination that works.
Let me know if this solves your problem, ok? For more information about your machine, go to http://www.ismacs.net/home.html, the International Sewing Machines Collectors Society. I also have some links at my blog--www.robbiesews.blogspot.com
Happy Sewing!
Robbie
Mar 18, 2010 | Sewing Machines
Bobbin problem
Hi. What a great daughter you are! Almost always, this problem is because the needle isn't in right (an easy mistake to make). The needle shank has a flat side, which needs to be facing a certain way. With almost all new machines (I hate to say all new machines), the flat side of the needle has to face the rear of the machine. The needle would then be threaded from front to back. (There was a lot more variation in older machines, but nearly all of them now have the flat side of the needle shank facing away from the seamstress.) A couple of other things can also prevent the bobbin thread from being pulled up, like if the needle is bent or dull or if the machine isn't threaded correctly, but in my experience, it's most likely the needle.
Please let me know if this solves the problem, ok?
Happy Sewing!
Robbie
Feb 26, 2010 | Singer Sewing Machines
Machine will not pick up the bobbin thread.
if your machine's needle threads from front to back, make sure that the flat part of the needle shank points to the rear of the machine. If it threads from left to right, the flat side should face right, etc.
Jun 08, 2009 | Singer 2639
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
297 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
