Question about Intel D845EPI (INTELKD845EPILPAK10) Motherboard
Intel D845EPI/D845GVSR MB problem
I have an emachines T2894 PC with an Intel D845EPI/D845GVSR motherboard that I'm trying to fix for a friend. He complained that it would not boot. After several tests I found the hard disk to be seriously corrupted. (I reformatted it on another PC and was able to read and write to it just fine). Upon trying to rebuild the emachines system with Windows XP, I found that I would always get the Blue Screen of death at the point where the install was apparently trying to access the harddrive (or at least that's what it seemed). I "thought" mabye there was an IDE controller problem since the CD and HD are on different controllers, so I disabled one and had them both share the CD IDE controler. Still...the same BSOD occurred. Any idea what the problem might be? I could buy another motherboard, but if it's just a capacitor or other component problem, I'd just as soon fix what I have. Thanks!
  • dj1957 Dec 26, 2007
    One other data point. I tried the XP install with NO hard disk attached and got the same BSOD behavior. (I knew the install would fail, but thought it might give an error about missing hard drive or something like that. This is what made me wonder about the IDE controller)
    Would you expect that to happen with the boot sector issue you mentioned above?
    Thanks,
    /Derrick
  • 3 Answers
Your d845gvsr motherboard bios chip need to reprogramme with eprom programmer your bios programe currupted
Posted on Sep 01, 2010
    Problem Solver:
  • 17 Answers
Sound like a bad memory issue. Try a with new tested memory module. Had this issue many times....
Posted on Feb 12, 2008
I had a machine with same problem it had a celeron d 2.93 processor I replaced with a pentium 4 2.8 now the computer works fine I put that same processor in a different machine and is also working fine................
Posted on Feb 03, 2008
I have intel origional D845EPI / D845GVSR Motherboard.
when i start the board without RAM. than i heared sound of of ram problem.
but after install the RAM i start the board, then i didn't listen any sound but the system is running.
Posted on Dec 29, 2007
  • 883 Answers
If you can get past the POST properly and see the drive size, nothing is wrong with the drive hardware. I think XP is seeing a previous boot sector install so try first to fdisk, format and system boot the drive. This should remove any boot sector "shadows".
Posted on Dec 26, 2007
  • Marty marty Dec 27, 2007
    get to basics first. Does the HD appear as a valid object when viewing the POST screen? now boot minimal DOS just to read and write HD. does it appear normal?
    then, what exactly does the BSOD print on screen? or no print? since you mentioned "the same BSOD behavior. ", does it ever include text with it?
Hi, I need Intel mother board Audio video & all drives for a D845epi / D845gvsr. Thanks Arjun
All the drivers for you motherboard can be downloaded from the following link:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+845+Chipset+Family+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D845EPI
Nov 16, 2010 | Intel D845EPI (INTELKD845EPILPAK10)...
E-Machine PC with only a green LED on MB on Boot attempt
We have repaired many of these systems. The board was damaged when the power supply shorted. You can get replacement motherboards at www.barebonekit.net click on the link on the left side for motherboards and look for Emachine.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 16, 2009 | Intel D845EPI (INTELKD845EPILPAK10)...
I have a emachine PC. PowerSupply blew up. changed it still down
try to remove the memory and put it back again make sure put it fit and correctly
May 28, 2009 | Intel D845EPI (INTELKD845EPILPAK10)...
No power up om motherboard
power supply died. MB might have been killed as well
Apr 06, 2009 | EliteGroup 848P-A Motherboard
Intel D845EPI/D845GVSR won't power up.
oon mobo thers pins that go to front finsd ones says pw stick it in eash way try new switch also ove rthose 2 pins ok to get itto light up could be bad mobo
Oct 07, 2008 | Intel D845EPI (INTELKD845EPILPAK10)...
Emachine T2742 MB D845EPI/D845GVSR
The diagram for that 9 pin J9G1 is alongside the CMOS battery.
Dec 25, 2007 | Intel Desktop Board D845EPIL Motherboard
My Intel D845EPI/D845GVSR MB processor does not boot up. No BIOS or POST is dispayed on the screen
Try to use working processor from your friend, If the problem still the same possible your motherboard has been damage. Ask for a warranty for the supplier.
Don't rate me Inappropriate if you don't like my solution or rate me SOLVED if this solution solved your problem. Thanks
Nov 23, 2007 | Intel D845EPI (INTELKD845EPILPAK10)...
Intel D845EPI (INTELKD845EPILPAK10) Motherboard Logo
424 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
