Canon PowerShot A720 IS Digital Camera
Problem for Canon PowerShot A720 IS Digital Camera
I have a lens error. It won't open when the on
By salinadelmar on Oct 11, 2009
I have a lens error. It won't open when the on button is pressed
Solution #1
posted on Oct 13, 2009
Not Rated)
BillB-SA
Rank: Guru  Canon Cameras & Camcorders  Expert
Rating: 85%, 565 votes
If you have recently dropped the camera you likely damaged the lens tube (housing) or jarred the zoom mechanism off of its track -- both problems that will require professional repair. If the camera has not suffered a drop, your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, chances are that your batteries need to be replaced because they're just too worn to properly power the camera.
Was this helpful?
Yes
No
Popular Solutions for Canon PowerShot A720 IS
Questions and Unsolved Problems for Canon PowerShot A720 IS
Do you recommend Canon PowerShot A720 IS Digital Camera?
Answer
Answer
In record (auto, portrait, etc.) mode, the screen is black and the lens doesn't retract all the way.... (More)
Answer
I have a water spot on the inside of a Canon A720 IS lens. Is there anyway to get inside the lens... (More)
Answer
The flash works intermittently. I've notice the camera does not auto focus when that happens.
Answer
although,i put anew batteries,my cannon A720 wont turn on
Describe your Digital Cameras problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Digital Camera Experts
Top Camera & Camcorder Repairmen
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
