Question about Samsung HP-R5072 50 in. Plasma HDTV
Samsung I have samsung 42Q7 Plasma TV, on the left side of the plan I have noisy pixels that seem to flash on and off randomly. the problem is worse with bright and blue images and disappears with reds and blacks. Any idea what's wrong? Ray from Moscow. Russia
  • 261 Answers
I have posted this in other areas and it appears to be a diffusion problem meaning the panel needs an electrical adjustment and can be done by a technician or you if you dare. Depends on how handy with electronics you are. But there are some adjustments you can do to minimize or remove these red or blue pixels firing randomly. Try adjusting V-SUS, V-SET, and check all other ones. VE, VS, VA, and see what happens. Write all voltages down first then go tweeking. I do have a bulletin here that states exactly what to do, I just have to find it. Let me know if you have any luck with this procedure first. Oh Yea, make sure you use the internal generator, the wipe screen from black to white so as to see both at the same time while adjusting the picture. It helps to have it on the stand when doing this procedure. Let me know if i can be of anymore assistance. Cheers. Jay
Posted on Jan 31, 2008
Noisy jumping red pixels in the upper right corner
You are right, this is caused by a faulty power supply that gives you bad voltages. So it can get worse in time.
Oct 10, 2014 | Samsung PN50B860 Plasma TV
I have whats called "red
You will need a small philips head screw driver and a Digital Volt Meter for this.
Unplug your set and take the back off
Plug the set back in and turn the set on
Now with your meter find the test point on the power supply that says VS. If you cannot find it, you can measure it at the plug of the board.
Make the sure the voltage matches the sticker that is on the panel. It will say VS. If it does not match, find the VS adjustment pod and adjust the voltage to match the sticker. If the voltage already matches, it is safe to raise 10 to 15 volts. If the picture starts to clear up, you are going the right way, if it gets worse, you need to adjust the other way. If it doesn't change at all, then odds are you have a bad panel.
May 23, 2011 | Samsung PS42S5H 42 in. HD-Ready Plasma...
The model is Samsung LN-T4661F. It power cycles at least 3 times every time I turn it on. Once the screen comes on there are, most times, pink pixels randomly all over the screen. I have to turn it off...
good day .maybe theres a defect in the board causing the screen changes abnormally. maybe the screen module is defective. just consult that problem to samsung service center to fix your problem.
Jun 24, 2010 | Samsung LN-T4661F 46 in. LCD HDTV
Samsung HPR4272X/XAA has 2 black bars going from top to bottom.
I really do not know there is the "Stuck Pixel Fixer programs" I think that Program Breakdown another IC. For this issue is absolutely the Plasma display panel have problem. You shall exchange it.
Apr 17, 2010 | Samsung HP-R4272 42 in. Plasma HDTV
Samsung HD tv help
Is it a Plasma Television? I recently had a customer have the same issue with a 2 year old model Samsung 50" plasma TV. In his case one Of the computer panels failed. He didn't have a service plan and the warrenty was out, so i directed him to Samsungs help line. They inturn directed him to a authorized repair center. Repairs were roughly $800. Thats a possibility but it may not be the same as your issue. Try leaving your TV running for a little while when it has the issue, and see if it eventually goes away. Some older plasma models have started to require a warm up time for the pixel cells. This has been a down fall of plasma that for the most part no longer exists on newer models.
I hope eveything works out.
Have a great day
Mar 22, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Samsung TV flickering image
You seem to have what is called error diffusion. Either call samsung about it and arange service or do it on What kind of warranty do you have? Depending on your date of purchase you might be able to get samsung to help cover it or pay for it all.
Mar 09, 2008 | Samsung SP-S4243 Television
Bright blue pixels on left side of plasma screen
try to adjust Vs & Vsc within 5% of their spec on the power supply board when you notice the problem.
Jan 01, 2008 | Televison & Video
Samsung plasma PS42D5S
You need to adjust the panel voltages, adjust the VS voltage to around 186 volts, if that doesn't change it then adjust the V-Scan voltage down, turn the unit on and apply a video source to it, and while adjusting the voltages look at the screen and you should be abe to watch the video noise fade out.
Dec 14, 2006 | Samsung PS42P2S 42 in. Plasma Television
Samsung HP-R5072 50 in. Plasma HDTV Logo
115 people viewed this question
Jerry Greenberg
Jerry Greenberg
