Digitech RP250 Digitech RP 250 showing HAI 105 at the display screen and i can't do enything it looks like is frozen
  • 1,512 Answers
You can download an instruction manual for free from here... I am sure that it will help you.
or ask your question of this forum... i am sure they can help :)
Posted on Jan 12, 2008
You need to factory reset your pedal, it will tell you how to do so in the manual
Posted on Mar 09, 2008
  • Vic Kulick
    Vic Kulick Oct 24, 2011
    picked one up on ebay (rp250) hisses a bit, doesn't pick up any guitar, faintly hear drums when drums actuated. any ideas?
My Wawa pedal went out on my Digitech RP 500 how could I make it work again
This might work - Hold the bypass switch for five seconds and follow the on screen instructions to calibrate the expression pedal. If that doesn't work you could also try doing a back up and then a factory reset. You may also consider a separate wah pedal. There are many recommendations at:
What Is The Best Wah Pedal For The Money Our Answer For You
Jan 07, 2015 | DIGITECH RP500 Guitar Multi-Effects Pedal
Cant here any sound very low digitech rp250
Check to make sure the amp/mixer button is pushed "in" when using headphones.
Apr 01, 2013 | Music
My digitech rp 500 has power supply but it won't
Make sure you have the OFFICIAL Digitech power adapter. Universal adapters or those for MOST other pedals will NOT work... things may light up but you will NOT get audio. This unit requires an adapter supplying 9 VAC (not DC) at about 1 amp. These AC output adapters are not very common and people get the units without an adapter and try using universal adapters and they do not work. An AC adapter is used by Digitech so they can generate both plus and minus voltages internally. I don't know what your utility power voltage is in Cebu, so you need to get an adapter for your voltage that will give 9 VAC output and fit the power jack on the unit.
Sep 15, 2011 | Digidesign Digitech Control 2 pedal for...
I need to know how to restore factory settings on digitech RP RP-90
Here is the link to your manual if you don't have one: Page 34 tells you how and don't forget to calibrate the expression pedal. Page 35 tells you how. Hope this helped.
Nov 09, 2010 | Music
My digitech rp 250 guitar processor seems to be frozen. everything is all lit up and its all zeros in the display screen.
Here is a link you will need to the latest firmware update: Make sure you follow all directions carefully. Look in your owners manual at how to reset the pedal. If all this fails contact support at their website. Also you didn't mention if you were using a Mac or a P.C. so I gave you the P.C. link. The Mac link can also be found there. Hope this helps.
Sep 01, 2010 | Audio Players & Recorders
Pedal Malfunction RP250
You will have to recalibrate your pedal. If you don't have your manual anymore try going to The procedure for the RP350 so that you don't lose your presets is : 1. Press and hold the UP/DOWN Footswitches until PDLCAL appears in the display (BYPASS,TUNER and EXIT will be displayed before PDLCAL is accessed after about 5 seconds). 2. When the display prompts you with TOEDN, rock the EXPESSION PEDAL forward (toe down) and press either FOOTSWITCH.
3. When the Display prompts you with TOE UP, rock the EXPRESSION PEDAL back (toe up ) and press either FOOTSWITCH.
4. The Display now prompts you to calibrate the V-Switch sensitivity (VSWxxx), where xxx is the current V-switch threshold. Rock the EXPRESSION PEDAL forward and press firmly on the toe once to turn the V-switch on (WAH ON) and again to turn the V-switch off (WAH OFF).
5. If the V-switch is too sensitive, press the right UP FOOTSWITCH to raise the threshold (range is 0-2000. Keep testing the V-switch sensitivity and adjust the threshold until it only engages when you want it to ( too sensitive a setting will lead to the V-switch falsely triggering on or off when using the Expression Pedal).
6.When the V-switch sensitivity is set to your satisfaction, press both UP/DOWN FOOTSWITCHES simultaneously to exit. NOTE: IF the DISPLAY shows ERROR, an error has occurred and steps 2 through 5 should be repeated. Sorry fo the caps but thats how the instructions appear in my sons manual. You can also dowload the manual and an editor librarian (for the 350 at least) at their site. They might even have an update for your pedal. Hope this helps. Keep playing.
Jul 09, 2009 | Music
Digitech RP 90 foot switch is not working
I removed the back cover, unscrewed the two (of 4) screws holding down the circuit board, replaced them again, and it worked fine.
Jan 11, 2009 | Music
Digitech RP-5 Effects unit
for the RP-5, this is the procedure that worked for me: 1. hold the preset up button 2. apply power to unit 3. release preset button 4. press value up button
Jun 29, 2008 | Audio Players & Recorders
1,775 people viewed this question
