Question about Maytag MAV7600 Top Load Washer
Maytag MAV7600 - loud noise on spin cycle
I have a maytag mav7600 that I purchased in 2001 that suddenly started making a very loud grinding noise when it starts in the spin cycle. I did remove all the clothes and just ran it empty to see if the tub would spin at all and it does but the noise continues. I assume it is something with the transmission but hopefully it is not the entire unit. Could it be the thrust washer assembly?
Also, if you would please explain how to get the front cover off that would be helpful!
Thanks in advance, Tod.
  • twieder Dec 27, 2007
    Sagacious, thank you for the help. You were correct. I pulled the hose from the tub and a piece of wire was stuck in the pump. I will still have to replace the pump due to the blades being damaged but it works good enough now to allow us to continue to have clean clothes.
  • 283 Answers
It's more likely something caught in the pump or bad pump. Remove the belt under the machine and check the pump pulley for noise.
Posted on Dec 26, 2007
The washing machine started making a grinding noise during wash cycle (minor) and a much louder grinding noise during the spin cycle. Is this a bearing? and is it replacable? Maytag MAV7600
sounds like a bearing... although it could be the water pump... water pump is an easy fix... bearing is not an easy fix... take the belt off the bottom of the pump (under the machine) and see if it spins freely by turning it w/ your hand... or if it seems really stiff... if it looks good then it's def. your bearing...
Jan 15, 2010 | Maytag MAV7600 Top Load Washer
I have a 2002 Maytag MAV7600 washer. Problem
Honestly get a new washer if you got 7 years out of an mav your ahead of the game worst machine maytag ever made, you need a timer but i wouldnt invest the time or money on an MAV
Jul 07, 2009 | Washing Machines
Maytag mav8600aww grinding when agitate
post your email i will send you the service manual
Jan 26, 2008 | Maytag MAV7600 Top Load Washer
All my washer will do is spin no matter were In set it
The timer contacts have welded together. Replace the timer.
Jan 11, 2008 | Maytag MAV7600 Top Load Washer
MAyatg MAV7600 BGN Top Load Washer Problem
The screeching sound could be the drain pump or something stuck between the bowls. Try turning the inner bowl by hand and listen for the noise. There should be a position on the timer, just before the spin, that allows the machine to drain before it starts to spin. Try to find the right spot and listen for the noise when only the drain pump is running. Good Luck.
Oct 31, 2007 | Maytag MAV7600 Top Load Washer
lubricate the motor plate A solved rating is great motivation to continue giving expert advise........
Oct 03, 2007 | Maytag MAV7600 Top Load Washer
Atlantis MAV7700
Got to take front cover of washer to get  at the screws to take out... to get lid to lift up
Sep 15, 2007 | Maytag MAV7600 Top Load Washer
Maytag Atlantis MAV7600 AWW
Normal brake sound in dry locations. Do you live in Arizona?
Feb 08, 2007 | Maytag LAT3600A Top Load Washer
Maytag MAV7600 Top Load Washer Logo
438 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
