Question about Nikon D40 Digital Camera with G-II 18-55mm Lens
Pop-up flash When I go to take a photo the flash pops up but doesn't fire.
  • 1 more comment
  • canedio Jan 03, 2008
    same problem here! suddenly.
    i also did a hard reset (the little squared button under the left side cover), but with no luck.
  • Anonymous Mar 23, 2008
    My D40 has worked awsome and I am serious when I asy I took one photo the flash worked fine then when I went to take another rapid shot ( taking a picture of a toddler) the flash wouldnt go off, it still took the photo but it was so under exposed i had to delete it. Very disappointed considering this happened on Easter Sunday the first Easter my daughter understood about searching for chocolate.
  • jyc_08
    jyc_08 Nov 05, 2012
    My D5100 is a nice camera but now that im going to use it with my friend, the flash pop up is not working even the flash button on the left side of it. Can anyone help me? I'm so desperate so fix it.
    Sniper:
  • 53 Answers
Make sure after popping up the flash, you didn't change the mode into "no flash" mode....an easy way to check is put the flash back down, then proceed to take another photo. If the flash pops up again but did not flash, you have a faulty camera (assuming battery level is at least until the 1/3 mark).
Posted on Dec 29, 2007
5 Suggested Answers
Quack
  • 542 Answers
SOURCE: *istD pop-up flash problem
Not sure if you try fresh Alkaline battery. Try it if you havn't already. Fully charged batteries, how do you know it fully charged? The "charger said so"? Your batteries or charger might give you a fault peak reading. Try fresh battery or AC adepter and go from there.
Posted on Sep 08, 2005
SOURCE: Flash won't fire
If it clicks when the flash is already open, it seems there would be a problem with the flash open sensor. The camera thinks the flash is closed, so it tries to open it again and it refuses to fire, because firing in the closed position would blow the bulb.
Here's a <a href='http://photo.net/bboard/uploaded-file?bboard_upload_id=42254384'>photo of the sensor in a D70</a>. The D40 flash is a bit different, but if you open it (just unscrew the two little screws in front) you'll recognize the sensor clips. Open and close the flash and see if the make contact when open.
(And DON'T fire the flash when open, or at the very least don't touch anything in there when firing or you'll get zapped.
Posted on Apr 27, 2008
  • 7 Answers
SOURCE: pop up flash nikon D80
I'm not sure of your problem, but if I understand it correctly, the flash does not pop down on its own, you just push it down and it locks down.
Posted on Jul 21, 2008
  • 130 Answers
SOURCE: Pop up flash not working
You probably need to change the setting wheel on the top of your camera to either auto or Program (P) to do what you are wanting.
Posted on Jun 14, 2009
Canon Speedlite 580ex ii - won't work with camera
Caroline, you should try to set the camera on "M" and the flash in 2nd curtain flash sync.
Or set flash in ATG wireless IR ETTL Slave modes and pop-up the flash on Canon EOS-70D.
Truly,
atdlee@netzero.com
Feb 08, 2014 | Canon SPEEDLITE 580EX TTL Flash
Flash pops but doesnt fire
Still this is strange. Most of the time when I use the auto setting, I turn the main dial not on the green camera, but on the one between SCENE and the green logo. That prevent the flash to pop up. But still if you want to use the flash it should be possible.
Be aware that some settings the flash can't be used, f.i. when the shutter speed is to high. I would suggest to put al user settings back to standard and try to use the flash again. If it stalls again, try to read the display, if it gives anything of a warning or message.
Jan 18, 2014 | Nikon D5100 Digital Camera with 1855mm...
My nikon D60 and the pop up flash dosent work
the flash pivot on the release side of the flash has a small cylinder that operates the flash up switch. If that cylinder is broken off or the pivot is pushed in so the switch doesn't close, then what you describe happens
pop up the flash and remove the two screws underneath, and you can pry off the cover - gently - to check the switch
Mar 16, 2013 | Nikon D60 Digital Camera
Error 05 flash doesn't pop up
spray a very very small amount of WD40 on the hings of pop up flash (use the thin RED spray tube)
Nov 17, 2012 | Canon EOS 400D / Rebel XTi Digital Camera
Built-in flash does not work even in a MASP mode
This often depends on the shooting mode you are using. It is often on a selection wheel. Say you are in Fireworks mode the flash will not fire. If you get out of a special mode back into normal camera I am pretty sure your flash will not be greyed out.
Jul 20, 2017 | Nikon D3100 Digital Camera
Auto flash wont work
did it pop up automatically or did you pop it manually? if it popped up by itself then the flash unfortunately is probably dead, since on automatic, it won't pop unless it's going to fire. If you popped it manually then - the camera doesn't think that the flash is necessary for the conditions that you're shooting in.
Oct 21, 2009 | Nikon Cameras
The flash on my d40x will no longer fire. the flash pops but nothing else happens! i have tried resetting but to no avail. i first noticed the problem while i was travelling so i couldn't send it off to be...
I do not want to speak down to you. If you pop up the flash and it does not fire it may be the mode. If the camera is in an auto mode and it feels there is NOT enough light to take the photo it will automatically pop up the flash and take the photo using flash. If it is in auto and it pops up the flash and it does not use it you may have a problem.
In most cases the best mode to use is P. In P mode (Programmed Auto) the flash NEVER automatically pops up (I find that very annoying). It will ONLY fire after you pop it up and take a photo. So with the camera in P. Take some photos with the flash down. Then try to take some photos with the flash up. It may also help to have fully charged batteries. Flash circuit uses lots of power for a short time to charge a capacitor. If the battery is too weak to charge the capacitor it will NOT fire the flash. It may have a RED LED or an INDICATOR in the View Finder that tells you the FLASH is READY.
Dec 01, 2017 | Nikon Cameras
Built-in flash does not fire off
Not really a solution, and about 3 years late :) my EOS400D also developed the same problem (however it was also coincidence that I had just updated to Firmware 1.1.1 (from 1.0.4), but basically the flash would pop up, but wouldn't fire (so not the standard problem with the microswitches), I found with a bit of forum searching that if you hold the flash down to almost clicking it in and then shoot it does actually fire. I am going to see how much it costs to get this fixed and will post what the actual fault is if I can understand the repairman.
Mar 29, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Flash
This is the AF Assist feature. If you don't have a hot-shoe flash mounted, but you do have the pop-up flash raised, the camera will strobe the pop-up flash in low-light situations to provide illumination for the auto-focus to work. You can disable it by turning off the AF ILLUMINATOR option in the "Wrench 1" settings menu.
Mar 09, 2008 | Olympus EVOLT E-500 Digital Camera
Canon 580ex "pops" in a baad way
Buy the flash tube and the cap., if they are bad.
It is not that hard, I can help.
Alexander
atdlee@netzero.com
Sep 04, 2007 | Canon SPEEDLITE 580EX TTL Flash
Nikon D40 Digital Camera with G-II 18-55mm Lens Logo
504 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
