Hi:
The zoom on my camcorder does not respond! - it is stuck and every time when I try to use the Manual Function the "Press the reset button" message appears.
How can I reset the zoom?
THANK YOU!
Hello. The stuck lens assembly is triggering an error condition--and you get the "press reset" to make you reset the internal computer in the cam. Was the unit dropped or did it have some sort of impact--this would cause the internal lens mechanism to become mis-aligned. Also, leaving the cam in a hot car can cause grease(or other lubricants) to flow to movement surfaces, thereby causing a "glue" effect. Look into the lens(cam off) under a bright light and try to determine if the internal lens assembly is crooked. Also, try to see if there is any "wet" area appearing anywhere(especially if the cam was exposed to heat--classic symptom) If the lens assembly is indeed mis-aligned, the cam must be sent to a repair facility. (Also, make sure the battery is fully charged as a weak charge will cause lens jamming(and a whole host of weird phenomenons)---Rick
Unable to install software. I m receiving message "an error occured" while trying to...
(More)
Unable to install software. I m receiving message "an error occured" while trying to install the same..
I bought this used, and it says i need an adapter to upload the videos but i dont have one, i live...
(More)
I bought this used, and it says i need an adapter to upload the videos but i dont have one, i live in canada where can i find one? thanks
I had video cam suite running fine and then another problem occured with my computer so I ran system...
(More)
I had video cam suite running fine and then another problem occured with my computer so I ran system recovery and tried run to video cam suite and I ve followed all of the instructions and and gotten all of the updates for xp home and sp3 and panasonic updates and repeatedly gotten an error that says i must restart to complete uninstall repeatedly. Can anyone help me. I'm not good at doing back to the directory and stuff can you help
