Usb ports How do I find out if my usb ports are usb1 or usb 2?
    Genius:
  • 1,601 Answers
Go into your Device Manager (you didn`t say which OS).
Under USB you should have something like Enhanced Host controller.
That is USB2.
If you haven`t got it, your on USB1.
Normally if you only have USB1, and you plug a USB2 capable
device in, you will be told `this device could perform faster`.
Posted on Dec 26, 2007
I cant install printer usb port is damage
Which USB port Damage because there are two USB port available.
One is Printer USB port or Sec is PC USB port.
If you are say PC USB port not working first you check it USB driver installed or not, or USB connect to motherboard or not. PC there are two side USB available one is front side and sec is back side. You connect only back side, because this USB connect to main board. So you connect only back side. If not working removed driver or installed driver.
Or if you are say printer USB then change cable or port or not solved only change option.
Read More Help.. If you have USB or Network Printer and are having trouble printing and HP Tech Support
Jun 27, 2014 | HP PSC 1315 All-In-One InkJet Printer
Modem name: MMX310G 3G USB Manager At port: COM 23
IMEI: 910532501150347
Please provide the nck code for MMX310G 3G USB Manager
Thanks
sthita_50@yahoo.co.in
Sep 28, 2013 | Computers & Internet
Usb port not working
Printers are particular about which usb port they are plugged into, a virtual printer port is assigned to USB1 in the computer, when you select the printer port for it to use. You may need to plug the printer into each USB port, until you fine the USB port 1 which it works in, remember to always connect it to this same usb port, otherwise it will not work. There is only one USB port number 1.
Apr 10, 2013 | Brother MFC-7340 All-In-One Laser Printer
My USB ports won't work on my gigabyte MA69VM-S2 mobo with win7
Unlikely to be issues with the OS. Have you recently upgraded to Win 7 from Vista or XP? and did the USB ports work with this OS?
Do ALL usb ports fail or is it just one or two and are these the front USB's or rear USBs?
Dec 29, 2010 | Gigabyte GA-MA69VM-S2 (rev. 1.0)...
I have a model m01517 5 port usb hub. It has 2 usb cables to the computer, do I use the blue or black connector? I can only get one port to recognize a device plugged in the other four seem to be dead,...
Not sure I understand this hub either. Looks like only one port is a USB 2.0 port, but here is a snippet from the manual......
This iConcepts USB Hub provides the electronic interface between USB devices and the host, It allows up to five USB devices or Hubs to connect an upstream USB Hub or Host port.
Features
• One USB 2.0 port
• 4 Port USB 1.1 and support high speed (480 mbps) and 4 port full speed (12 mbps) operations.
• The USB 2.0 port can operate both USB 2.0 & 1.1 Devices
• USB 2.0 port supports self powered mode and bus - powered mode, indicated by a powered LED .
• Over current detection and protection
Manual is provided here: http://www.sakar.com/p-1124.aspx?categoryid=182
Sep 09, 2010 | Sakar (M01517) 5-Port USB Hub
The usb port won't work on my acer extensa 4630z laptop
Did you install any Anti virus . Check the USB port for any physical damage. Try connecting a mouse with USB port to check if its working. After all this then the issue remain the same then the USB port needs an replacement.
Regards.
Feb 08, 2010 | Computers & Internet
Why don't my USB ports on my monitor work
1) good USB cable from Monitor USB input port to PC USB port?
2) Check pin 1 of the USB port, you should have 5vdc.
3) Your monitor's USB ports are basically the powered USB hub, but it must be connected to the PC USB port.
Jan 25, 2010 | Dell E176FP 17" LCD Monitor
I DON'T KNOW WHERE TO PUT THE USB CONNECTOR
If you only have one USB connector then you can purchase an USB hub which may have 4 or more ports (I suggest you get a powered USB hub). Then plug the hub into the computer's USB port and you now have several USB ports.
Jan 04, 2010 | Canon CanoScan 4400F Flatbed Scanner
When I plug a wireless cable into a USB port, the computer tells me that there are High speed USB ports available but does not inform where to find them.
Right-Click on My Computer, Properties, Device Manager, then Click on Universal Serial Bus Controllers, u will see the USB port available on your computer there. Also, at the same time you are doing this, try checking all the USB ports on your computer...most times, the HIGH-Speed USB Ports (USB 2.0) are always seperated from the other USB ports...so try the USB port seperated from others.
In your own case, Acer TravelMate 2303LCi has just 3 USB slots, a PC card slot, modem and network slot. No floppy drive, no TV-out, no IR, no Wi-Fi. So check-out USB Ports, the USB port infront of the Laptop beside the Audio Port and and the Speaker, on the extreme-right is your USB 2.0 High-Speed Port.
Jul 09, 2009 | Acer TravelMate 2303LCi Notebook
USB ports work at 1.1; s/b 2.0
Your computer is functioning correctly.
The USB ports on your laptop are USB1 ports its pard of the hardware.
Your PCMCIA USB 2 card runs at USB 2 speed and therefore when you connect a USB 2 device to this port you will not get this USB message.
Jan 18, 2009 | Lenovo ThinkPad R51e Notebook
Computers & Internet Logo
125 people viewed this question
David Payne
David Payne
