Question about Delphi NAV200 GPS Receiver
No signal on new GPS Delphi
Signal - states no signal
  • 86 Answers
Return it to the store. I got one for Christmas and right out of the box it always said "New Route" and would never give me directions. The one I exchanged it for works perfectly.
Posted on Jan 19, 2008
My Garmin Novi can not find a satellite signal in Florida?
Assuming that your GPS can receive a satellite signal in other states, then it is likely the placement of your GPS in your vehicle. The satellites are in fixed orbit, so as you move southward, their position in the horizon changes relative to you. As a check, turn your GPS on outside of your vehicle with a clear line of sight to the heavens (no trees, buildings, etc.). You should get a satellite signal. If you still do not, then you have a problem with your unit. If you do get a signal outside, then rearrange placement of your GPS inside your vehicle.
Mar 17, 2017 | Garmin GPS
Where can i get an 01 silhouette pcm pinout
PCM pinout diagrams
2001 silverado (Thanks Banker099)
Try this link for page below
wol_error.gifThis image has been resized. Click this bar to view the full image. The original image is sized 799x247 and weights 17KB.connectorc1pcm2001.gif
Powertrain Control Module (PCM) C1 (BLU)
Connector Part Information
• PCM Connector C1 Assembly 12191489
• TPA (BLU) 12176408
• Connector Cover 12191108
Pin
Wire Color
Circuit No.
Function
BLK/WHT
451
Ground
LT GRN
1867
12 Volt Reference
PNK/BLK
1746
Fuel Injector 3 Control
LT GRN/BLK
1745
Fuel Injector 2 Control
5-10
Not Used
11
LT BLU
1876
Knock Sensor 2 Signal
12
DK BLU/WHT
1869
CKP Sensor Signal
13
ORN/BLK
463
Requested Torque Signal
14
ORN/BLK
1061
UART Serial Data [Secondary]
15
DRK BLU/WHT
774
UART Serial Data [Tertiary]
16
Not Used
17
DK BLU
1225
Transmission Fluid Pressure Switch Signal B
18
RED
1226
Transmission Fluid Pressure Switch Signal C
19
PNK
439
Ignition 1 Voltage
20
ORN
440
Battery Positive Voltage
21
YEL
1868
Low Reference
22
Not Used
23
PPL
719
Low Reference
24
Not Used
25
TAN
1671
HO2S Low Signal [- Bank 2 Sensor 1]
25
TAN
413
HO2S Low Reference (Denso Sensors) HO2S Low Signal (Delphi Sensors)
26
TAN
1667
HO2S Low Signal [- Bank 2 Sensor 2]
26
TAN
413
27
Not Used
28
TAN/WHT
1669
HO2S Low Signal [- Bank 1 Sensor 2]
28
TAN
413
29
TAN/WHT
1653
HO2S Low Signal [- Bank 1 Sensor 1]
29
TAN
413
30
LT GRN
1478
Coolant Level Switch Signal
31
Not Used
32
BLK/WHT
771
Transmission Range Switch Signal A
33
PPL
420
TCC Brake Switch Signal
34
WHT
776
Transmission Range Switch Signal P
35
GRA
48
CPP Switch Signal
36
BLK
1744
Injector 1 Control
37
YEL/BLK
846
Injector 6 Control
38
PNK/WHT
1101
Damping Lift/Dive Signal
39
Not Used
40
BLK/WHT
451
Ground
41
BLK
407
Low Reference
41
GRA
720
Low Reference (w/o Delphi HO2S)
42
Not Used
43
RED/BLK
877
Fuel Injector 7 Control
44
LT BLU/BLK
844
Fuel Injector 4 Control
45
GRA
474
5 Volt Reference (FTP Sensor)
46
GRY
474
5 Volt Reference (TPS Sensor)
47
GRY
597
5 Volt Reference (MAP Sensor)
48
GRA
596
5 Volt Reference (EGR Sensor)
49 50
Not Used
51
DK BLU
496
KS [1] Signal
52
Not Used
53
BLK
470
Low Reference
54
BLK
452
Low Reference
55
BRN
1456
EGR Valve Position Signal
56
Not Used
57
ORN
440
58
DK GRN
1049
ECM/PCM/VCM Class 2 Serial Data
59
YEL
710
Class 2 Serial Data
60
ORN/BLK
469
Low Reference
61
PNK/BLK
632
Low Reference
62
Not Used
63
GRA
720
Low Reference
63
TAN
413
64
Not Used
65
PPL
1670
HO2S High Signal [- Bank 2 Sensor 2]
66
PPL
1666
HO2S High Signal [- Bank 2 Sensor 1]
67
Not Used
68
PPL/WHT
1668
HO2S High Signal [- Bank 1 Sensor 2]
69
PPL/WHT
1665
HO2S High Signal [- Bank 1 Sensor 1]
70
BRN
1174
Oil Level Switch Signal
71
Not Used
72
YEL
772
Transmission Range Switch Signal B
73
BRN/WHT
633
CMP Sensor Signal
74
YEL
410
ECT Sensor Signal
75
PNK
1020
Off/Run/Crank Voltage
76
BLK/WHT
845
Fuel Injector 5 Control
77
DK BLU/WHT
878
Fuel Injector 8 Control
78
Not Used
79
WHT
687
3-2 Shift Solenoid Valve Control
80
ORN/BLK
510
Low Reference
wol_error.gifThis image has been resized. Click this bar to view the full image. The original image is sized 799x247 and weights 17KB.connectorc2pcm2001.gif
May 23, 2014 | 2001 Oldsmobile Silhouette
Turn signals wont work
have you checked the flasher unit itself its a large round or square block in your fuse panel
Apr 21, 2014 | Delphi 2001 - 2003 Saturn L200 Vehicle...
My navman f15 will not recieve signal anywhere
the reason your device does not receive any signal is because the baud rate and com port might be wrong. go to settings and fing GPS port, after entering choose auto choice so it can take the suitable gps port and baud rate
Feb 19, 2010 | GPS
Gps is stuck in new york it is shearching for singal
GPS in New York can come in contact with a numerous unwanted signals, including illegal GPS blockers, or it could be searching for a signal but it can't because of cloudy atmosphere. You did not state what model it is, nor you have stated whether it shuts down or freezes. The answer to your problem lies on the correct questions. That you're stuck in New york, I have no idea what it means. Sorry.
Oct 06, 2009 | Tomtom ONE GPS Receiver
Unlock Delphi nav 200
Hi I know a possible solution in Brazil, this week a contact whit this guy and post the solutions ok.
this is the url:
http://www.quebarato.com.br/classificados/software-c-desbloqueio-gps-delphi-nav200__2626855.html
Aug 09, 2009 | Delphi NAV200 GPS Receiver
Xm radio
Looks like my company is going to purchase a new fm radio for the company truck, I should be able to plug the xm radio into it.
Jun 03, 2009 | Delphi SKYFi XM Radio Receiver
Always "Waiting for GPS Signal"
The waiting for signal message just means it can’t get satellite reception where you are. you most likely need to utlize the Optional external GPS antenna. This is a common problem in the midwest and southwestern states. if this has happened since you bought it. the internal antenna couldve come loose. Which means you may have got a defective unit from the factory. But my guess is you just need to utilize the external antenna.
its like thinking of a cell phone and how some people dont always get a signal. now in gps it needs 3x the signal. with 1/8th of the communications satellites cell phones have.
so as more and more people get tom toms the harder it is for each unit to work, and less signal can be partitioned to your unit at the time of use. where as cell phones only need 2 towers, GPS needs 4 satellites.
Jun 11, 2008 | Tomtom GO 700 GPS Receiver
Great signal, so sound
My XM Boombox is also white and it is a Belkin. The folks at Delphi told me the receiver in the boombox is screwed up which over time also screws up the Delphi receiver. Belkin is sending me a new boombox and Delphi is sending me a new Roady XT.
Mar 01, 2008 | Delphi Roady XT XM Radio Receiver
Delphi NAV200 GPS Receiver Logo
141 people viewed this question
Top Delphi GPS Experts
Marvin
Marvin
Vernon Taylor
Are you a Delphi GPS Expert? Answer questions, earn points and help others
