1) your box may be low on freon, 2) fault thermostat may cause unit run non stop, causing evaporator to ice up and blocking air circulation, 3) Dirt condensor thus reducing operation efficiency.
Check the simplest problem first - make sure condensor coil is clean. if not, use a vacuum cleaner to clean condensor.
For # 2 is more likely if the evaporator has a fan. If it has, check to see if it runs; it is behind the back panel inside box. While at that, see if evaporator coil iced up. If it is defrost using hot water and turn it on setting thermostat to normal temp. setting. If it work fine and later develops same problem, replace thermostat.
If the above 2 solutions don't solve the problem, call a technician to check freon.
when I was replacing the lights in the front I noticed that 1 of the fuses was out. Any idea where...
(More)
when I was replacing the lights in the front I noticed that 1 of the fuses was out. Any idea where to get these?
not dispensing properly touch the button it makes noise but item will not drop even though all slots...
(More)
not dispensing properly touch the button it makes noise but item will not drop even though all slots are full tried adjusting cans but still won't dispense
Have a skybox, when I push for a soda on one button it doesn't dispense. The light does flash, and...
(More)
Have a skybox, when I push for a soda on one button it doesn't dispense. The light does flash, and other three buttons work fine.
Our cans are not cold. We have turned the termostat as high as it will go. The compressor sounds...
(More)
Our cans are not cold. We have turned the termostat as high as it will go. The compressor sounds like it is coming on.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
