Question about Garmin nuvi 350 GPS Receiver
Losing signal the picture freezes and the the no signal message is displayed
  • 1 more comment
  • Anonymous Jan 03, 2008
    I just received a GARMIN nuvi 350 for Christmas we took it on the road two days later and it lost all satelitte reception all together while I was driving. I have tried everything from powering it down several times, sitting still for a while, pressing the reset button, to letting it rest for a bit, to trying to download updates. Any others with this problem or solutions?
    Brad
  • Anonymous Jan 27, 2008
    having the same problem... any solution would be nice...
  • oogabooga May 31, 2008
    For no apparent reason, it loses signal and can't find any satellites. Very difficult to regain connection.
    Scholar:
  • 174 Answers
Have you ever tried it in the open air? Just to make sure it gets a good signal....
Posted on Jul 23, 2008
What is the cause of my "no signal" display?
it means that there is nothing plugged in or sending out to the tv.
what are you trying to do hook ur pc up to tv or?
Mar 18, 2015 | Toshiba 50L5200 - 50 Led Tv
Why does my pvr keep freezing
Sorry can't help on this. Presumably you've switched off/on at mains and checked all connections secure. Would a factory reset help, see tips how to do on fixya, although not sure if you would lose library data.
Aug 19, 2014 | Bush BTU500DTR 500GB Twin Tuner Freeview...
Picture breaks up/freezes weak signal message,
Constantly? Once in a while? If it does it without ever working, it sounds like the tuner is bad. I would not try servicing anything inside the TV. They're just not made for that anymore. I did it for 20 years. You could connect an external antenna, doing the scan, and see it if works that way to rule out a cable problem, or having the cable co. check the dBmv level.
Nov 27, 2013 | Televison & Video
DP-42SM-Freezing the input picture
Since it seems the original board did not have this problem why not put it back to confirm if new board is the problem or some event occurred when you replaced it.
May 25, 2012 | Televison & Video
Digital TV problems
You are suffering from a poor signal. Digital TVs will display 'blocking' (partial freezing of the picture in square or rectangular blocks) or total freezing of the picture, when the signal is too weak.
You don't say if this is a recent problem on a set that has been working correctly - that info. would be helpful. However, things to check include:
Has the aerial moved (wind?)
Are you using a new extension coax cable? If so try another one, as connections may be faulty.
If this a new TV, and you have not used digital previously, your aerial may not be high enough gain for a digital signal, but that is unlikely unless it's a nery old aerial.
Feb 28, 2010 | Philips TV Tuner Video Capture PCI Card -...
2004 hlp4663w component and hdmi signal error message
Chances are the analog board ( One with the Inputs) need replacement. You can get one at the following link. www.tvrepairworld.com
Jan 02, 2010 | Samsung DLP HL-P4663W 46" Rear Projection...
Infocus X1 picture freezes and dissapears and then comes on again
your display settings may be off, so change settings to factory reset and you may have to drop the resolution on your computer. you may also have a bad cable, so try a different cable.
Jul 03, 2009 | InFocus X1-RE Projector, Factory...
Picture and sound problem
If your getting your signal via a satelite receiver or HD cable box, its likely that the sound dropouts and picture freeze are the result of marginal signal strength. Does the TV ever do this when using a DVD player? If not, its certainly the quality of the signal.
If the TV is at fault, the problem will be on the digital board.
michtech
Feb 07, 2009 | Samsung HLN5065W 50" Rear Projection...
TV displays a "no signal message"
is there any picture at all ? if no signal message regardless of any signal input , ur ad board need to be change.
Sep 19, 2008 | Philips Magnavox 15MF400T 15 in. LCD...
Text screen freezing problems
yeah i know what you're saying! my phone works fine, but it's just sending the texts is what freezes mine, and i dont want to lose my info. either. i wonder if there is a solution to fix this? my dad found that there is some setting configuration that will set the texting settings to normal or something, but he's working on that now, but i will keep posting updated information!
Oct 07, 2007 | Motorola Mobility RAZR V3
Garmin nuvi 350 GPS Receiver Logo
131 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
