Question about Microsoft Xbox 360 Console
Nyko xbox 360 intercooler
I purchased the Nyko Intercooler for my son's XBOX 360 and the Xbox power adapter plug does not fit the mating plug on the Intercooler.
  • 3 more comments
  • Anonymous Dec 26, 2007
    Yah the fucking thing is a piece of shit and dont fit its like there is a extra piece in the some dumb ass left in there when it was made.
  • Anonymous Dec 27, 2007
    We have the same problem here. There is a small plastic tab in the middle of both the intercooler female port and the male power plug which conflict with each other. One is aligned vertically and the other horizontally. It looks like they could be made to fit together if either of these tabs was removed, but I am unwilling to do so since they may be there for a reason -- they associated power connections on them may be different.
    Also, there is lots of evidence that the intercooler is *bad* for the 360. See
    http://www.joystiq.com/2006/10/27/nykos-intercooler-may-burninate-the-xbox-360/
  • sb55 Jan 03, 2008
    same problem need solution!
  • Jelksy Jan 04, 2008
    The only solution for this problem is to return it and not purchase another one.
  • xmoodudex Jan 02, 2009
    I took pictures to show. I have the same problem as well
    Female
    Male
Thats weird mine fit perfectly on there
Posted on Jan 03, 2008
Intercooler TS makes Loud Noise when i start up my xbox 360.
clean the intercooler of any dust and the noise will disappear
Dec 18, 2010 | Nyko Xbox 360 Intercooler Ts
Overheating issues
Blow out the Xbox 360 with compressed air, buy external fans, but don't buy the "Nyko intercooler" as they have been rumored to have cause problems to the Xbox 360 and void warranty. Your best bet is to buy a cheap office fan and point it at the Xbox to cheap the air flowing. Also if possible, move the Xbox 360 into a open space where it has at least 5 inches of space behind it, and at least 2 or 3 inches of space on either side to keep a nice airflow. Best of luck!
Jul 13, 2010 | Microsoft Xbox 360 Console
What is the best external cooling system for xBox
There are few manufacturers in the market providing cooling solution for Xbox 360
1) Nyko Intercooler is not popular and not recommended by gamers, so do not go for it
2) Cooler King retails at a price of around $35 it has additional ports with the cooler, read more about this here.
3) Gameshark Cooler available for $20, check the link here
4) Rear Mounted Cooler for $11, check the link here
also 2 other links from Amazon.com here and here
i have not used any cooler for my Xbox 360 so i have given you options to choose from which have good reviews, personally i would suggest you not to go for any cooler just ensure you wipe off the dust from your Xbox vents regularly and keep it at a well ventilated location.
I am from India which is a tropical country with very hot tempratures that rise up to 104 degree Fahrenheit, after one RRoD replacement for the past 1.5 years i have being playing on my Xbox 360 without any issues, i keep dusting my Xbox 360 frequently since i also have dust issue at my place.
Hope this helps, do rate my solution
Happy Gaming
Regards
KreativeGeek
http://gamingbox.wordpress.com
May 17, 2010 | Microsoft Xbox 360 Console
I bought a NYKO intercooling fan and the plug from the xbox 360 elite will not go into the fan receptacle is there a specific intercooler for the elite?
Microsoft has two different power connections for the Xbox 360. I do not recommend the use of the Intercooler. Believe it or not, it actually prevents air from circulating and increases the temperature of the 360!
For cooling I always recommend the fan modification. I have written a free guide showing you how to do this, no soldering skills required!
Here is the guide.
Hope this helps! Let me know if you have any questions.
Dec 29, 2009 | Nyko Intercooler for Xbox 360
Slot will not open
yko has recently released an updated Intercooler that uses its own power source. Nyko claims this problem no longer occurs with new versions of this cooler. However, Microsoft still considers it an unlicensed add-on and will void the warranty of machines showing signs of its use.
Dec 21, 2008 | Microsoft Xbox 360 Console
Fan problems
it looks like by Fitting this Homebrew Fan and switching the power on that you have potentially shorted the systems Motherboard. this will render it unworkable as is in your case. unfortunately for you now, because you have modified the Xbox 360s hardware, your warranty with microsoft is Voided meaning you will have to purchase a new Xbox.
Instead of resorting to fitting Extra pieces of hardware Yourself,i suggest follow these steps :
1) do not put Xbox 360s in small confined spaces such as TV Cabinets and cupboards, this decreases the Cooling capabilities of the Xbox System Dramatically which will eventually lead to an Over heat and potentially damaged CPU and/or GPU (RRoD). Make sure the Xbox console has a lot of empty space around it, Free from other electrical appliances which will give it the fresh cool air it requires to keep the core temperatures down.
2) buy a very small desk fan and have it blowing a very slight breeze onto the back of the Xbox Console. do not have the fan turned up too high or Pointing Directly into the back of the console, as this can sometimes wear down the Bearings on the fans which will eventually cause them to break.
3) the final solution would be to Look into purchasing a 3rd Party Fan Attachment, these fans don't alter the hardware within the system, meaning they are still within warranty. and generally provide cooler running temperatures for your console. one example of an attachment would be the Nyko Intercooler (google it).
Hopefully this solves your problem. sorry to hear that you may need a new console !
Oct 23, 2008 | Microsoft Xbox 360 Console
2 light flashing red lights once game is on for 5-10 min.
your xbox is overheating put it in an open area and let it cool overnight i might even suggest the nyko intercooler ex
Sep 26, 2008 | Microsoft Xbox 360 Console
It keeps turning off and on
If you have a nyko intercooler fan on your xbox 360, take it off, this would be causing the problem.
If you dont have one, check your power brick, if it is orange or red when you power the system, then you will need to buy a replacement.
Apr 22, 2008 | Video Game Consoles & Games
Power cord light is orange
no the cheap bastards try and fix the old 1 and send u a new 1 as a last resort!!!
looks like you need a new power cord but i suggest u borrow a friends and try that 1st to see if that is the actual problem
Apr 15, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
