Question about 2wire 2700HG-B Router (2700HGB)
I have to click the addres bar twice
Can't connect to internet. But sometimes if I get lucky I can connect to internet if I click on the address bar twice or just stop and refresh.
My Yahoo messenger also keep disconnecting. And the same with MIRC.
Is this my ISP problem or my modem? Thanks for all your attention
    Problem Solver:
  • 9 Answers
It could be your ISP, modem or computer. i really cant say, need to know few things like the status of the lights on your modem when your connection is dropping out. you might want to call you ISP for this and ask them if there's a network outage on the server you are connected to
Posted on Feb 19, 2008
Wireless problem. it's conected, but limited. no internet connections. my operating system is vista
Generally you get this indication when your system has auto-assigned itself a APIPA IP addres (Automatic Private Internet Protocol Address) where the system was unable to get an IP address from the DHCP server.
To resolve, right click the wireless network connection, Click Troubleshoot Problems to Diagnose and Repair the connection
Dec 06, 2009 | E-Machines M2350 Notebook
How do I repair a URL address
GO IN CONTROLPANEL-NETWORK CONNECTION
RIGT CLICK ON CONNECTION LOGO
SELECT PROPERTIES
SELECT TCP/IP (gENREL)
SELECT PROPERTIES
TYPE IP ADDRES
SUB---------------
GATEWAY---
DNS -1
DNS-2
THEN OK
NOT USE USUALLY REPAIR CONNECTION OPTION
THANKS
Oct 10, 2009 | Computers & Internet
I try to contact my router with the adress 192.168.0.254 and it doesn't work. Can you help me?
Basically your Router will have a hard coded addres on your network such as 192.xxx.xxx.xxx. You can find this address in your network properties. On your computer go to:
Control Panel
Double click on Network Connections
Select your Network Adapter (Double Click)
Click on the Support Tab
Here where it says default Gateway is the address of your Router enter this address in the Browser address bar and you ahould be able to communicate with the Web GUI of your Router.
Good Luck
Sep 19, 2009 | Cisco 800 SERIES IOS IP/ FW PLUS IPSEC...
Windows vista not taking huwaei mt841 broadband modem.where to get vista compatable drivers
This device will not require drivers if it is connected to your computer with the Ethernet network cable.
After you have connected it to your computer and turned the device on, simply open up your Internet browser and type in its IP address into your address bar.
Typical IP addresses are:
  • 192.168.1.1
  • 192.168.1.254
  • 192.168.0.1
  • 192.168.0.254
You may have to consult the manual for the exact addres or trial and error. You should see a router configuration page. That's where you can customise its settings. The settings page will look like this.
If you're asking that you can't connect to the Internet with this router, well, that's a slightly different question :-)
Hope this helps!
Jun 06, 2009 | Microsoft Windows Vista Ultimate Edition
Can't connect
It will be one of two things or both - either your computer is notsetup for DHCP or your router is using the same IP address as your ISPor both.
To check ISP IP address connect your computer to your modem then: from start => run => CMD (hit enter after this)
a command window opens, type "ipconfig /all" without the quotes.
The line with "IP address" gives you your ISP IP addr.
Compare this with what you get from your router manual if they are the same then do the following:
Toconfigure your computer to use a DHCP IP address, go to the Controlpanel => network connections => Properties (right click on yourdefault connection) => double click Internet protocol (From generaltab) => (a new window pops up) from the general tab ensure that"obtain an IP address automatically" is selected.
To change the IP address of your router check your manual and do the following:
IP Addr => 10.10.1.1
Sub net mask => 255.255.0.0
Default gateway => IP address from your ISP
Make sure to the router is set to act as a DHCP server.
You should be up and running.
Aug 10, 2008 | Buffalo Technology WHR-G54S Wireless...
Just bought a laptop and can't get comcast to work with net gear. My son's lap top worked when he lived with me.
It will be one of two things or both - either your computer is not setup for DHCP or your router is using the same IP address as your ISP or both.
To configure your computer to use a DHCP IP address, go to the Control panel => network connections => Properties (right click on your default connection) => double click Internet protocol (From general tab) => (a new window pops up) from the general tab ensure that "obtain an IP address automatically" is selected.
Aug 10, 2008 | NetGear WGR614 Wireless Router
Dynext router
Aug 09, 2008 | Dynex Computers & Internet
Router Connectivity
Aug 08, 2008 | Computers & Internet
Unable to conect to dodo isp
First make sure that you have a valid connection to the router and that you have a valid IP address.
(note: for a wired connection you should have a link light on the numbered port of the router to which your computer is connected. You should have an IP address in the range 192.168.2.x. To check your IP address, click on Start, Run and type in command. Click OK. Now type in ipconfig and hit enter. Your IP address will be listed.)
For the F5D5230-4, F5D6230-3
Open a Web Browser
1. In the address bar type http://192.168.2.1
2. Click on Intial Setup
3. Select PPPOE and click Select
4. Type in your username that was assigned to you by your ISP *
5. Type in your password that was assigned to you by your ISP twice
6. Leave Service Name blank
7. Click on Enter
8. Click on Status in the left hand column
9. It should now show Cable / DSL Connected under the Internet column
For the F5D5231-4, F5D6231-4, F5D7230-4, F5D7231-4, F5D7231-4P, F5D8230-4, F6D3230-4
Open a Web Browser
  2. Click on Connection Type in the left hand column under Internet WAN heading
  3. Enter your password if any and click Submit
  4. Click on PPPOE and then click on Next
  5. Type in your username that was assigned to you by your ISP *
  6. Type in your password that was assigned to you by your ISP twice
  7. Leave Service Name blank
  8. Click on Apply Changes
  9. Click on the Home link at the top of the screen
  10. It should now show Connected as the Internet Status at the top right hand corner of the web page
Apr 24, 2008 | Belkin (F5D5231-4) Router
Internet
hi i am sabbirmobile frome india,
will you go inside of mobile manu(1)click windaws start boton and go in sating(2)click on connection(3)add new connection(4)write your internet seting name(5)write your internet provider name(6)type ip addres(7)type proxy addres and click ok.
now enjoy your internet connection.
Jan 24, 2008 | HP iPAQ hw6515 Pocket PC
2wire 2700HG-B Router (2700HGB) Logo
43 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
