Question about Nikon D70s Digital Camera
Nikon d70 will not take photo with fault code r09 coming up on area where number of photoes taken is any ideas?
  • nsfbr May 11, 2010
    r09 is not a fault code. It is the number of images remaining with the current settings in the internal camera buffer memory. You can check this by changing the quality settings and watch the value change (r03 would be typical for RAW - I'm guessing you it set to one of the Jpeg settings)
    So that isn't related to the problem.
    Any chance of you answering some quick questions?
    - What lens are you using with the camera?
    - Does the lens focus? Does it achieve focus lock? (That means the green dot in the lower left of the viewfinder shows continuous green.)
    - What mode setting are you using? (The dial on the top that has M A S P and a bunch of auto modes.)
  • 667 Answers
Check the depth of field preview with the lens on and the camera on. If the aperture does not react, it may be a problem with the lens rather than the camera. Check the camera with another lens if you have one.
Posted on Dec 26, 2007
Why does my pictures on my nikon D70 comes out balck and withpink horizontal lines
Do you see coherent photos in the camera's rear display when the CF card is still in the camera?
Aug 16, 2014 | Nikon D70 Body Only Digital Camera
Nikon d70 wrtiting to memory
This is not something you will be able to fix yourself. Go to Nikon USA's website for the location of the nearest repair depot and phone them. They can give you an idea of the cost.
May 05, 2013 | Nikon D70s Digital Camera
Negative type,or lost color on glossy prints.
Check your computer settings. It has programming to make Negatives like the old photo film would produce and this may be the Mode that it is set for. You could also be in the Infared Mode which would give you more strange results.
I am not an expert for this area, but I have used some of the photo programs both on my set and at the Drugstores. You could also have set your Camera, if Digital, for the wrong Mode and taken the photos in Infared or Negative Modes. The printer would not be at fault, just accurately printing the way it was recorded.
Jan 23, 2012 | Kodak Esp 3250 Allinone Multifunction ( ...
Nikon D70 is freezing up. I have no idea what I may have done but when I push the button to take a picture nothing happens and r09 flashes
r09 is just the camera estimate od how many shots you have left on your memory card. For the other, Use fully charged battery , Turm ca,era on and re,ove battery while at same time holding shutter for a[[rox 3- seconds. Re[lace battery, then turn camera off.on. If that does not do it, turn camera on and press reset button on bottom of camera (page 200, I believe, in tghe users manual
Jan 29, 2011 | Nikon D70 Digital Camera
Photos taken now not visible on memory card. I'm currently on vacation and have been taking photos on my DMC-TZ5. Camera has been working fine, until yesterday. I took a number of photos of a...
The memory card has most likely corrupted or the camera itself is faulty. Depending upon where you were holidaying this could be an intermittent fault due to temperature or humidity. It can also be caused if you have not followed the correct procedure for safely removing your SD card from your laptop (in Windows, click on "safely eject hardware" or from the "My Computer" window right click the SD card icon and select "Eject").
Try cleaning the card contacts using a cotton bud moistened with alcohol in case sweat, oil or grease has got onto them. If that fails then see if you can borrow another SD card, but this is risky as you may end up damaging the card so you may be better to buy the cheapest one you can solely for testing purposes (it's also worth asking for one on your local FreeCycle /Freegle groups as many folks now have low capacity SD cards with zero resale value which they have upgraded from and no longer use) . If the camera works perfectly then you know that it's most likely that the card was at fault and if not you definitely have to choose whether to get your camera sent for diagnosis and possible repair by Panasonic or whether to buy another one. Your camera is recent enough that it might still be under the manufacturer's warranty.
Regarding your existing SD card, it seems not to have recorded the images correctly or may not have recorded them at all. If the former applies, they *might* be recoverable but it needs specialist data recovery software which is not cheap (search "SD recovery"). Insert the SD card into your laptop and select the three black frames and click on "properties" to see how much memory they occupy. This will give you an idea as to whether there are approximately 90 images (3 x 30) there or not, but even if not the images could still be elsewhere on the card. You really won't know unless you invest in the required software to find out or by taking the card to a data recovery specialist (also not cheap). If you hope to recover any lost images then you must not use the card again as the data will gradually become overwritten.
The final option is to abandon all hope of the lost images, transfer the ones which you do have to your laptop (and back them up further to recordable DVD or a USB stick) and to then reformat the memory card in your camera. This option is only to be taken if obtaining a replacement SD card is impractical and if you wish to gamble that the fault was an unusual one-off. Only you can decide whether the risks of losing further unrepeatable photos are an acceptable alternative to the only certain (and expensive) fix of buying a new camera and/or memory card, although you could recoup some of the expense by reselling your current camera: it's up to buyers to ask questions ("caveat emptor") so don't mention the recent issues. Morally and legally this is fine as you don't actually know that the camera is faulty.
Sorry there's no definite answer here, but I hope that my reply will help you to isolate the cause or assists you in choosing your next course of action. If the fault is intermittent then they're impossible even for professionals to repair if they cannot reproduce the fault when testing the camera.
Good luck, and please take a moment to rate my answer.
Sep 30, 2010 | Panasonic Cameras
I have a Compact Flash card of 512mb (CF card) i use this card in my nikon D70, i went to my friend house and tried connection my camera to his comp to download image, but my friend machine was infected by...
Guide to recover deleted photos from Nikon D70?
Connect Nikon with PC
Using a USB cable or putting SD card into an SD card reader to connect Nikon with Computer.
Scan Nikon d70- Running the Nikon Photo Recovery,you can choose Nikon media drive and click "Start Scan" for scanning
Recover deleted photos
After scanning, you will see all recoverable media photos and videos with file type. At last, click "Recover" to recovering deleted Nikon D70 photos.
This Photo Recovery also can recover all photos files from Nikon D3100 like JPEG, BMP, TIFF, GIF, etc. Support all Nikon camera.
For full details please refer to Nikon D70 Manual.- https://guideusermanual.com/product-name-d70-manual&po=4425&lang=English
Mar 28, 2017 | Computers & Internet
Nikon D70s Digital Camera Logo
563 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
