Question about Panasonic DMR-E55 DVD Recorder
No Indication...Dead Unit?
I switched my machine on half an hour ago and everything was working fine.  Now, there is no indication on the front of the unit and I get no response to the On/Off switch.  I have checked/changed power supply leads, but nada.  Any ideas, please?
  • 185 Answers
Firstly, try plugging the unit into another mains socket just to make sure it's not the socket that's faulty, or try another appliance in the socket you are using. Next, make sure the fuse in the plug hasn't blown. If you don't have a fuse tester, you can try the fuse in another similar appliance to see if it works. If it has blown and your spare lead is the same, there will be an internal problem. Inside the unit is an in-line 2 amp fuse. If this has blown you almost certainly have a power board problem. Always switch the mains off before plugging in or removing the mains lead from the rear of the unit. Back EMF can damage the appliance if you don't do this.
Posted on Dec 26, 2007
F26 washing machine Siemens s1272
The F26 error code on the Duet washer is a door switch error.
Disconnect the unit for 10 minutes and plug back in to power.
Check the display for any kind of power indication.
If you have any leds of power indication, try adjusting the door switch.
May 07, 2014 | Washing Machines
Push button switch does not work
Sounds like a really dead machine. You have to start at the outlet, with something to see if it's working.
If the outlet is good, are any lights or indication of power on the machine working?
If no indication of power shows, a technician needs to open the machine to see what's wrong.
Nov 27, 2013 | Electrolux Washing Machines
My laptop is completely dead, fine yesterday. Today no lights, sounds nothing. I tried removing the battery , unplugging no response. Thanks,
Remove the battery for at least 3 minutes... Then put it back and then plug in the charger and switch on the charger. If the battery is completely drained, it would take a while for the charging to initiate. Please have patience and leave it on charging even though without the charging indication for at least an hour. After that still if the charging indicator doesn't lit, then its definitely your charger or laptop. You will need to take it to a service centre in that case.
Nov 03, 2011 | Compaq Presario 2170US Notebook
Marantz pm7200 hdam, will not power up, checked internal fuses all ok, over rid the internal power-on rely and power amp powers up but pre amp circuit still dead, any idea, power panel look fine but...
The preamp stage might be dead. Not much you can do but to bring it in. Make sure the input selector is on the right input.
Sometimes there's a "Monitor input" usually Tape2 input that overrides everything
Sep 01, 2010 | Marantz PM7200 2-Channel Amplifier
Gaggia Syncrony won't heat up.
I switch the machine on and the green light (number 24) flashes to indicate it is warming up but it never gets there it just keeps flashing for at least half an hour.
Dec 31, 2009 | Gaggia Syncrony Logic 74884 Espresso...
Cucina Pro Double Coffee Brew Station 1711 Series We have had this unit for about 2 months. It has been operating fine until about a week ago when the left side ON/OFF light and the TIMER light have both...
It is an indicator that means you have to clean that side - you then press two of the buttons for 5_10 seconds to stop the blinking . but i can't find my manual and can't figure out which two buttons!
Jun 28, 2008 | Heating & Cooling
Frigidaire built stacked washer and dryer
There is a thermal cut off on the motor. when it overheats it will trip and not start until the motor cools down. Replace the motor to solve the problem.
Jan 07, 2008 | Frigidaire GLTF2940ES Front Load Washer
Panasonic DMR-E55 DVD Recorder Logo
163 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
