Shinco 1250 DVD Player
Having problems reading dvd. Intermittent. Will read for a few minutes then die. Once it gets warm it just keeps giving me this sound like a car reving for a Nascar race.
Should I try to repair? Trash it? Any self help ideas?
  • 1 more comment
  • micemic Dec 28, 2007
    What would you say if I told you the disc loads after a few hours then dies after a few minutes. Right now it just loads and eventually goes to no disc after about a minute of sounding like a race car under the lid. What problem would that indicate?
    Problem affects any disk I try. I'm fairly experienced with general troubleshooting and thats the first and easiest remedy I'd try which is to change the disk.
    Genius:
  • 1,226 Answers
You can try to repair it. Open the DVD player, after opening seeing the optical lens inside. Gently clean the optical with soft cloth or Cotton slowly rub it. do not add fluid to the cleaning material that will cause to destroy the lens.
if not work then maybe your DVD player is useful for some video cd.
Posted on Dec 28, 2007
  • Emelio Navaja
    Emelio Navaja Dec 28, 2007
    Try use some disc, the current disc maybe has portion of data that cannot be read by the player. thats is why player keep on turning the disc finding a good portion of the disc its to find out the player detect bad on it will prompt NO disc.
    Guru:
  • 1,894 Answers
Open the player and look inside it
If you don't see any signs of the laser then it's most likely that the lens unit has malfunctioned or simply "died" (but in your case the laser still shows some signs of life since you said it recognized your discs). You need to get that replaced to have your unit up and running again. Sorry...
  • dewan nafees ahmed Dec 28, 2007
    It could be dust, so try using a lens cleaner (but it's highly unlikely). Try it just to be sure.
    no. i think this kind noise cant be due to lens.
    this must be due to mis-positioning of the disc inside the player compartment.
    when evry if there the disc is not held properly inside the player this kind of noise occurs. once when i was testing my DVD drive by keeping it open i just held the drive loose in my hand. that time it made a heavy noise.
    but i soon turned the power off and made the drive tight by its coverings and then started it again. it went on well.
    but if this case is not tackled in proper manner it will cause the disk to crack inside the player itself. this may cost you a lot since it has chances for damaging the lens inside it.....
    if this is not the problem.. the sure problem is your lens.. its totally DEAD.. so the drive may be trying to read it again and again ( reason for noise) .. since its not able to read it after many tries it just leaves it off..
I put the dvd in the slot and the machine takes a very long time loading and the the it says no disc. I also noticed one time it said ps off
Tries it with many other DVD discs,If u have the same result the DVD player Laser eye is having problems and it dying,not reading Data's from the DVD disc anymore.If not,that only DVD disc,that have problems,than check DVD disc for smushes,grims and cracks on the DVD disc itself.If it is the DVD player having problems with it Laser eye and it dying.The DVD player is junk not worth repairing.The DVD player sell really cheap these days,like $40 for a brand new one.
Nov 15, 2010 | RCA DRC247N DVD Player
Shinco 1720c DVD player will no longer read DVDs... just says "no disc"...
try using a lens cleaner or take apart and clean upper and lower len with a qtip and rubbing alcohol
Oct 12, 2009 | Shinco SDP-1720C Portable DVD Player
Code H02
Your DVD player is having an issue with the spindle motor (the thing that spins the DVD around). The following solution works for most people, and you should only have to do this once.
  1. Unplug the DVD player.
  2. Take the cover off.
  3. Place a disc on the spindle.
  4. Put a little pressure on the disc (so it doesn't slip) and spin it around a few times.
  5. Remove the disc, reassemble, and plug back in.
  6. Try to play a DVD.
  7. Report back if this solved your problem, or if more troubleshooting is needed.
Aug 02, 2009 | Panasonic DVD-S55 DVD Player
DVD player no longer plays DVD's that I KNOW played on it before.
yes, Lazer wont aline to read, they get progressively worse, sometimes intermittent, if that is the case then you will need a whole new internal cradle. maybe time to get another one. the Yeti
May 20, 2009 | Televison & Video
DVD not reading
Its better that you purchase a better lens cleaner which keeps our old lens alive.
I have same problem with me, but now when i used the lens cleaner, the problem solved, now i can easily see DVDs on my portable player
Apr 02, 2009 | Aiptek PDV-919 Portable DVD Player with...
SHINCO DVD - 100 English manual to operate the full function of DVD.
if you find the manual could you please send me a copy I have the same problem I have a Shinco DVD 100 bought in cina but I do not understand cinese.
Thank you very much, if I found it I will send you, thi is my e-mail
villasts@gmail.com
my name is Rani
Feb 04, 2008 | Shinco DVD-833 DVD Player
I have bought it new but there is no instruction manual
CONATC YOUR SUPPLIER. iT IS UNDER WARRANTTE AND WILL BE SUPPLIED BY THEM
Oct 05, 2007 | Shinco SDP-1250 Portable DVD Player with...
Dvd Jammed
There should be a tiny hole that you can get a paper clip through on your DVD this hole leads to a manual release mechanism that should open the DVD drawer. I hope this helps
Sep 10, 2007 | Shinco SDP-1250 Portable DVD Player with...
Reads disc then stops and reads again, keeps repeating this process
Hi dangraham.....I'm not very confident whether this will remedy your particular issue, however, please click on the URL below for the information....good luck my friend http://www.fixya.com/support/t178169-sound_but_no_picture_play_certain_dvds
Nov 10, 2006 | Cyberhome CH-LDV 700B Portable DVD Player
Televison & Video Logo
Top Televison & Video Experts
