Question about Toshiba Satellite U205 Notebook
Sound driver i tried downloading the driver from toshiba site of windows xp but its not working
  • 2 more comments
  • Anonymous Jan 07, 2008
    Toshiba Satellite U205 PC Notebook
  • Anonymous Mar 30, 2008
    no sound driver
  • Anonymous May 08, 2008
    i have a toshiba satellite a205-s4777, it was it had windows vista but i installed windows XP in it, now my sound doesnt work any more, is there anyone that know where to get the sound driver
  • Anonymous May 12, 2008
    no sound in my pc
I need the solution
Posted on Sep 28, 2008
Give me
Posted on Sep 17, 2008
I don't have a sound driver for intel 945 chipset. what can i do for that?
Posted on Jun 13, 2008
    Genius:
  • 1,601 Answers
Missing or lost sound in Windows 95 / 98 / ME / 2K / XP.
Cause:This issue could be caused by any of the below possibilities.
  1. Bad software settings.
  2. Corrupt or missing sound drivers.
  3. Compatibility issues with the operating system and/or other hardware.
  4. Speaker related issues.
  5. Bad or missing sound card.
Solution:Verify software volume control settings
First verify you see a small sound icon sound driver - sound3.gif in the systray (generally at the bottom right hand corner of your screen). If this icon is missing follow the below section.
Windows XP
  1. Open the Control panel
  2. Open the "Sounds and Audio Devices" icon.
  3. Verify the "Place volume icon in the taskbar" checkbox is checked. If this option is not available or is grayed out, skip to the next section of this document.
  4. If you were able to check this box, click ok and close out of this window and the Control Panel.
  5. Double-click the sound icon in the systray and verify that all the sound volumes are mid-way or higher.
verify the installed driver settings
  1. Open the Windows Device Manager
  2. Verify there are no conflicts or errors listed anywhere in Device Manager. If conflicts exist skip down to conflicts section.
  3. Verify no other devices are listed. If other devices are listed skip down to other devices section.
  4. Verify that your "Sound, video and game controllers" category is listed, if not skip down to the missing sound card section.
  5. If no conflicts or other devices are listed and your sound card is listed with no conflicts, skip to the next section.
Conflicts section
If conflicts exists with your sound card and/or other devices installed in your computer it is likely that either the drivers are not properly installed for that device and/or the sound card and/or other devices are conflicting. If you open the properties of the device that is conflicting and view the properties, additional details about the conflict can be found. Additional information about error codes as well as help with Device Manager can be found on our Device Manager section.
If you are unable to locate additional information about your issue or are unable to resolve the issue, follow the below steps.
  1. Under Sound, Video and game controllers highlight each device and press the delete key to remove the device.
  2. Reboot the computer.
  3. As the computer is booting the system will detect the sound card and any of it's devices and re-install those devices. If prompted for a location of drivers, try pointing it to your sound card CD and/or your Windows CD. If this does not work or is unable to locate the proper files, you will need to get the latest sound drivers from your sound card manufacturer.
Other devices section
If other devices are listed, it is possible that these other devices could be the sound card or other devices conflicting with the sound card. If any other devices are listed it is recommended you remove those devices, reboot the computer and let Windows redetect the devices.
If this does not work, attempt to determine which device is not being detected and resolve that issue first.
Missing sound card section.
If you are missing the "Sound, video and game controllers" category in Device Manager, it is likely that the sound card drivers are not installed properly, sound card has been disabled, sound card is bad, or no sound card is available in the computer. First, verify no conflicts or other devices are present in the Device Manager; if these are present it is likely they are the sound card and/or devices causing the sound card not to be detected. Second, verify that the computer has a sound card and/or that the sound card is enabled on the computer.
If this is an on-board sound card you can verify that it is enabled in BIOS setup. Additional information on entering the BIOS setup can be found on document CH000192.
If you have no adapters and/or cannot click the down arrow to select the correct adapter, close out of this Window. In Control Panel double-click the System icon / click the Device Manager tab within Device Manager and ensure there are no yellow ! or red X.
If you have either of these on any of your sound devices, attempt to remove everything under Sound Video game controllers and reboot the computer. If after rebooting the computer you still have the same conflicts, double-click on the conflicting device and refer to our Device Manager error code section giving you additional information on the error code you are experiencing.
Verify speaker connections
Verify the speakers settings and speakers are not at fault by running through speaker troubleshooting steps in document CH000034.
Sound card drivers
If you have followed the above recommendations and you are still unable to get the sound card to work, download and install the latest sound card drivers from the computer or sound card manufacturer. A listing of sound card drivers can be found on our sound card driver page.
Posted on Dec 26, 2007
3 Suggested Answers
SOURCE: Toshiba satellite a55 s1063, driver wireless
OK guys here is the wireless driver for Toshiba satellite a55 s1063. It took two weeks for me to find this driver.
http://www.wireless-driver.com/download/atheros/Atheros-based-all-wireless-cards.htm
Posted on Mar 22, 2009
SOURCE: Toshiba PSAAKL 00M800 sound driver problems with XP
i have a toshiba psaakl 00m008 notebook with vista Home installed but due to some problem i installed windows XP professional and now i have a problem with the sound driver ... where do i download sound driver which is compactible with XP please help
Posted on Jun 16, 2009
Satellite a135-s4637 did not support xp driver for xp os
Did you try downloading the drivers from the Toshiba WEB site?
Normal 0
You can download any/all the Windows XP device drivers for your model laptop from the Toshiba WEB site from their download page. Make sure you enter the model of your laptop so you can get the correct drivers. Please click on this link: -
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
http://blitware.com/adpages/driverfetch/manufacturer/?manufacturer=Toshiba&gclid=CMOVxNCBx6ACFSgnawodoHNGbA
Sep 30, 2010 | Toshiba Satellite A135-S4527 Notebook
No drivers for windows xp sp2/sp3
You can download all of the drivers from the Toshiba website.
Nov 12, 2009 | Toshiba Satellite A205-S4777 Notebook
I search driver toshiba tecra 9100 windows XP
You can download any/all the Windows XP device drivers for your model laptop from the Toshiba WEB site from their download page. Make sure you enter the model of your laptop so you can get the correct drivers. Use this link :-. http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp#
Jun 21, 2009 | Toshiba Tecra 9100 Laptops
They are all right here:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=1132282&rpn=PSA50U&modelFilter=&selCategory=3&selFamily=1073768663&selModel=1132282|PSA50U
Click on the Downloads tab and then choose windows xp as your operating system and you can download any of the drivers that you need from that point.
Mar 14, 2009 | Toshiba Satellite A55-S1063 Notebook
I?ve recently downgraded my Toshiba Satellite A135-S4527 to Windows vista. But I?m unable to find the drivers for Windows XP. Ethernet drivers
Do you mean Vista to XP not the other way around?
Download the XP network driver for your model laptop from the Toshiba WEB site from their download page.
For a shortcut to the Toshiba's download page.
Copy and paste this address into your browser's URL address location.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1209157&rpn=PSAA0U&modelFilter=A100-S8111TD&selCategory=3&selFamily=1073768663&selModel=1209157|PSAA0U
Feb 19, 2009 | Toshiba Satellite A135-S4527 Notebook
Xp drivers
Hi, I could do with more information, however try visiting www.cnet.com I get all my FREE drivers and downloads from there.
Good Luck!
Please push that Blue button if sorted.
Paul 'W' U.K.,
Jan 27, 2009 | Toshiba Satellite Pro L300 Notebook
Drivers for TOSHIBA A135-2386 or Windows XP
Go for google search of  "drivers downloads for TOSHIBA A135-2386" , u will get many site from where u can download ur drivers
or try these sites
www.driverfiles.net
www.drivershq.com
www.driverskit.com
May 08, 2008 | Microsoft Windows XP Professional With...
Toshiba A135-S2276 Win XP Drivers
Toshiba A135-S2276 Win XP Satellite Drivers free downloading
Nov 08, 2007 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite U205 Notebook Logo
854 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
