Question about Sachtler Speed Lock CF HD Tripod
Satchler cf speed lock 3 stage
Stop on lower section has come out of C/f tube, how do i remove & repair
  • 625 Answers
Stop is probably a rubber "O" ring that fits into a recess around the leg. the leg will have to be taken apart upward towards the spreader plate.
Posted on Dec 31, 2007
How do I remove the gas tank out of a 2006 Ford 500 no one knows
SECTION 310-01: Fuel Tank and Lines 2006 Freestyle/Five Hundred/Montego Workshop Manual REMOVAL AND INSTALLATION
All vehicles
  1. With the vehicle in NEUTRAL, position it on a hoist. For additional information, refer to Section 100-02 .
  1. Release the fuel system pressure. For additional information, refer to Section 310-00 .
  1. Drain the fuel tank. For additional information, refer to Section 310-00 .
All wheel drive vehicles
  1. Remove the rear driveshaft. For additional information, refer to Section 205-00 .
All vehicles
  1. Remove the muffler. For additional information, refer to Section 309-00 .
  1. Disconnect the fuel vapor control tube assembly valve-to-fuel vapor tube quick connect coupling. For additional information, refer to Section 310-00 .
  1. Disconnect the fuel supply tube-to-fuel filter quick connect coupling. For additional information, refer to Section 310-00 .
  1. Disconnect the fuel vapor tube-to-fuel vapor control tube assembly valve quick connect coupling. For additional information, refer to Section 310-00 .
  1. Disconnect the fuel tank wiring harness electrical connector at the rear of the fuel tank.
  1. Release the clamp and remove the fuel tank filler hose from the fuel tank.
  1. Place a suitable lifting device under the fuel tank.
  1. Remove the 2 front fuel tank strap bolts.
    • To install, tighten to 35 Nm (26 lb-ft).
  1. NOTE: Do not bend the fuel tank straps.
    Loosen the 2 rear fuel tank strap bolts and position the 2 fuel tank straps aside.
  1. Lower the fuel tank enough to move forward, clear of the fuel straps then complete the lowering procedure.
  1. To install, reverse the removal procedure.
Procedure revision date: 08/19/2009
May 03, 2016 | Ford Cars & Trucks
Replacing upper intake gasket 2003 E150 4.2l
Remove the 12 bolts that hold the intake to the lower section and disconnect all the hoses and linkages. Replace the lower gaskets and torque the manifold in a radiating sequence in this order.
stages to tighten
stage 1 - 59 inch pounds
stage 2 - 66 inch pounds
stage 3 - 90 degrees
Sep 17, 2012 | 2003 Ford E150
How do you take the alternator offa 02 Dodge Grand Carvan?
3.3L & 3.8L Engines
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Remove or disconnect the following:
    Negative battery cable Alternator harness connectors Right front lower splash shield Accessory drive belt Lower oil dipstick tube bolt and the wiring harness from the tube 3 mounting bolts Dipstick tube Alternator
Sep 14, 2011 | 2002 Dodge Grand Caravan
Need to replace ignition cylinder. no keys
This is not an easy repair due to anit theft requirements. need to chisel off bolts.
Section 11-04: Steering Column 1997 Probe Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 05/17/2000
Ignition Switch Lock Cylinder Removal
  1. Remove the steering wheel (3600). Refer to the procedure in this section.
  1. Remove the four lower steering column shroud screws.
  1. Separate the upper and lower steering column shrouds.
  1. Remove the ignition switch lock cylinder illumination miniature bulb from the lower steering column shroud.
  1. Remove the upper and lower steering column shrouds.
  1. Remove the multi-function switch (13K359). Refer to Section 11-05 for the removal and installation procedure.
  1. If equipped, remove the ignition/shifter interlock cable screw.
  1. Disconnect the ignition/shifter interlock cable (3F719) from ignition switch lock cylinder (11582).
  1. Use a chisel to remove the two ignition switch lock cylinder bolts.
  1. Remove the ignition switch lock cylinder from the steering column.
  1. Disconnect the ignition key reminder switch electrical connector.
  1. If necessary, remove the ignition key reminder switch.
Installation
NOTE: Use new ignition switch lock cylinder bolts. Tighten the bolts until the bolt heads break off. Check for proper ignition switch (11572) operation.
Mar 25, 2011 | 1997 Ford Probe
How do I remove the radiator form my 1997 ford taurus do I have to remove the bumper?
No,
Section 03-03: Engine Cooling 1997 Taurus, Sable Workshop Manual
REMOVAL AND INSTALLATION Radiator Aluminum Core, Crossflow
SPECIAL SERVICE TOOL(S) REQUIRED Description Tool Number Fuel Line Disconnect Tool Set T90T-9550-S
Removal
svh~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not mix Standard (green) Coolant with Extended Life Coolant (orange). If mixing occurs, drain engine cooling system and refill with originally equipped coolant type. If this contamination occurs, the service interval of Extended Life Coolant will be reduced from 6 years/150,000 miles to 3 years/30,000 miles.
  1. Disconnect battery ground cable (14301).
  1. Remove battery (10653) as described in Section 14-01 .
  1. Remove clip retaining contant control relay module and position module aside.
  1. Remove battery tray (10732) as described in Section 14-01 .
  1. Remove radiator cap (8100).
  1. Raise vehicle on hoist as described in Section 00-02 .
  1. Remove radiator splash shield.
  1. Drain engine cooling system as described in this section.
  1. Remove the radiator mounting bracket assembly.
  1. Remove lower radiator hose (8286).
  1. Partially lower vehicle.
  1. Remove upper radiator hose (8260).
  1. Remove radiator overflow hose (8075).
  1. Remove upper A/C condenser core retaining bolts.
  1. Remove upper transmission oil cooler tube clips.
  1. Remove lower transmission oil cooler tube (7C410)(EPN=7C410)using 3/8 Inch Fuel Line Disconnect Tool T90T-9550-C.
  1. Raise vehicle on hoist.
  1. Remove lower transmission oil cooler tube clips.
  1. Remove transmission oil cooler bracket and position transmission oil cooler aside.
  1. Remove lower A/C condenser core bolts and position A/C condenser core (19712)aside.
  1. Remove radiator support bracket.
  1. Remove radiator (8005).
Jan 13, 2011 | 1997 Ford Taurus
Philips tv 20pt1782 want service manual
hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me..
Jun 10, 2010 | Lexmark All-in-One Printer with PictBridge
How to replace head gasket on 1999 2.5 cyl ford ranger
Cylinder Head Removal
  1. Disconnect the battery ground cable
  2. Relieve the fuel pressure.
  3. Drain the cooling system. Disconnect the three way catalytic converter Loosen the water pump pulley bolts.
  4. Remove the drive belt.
  5. Remove the water pump pulley, fan and clutch assembly.
  6. Remove the intake manifolds
  7. Remove the ignition wires from the spark plugs .
  8. Remove the spark plugs; .
  9. Remove the oil level indicator tube
    • Remove the bolt.
    • Remove the oil level indicator tube.
    • Remove the EGR valve to exhaust manifold tube
    1. Remove the valve cover
    1. Remove the drive belt .
    1. Recover the A/C refrigerant; refer to Disconnect the engine control wiring from the A/C compressor
    2. Remove the A/C compressor mounting bracket (2882) with the power steering pump (3A674) attached and position out of the way.
    3. Disconnect the engine control sensor wiring connector from the generator
    4. Disconnect the (1) lower radiator hose and the (2) water pump inlet tube
    5. Remove the upper radiator hose
    6. Remove the water pump inlet tube.
      • Remove the bolts.
      • Remove the water pump inlet tube.
    7. Remove the generator.
      • Remove the bolts.
      • Remove the generator.
    8. Remove the generator mounting bracket.
      • Remove the bolts.
      • Remove the bracket.
      1. Remove the ignition wire and bracket; refer to Section 303-07A .
      1. Remove the outer timing belt cover; refer to the procedure in this section.
      1. Remove the timing chain/belt (6268); refer to Timing Drive Components—Timing Belt in this section.
      1. Remove the exhaust manifold (9430); refer to Exhaust Manifold in this section.
      1. Remove the cylinder head .
        • Remove the bolts and discard. (should get new ones)
        • Remove the cylinder head.
        • Remove the head gasket and discard.
Installation
  1. Clean all gasket mating surfaces.
  1. Install new gaskets as necessary.
    • Use new cylinder head bolts.
  1. Follow the removal procedure in reverse order.
  1. Tighten the bolts in sequence, in three stages, to 70 Nm (51 lb/ft).
    • Stage 1: Tighten all bolts to 70 Nm.
    • Stage 2: Retighten all bolts to 70 Nm.
    • Stage 3: Tighten all bolts an additional 90-100 degrees.
  2. Install generator bracket. Install bolts in four stages.
    • Stage 1: Hand-start bolt 1.
    • Stage 2: Install and tighten bolt 2.
    • Stage 3: Install and tighten bolt 3.
    • Stage 4: Tighten bolt 1.
  3. Install the A/C compressor mounting bracket. Install the bolts and the stud.
    • Tighten the M10 bolts and stud to 48 Nm (35 lb/ft).
    • Tighten the M8 bolt to 25 Nm (18 lb/ft).
Mar 10, 2010 | 1999 Ford Ranger SuperCab
Fixing heater core on Mercury Villager front one
go here for lots of help
http://groups.yahoo.com/group/villagerquest/
Heater Case Removal
  1. Drain the engine coolant. Refer to Section 03-03 for the procedure.
  2. Disconnect the battery ground cable (14301).
  3. Disconnect the heater water hoses (18472) from the heater core (18476) at the bulkhead.
  4. Remove the instrument panel lower center panel (04494). Refer to Section 01-12 for the removal procedure.
  5. Remove the glove compartment and LH instrument panel lower cover (044L97). Refer to Section 01-12 for the removal procedure.
  6. Remove the instrument panel ash receptacle (04810).
  7. Remove the two upper center instrument panel finish panel screws and the two lower center instrument panel finish panel screws.
  8. Remove the center instrument panel finish panel (044D70) and disconnect the cigar lighter socket and cigar lighter illumination lamp electrical connectors.
  9. Remove the four radio chassis bracket screws and pull the radio chassis (18806) and climate control assembly from the instrument panel (04320). Disconnect the radio chassis electrical connectors, the antenna lead, the three climate control electrical connectors and remove the radio chassis and climate control assembly.
  10. Remove the two heater outlet floor duct screws. Remove the heater outlet floor duct (18C433).
  11. Remove the four RH instrument panel lower reinforcement bolts and the RH instrument panel lower reinforcement (045F08), then the four LH instrument panel lower reinforcement and the LH instrument panel lower reinforcement.
  12. Remove the anti-lock brake control module (2B373). Refer to Section 06-09 for the removal procedure.
  13. If equipped, remove the speed control amplifier. Refer to Section 10-03 for the removal procedure.
  14. Remove the electronic door lock control processor (14B001). Refer to Section 01-14A for the removal procedure.
  15. Remove the passive restraint control module. Refer to Section 01-20B for the removal procedure.
  16. Remove the two center duct screws and remove the center duct (19D633).
  17. Remove the two ground wire bolts.
  18. Remove the three U-bracket-to-chassis nuts.
  19. Remove the four U-bracket bolts and remove the U-bracket.
  20. Remove the two RH and the two LH instrument panel bracket bolts and remove the instrument panel brackets (042C74).
  21. Remove the RH inner duct.
  22. Remove the LH inner duct.
  23. Remove the two accelerator pedal and shaft bolts and then the accelerator pedal and shaft (9725).
  24. Remove the accelerator pedal stop screw and then the accelerator pedal stop (9816).
  25. Remove the heater outlet duct screw and remove the heater outlet duct.
  26. Remove the temperature blend/panel bypass door actuator motor. Refer to the procedure in this section.
  27. Remove the panel/floor/defrost door actuator motor. Refer to the procedure in this section.
  28. Remove the three A/C evaporator register duct screws and remove the A/C evaporator register duct.
  29. NOTE: The A/C evaporator/blower motor assembly does not have to be removed in order to remove the heater assembly.
    Remove the four A/C evaporator/blower motor assembly screws to aid in the removal of the heater assembly.
  30. Remove the four heater assembly screws.
  31. Remove the heater assembly.
Sep 30, 2009 | 1996 Mercury Villager
Where exactly is the blower motor resistor for a 1997 E36 BMW located? The car has climate control. Is there a website or a place with photos specific to this vehicle??
Hi, hope the folowwing will help i found on internet if not email me at globalsat1@gmail.com. My service manual say its in the upper leftside of the heaterbox. remove lower left dash trim panel (drivers) and pull out resistor pack.
Fixing BMW E36 Blower Fan Speed . . . DIY!
It has been two weeks since my blower fan stopped working correctly on the low speed options (1, 2 and 3 ). It only works on high speed (Option 4). At first, I thought that the problem was in the fan speed switch because I’ve seen this problem before and when I told my electrician about it, he disassembled the switch and tried to clean it. Of course this solution didn’t work. So, I’ve decided to dig for the solution myself and I found that this is a pretty common problem among E36 cars. The problem is that speed 1, 2 and 3 are controlled by something called (Final Stage Unit on digital climate control units, Blower Resistor Pack on analog climate control units). The 4th speed is actually uncontrolled, so, it simply bypasses the final stage or resistor pack units. That explains why the fan works on the 4th speed and not the other lower speed options. Anyway, I tried to find a DIY (Do It Yourself) procedure on how to fix this problem and I found one that was written by "Deem3" on bimmerforums (thank you Deem3 for the great write-up). Now take a look below. It’s a really simple procedure. I will be trying it this weekend to see how it goes. I will post more details about this job soon. Symptoms (2 cases):
- Digital Climate Control: All the lights on your digital climate control are working and the buttons respond but the blower doesn’t blow any air.
- Analog Climate Control: The blower doesn’t work except on the highest speed (4th position).To replace it, we need to take off the driver’s side knee bolster. This only requires you to remove two screws,one on the right side of the bolster and one on the left. Using the phillips screwdriver remove the following screws. Now remove the speaker and footwell light. Using the 10mm socket remove the 3 bolts holding the metal shield. And using the phillips screwdriver remove the obd2 port. Now you should be able to see the footwell air duct. Remove it by pulling it.
With everything out of the way you should now be able to see the defective final stage unit. Remove it using the torx-20 screw driver. Replace it with the new part and before you put everything back turn on your car and test the blower. If everything is ok proceed to put everything back, and enjoy the benefits of having a blower in your car again.
Aug 06, 2009 | BMW 328 Cars & Trucks
Water dispenser doesnt work, ice dispenser works fine
1) remove the tubing connector behind refrig kickplate . Press for water . If no water comes from tube under refrig , then possibly frozen tank but probably not . Probably bad water inlet valve . ( tank is in the lower potrion of the refrig section behind the crispers ) .
2) if water does shoot out , then your freezer door is frozen which requires leaving door open and tapeing light switch closed and tape plastic around freezer section opening so fridge will continue to operate normally . Thawing freezer door could take a day or 2 . 3) You can plug the hoses back togather and walk by occasionally pressing water untill comes out . Lower your freezer temperature setting also ( could be set for too cold)
Jul 19, 2009 | GE GSH25JSSS
Sachtler Speed Lock CF HD Tripod Logo
337 people viewed this question
Top Sachtler Photography Experts
Tom Chichester
Tony Parsons
Tony Parsons
Neha Kaur
Neha Kaur
Are you a Sachtler Photography Expert? Answer questions, earn points and help others
