Question about Nokia N73 Cellular Phone
Dead Phone I Upgraded to v4.0723.2.0.1. Something gone wrong. Now just phone light come on. No Screen nothing. Tried battrey out, start without SIM, Memory card. Windows does not see Phone on USB just 'device not recognised'. What can I do?
    President:
  • 1,017 Answers
The basic info is probably still there but you need to do a major reset. Its a dealer case.
When upgrading software on Mobs, be sure to:
HAVE A FULLY CHARGED BATTERY INSERTED;
PUT IT ON GENERAL PROFILE;
TURN OFF YOUR PIN NUMBER;
CONNECT YOUR CHARGER TO YOUR MOB AND SWITCH IT ON;
DO NOT-----DO NOT---- TOUCH YOUR PHONE WHILE THE UPGRADE IS GOING ON;
THIS CAN TAKE 30 MINUTES OR MORE.
And obviously don't unplug the phone from the PC.
Be patient, you may have to do a restart or two on your mob afterwards. Even remove the battery to get it going again. But give it plenty of time.
I did an upgrade on a Sony Eric 810i it took nearly two hours.
Posted on Dec 26, 2007
Hello....my phone BLU Life play is completely dead now. The day before thanksgiving my phone was working perfectly find then of course. My battery. Was at 20% so I tried charging it and I notice that it...
Try using someone else's battery in your phone and/or your battery in their phone and try charging it and turning them on. If your phone turns on now, then its something wrong w/ the battery, if not... then its something wrong with your phone. Is there any possibility that it got wet? If so, take the battery out immediately (although its probably way too late after all the attempted charging), pour some rice into a small tupperware or other sealable container, snug your phone into the rice, then bury it completely in more rice and seal the container and LEAVE IT ALONE for at least a couple days. After u take it out and plug it in... go do something away from the phone for a bit... cuz it sometimes will take a while of looking like nothing is happening. I don't know what the notification light is like on that phone. But on mine, after probably 20 minutes of nothing while charging... the charging light started to flash (indicating that it is charging, but not yet ready to be turned on), once the light was solid on, turned the phone on no problem.
Nov 30, 2013 | Cell Phones
Kyocera Rise Problem
Sounds like your digitizer has gone dead in the button area. Since the buttons are actually just locations on the actual digitizer you will have to replace the digitizer. You could also do a factory reset (You WILL LOSE ALL USER DATA so do a backup with something like TitaniumBackup first) if after the factory reset the buttons still don't work then it is the Digitizer
Jun 22, 2013 | Cell Phones
My blackberry mobile phone cannot swith on ; the screen cannot come on
To answer all 3 of your questions. There's a chance your phone is dead. Could be a fried battery, could be a totally dead phone. If you've tried charging it and that didn't help. It's dead.
If you get a lightning bolt on the screen while charging. The battery is fried and needs a new one. If you plug it in and get nothing, no lights, just a tethered brick. The phone is dead.
Sep 07, 2011 | AT&T BlackBerry Curve 8310 Cell Phone -...
I have a Nokia E71 phone and my kid dropped it in to water tub and then we removed battrey in it immediatly and then wiped with a cloth and did put infront of fan heater and then plugged in but still did...
This is not enough for a water damaged phone - take it to a phone repair shop and the water drops still can remain near the components of the motherboard.
Mar 04, 2011 | Nokia E71 Smartphone
Low Battery, Connected car charger, now is dead
May be the battery won't have charge, keep 1 or 2 hrs continues charges, and if it is not working then you have to replace the battery set full.
Jul 04, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
Phone has gone dead.
If you JUST got that phone, you should probably take it back and have it replaced as something is defective inside the phone. There is nothing you can do personally to track down the defective part or replace it.
Jun 23, 2009 | Nokia 6085 Cellular Phone
Help!
key off and out,diconnect negitive side of battrey then postive.clean terimals,charge battrey,connect postive cable (with key off)connect negitive.and start.
your dead battrey is taking up a big load on system,so when you boost it the dead battrey is taking it all the starter is geeting vey little.thats the clicking.
if you dont have a charger dicconect both terminals the same way again,put the jumper cables on the dead battrey.let it charge battrey for 10 15 mins .the longer the better.remover jumpers.
with key off and out conected battrey terminals.connect jumper cables and start.
let me know if it start or not hopefully the key hasnt lost its coding.
Dec 04, 2008 | 2003 Volkswagen Golf
I took my memory card out of my 810i without first switching off now when i turn on the phone all it does is flash a white screen and nothing works i also have to take out the battery to switch off whats...
nothing just reformat the card in the phone itself, the card has got a different filesystem than the phone recognises,
start the entire process from scratch cormat the card in the phone before that backup all ur data on the pc. that should fix the same.
otherwise after removing the card reset the phone to factory settings security code is 12345 0r 0000 that should do the trick again here first backup.
Apr 10, 2008 | Nokia 6288 Cellular Phone
New battery....
that happened to me and i had to get a new ds , try calling nintendo go to nintendo.com 4 the phone number try google it or just get a new ds or battrey
Jan 12, 2008 | Nintendo DS Lite Console
Nokia N73 Cellular Phone Logo
63 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
