just bought a 300 pipe threader from a seller who did not specify that the unit was 120 rpm. He...
(More)
just bought a 300 pipe threader from a seller who did not specify that the unit was 120 rpm. He sent it with the standard threading assembly and all of the rest of equipment for threading pipe. Is there a way to convert this unit to 38 rpm so that I can use this machine for threading pipe? When would a person need a 120 rpm machine? I have been in the plumbing trade 15 years and never heard of this.
i want to wire a 3 phase planer up. I have three phase at the panel. How do I size the wire and what...
(More)
i want to wire a 3 phase planer up. I have three phase at the panel. How do I size the wire and what is the typical wiring scheme/
I can`t undo the collet to change bits.When you hold in the thumb button on the handpiece it is not...
(More)
I can`t undo the collet to change bits.When you hold in the thumb button on the handpiece it is not locking down ,so that the collet is not coming free of the shaft.At each rotation using the key you can feel the thumb button on the handpiece being forced up against you and not locking into place.
I have a BD fire Storm 14.4 battery and when I put it into the charger it will not charge the red...
(More)
I have a BD fire Storm 14.4 battery and when I put it into the charger it will not charge the red light on charger will not lite. does this mean that the battery is bad. Or the charger?
