Question about Rancilio (RAROCKYND) Grinder
Rocky grind settings
I just got a rocky second hand with my new silvia. The grinder is great but im not noticing any difference between any of the settings. Went to make some course for presspot and it looked the same as the grind setting for the espresso. Also the little button on top seems loose, could that be the problem? Is it possible to fix this myself?
  • 25 Answers
The little button on the top locks the grind to the set position. If it is falling down and not engaging the collar, the collar will turn and rest the grind to a very fine setting. If this is happening, you have to clear the hole that it sits in. Easier said than done, but not too difficult.
First, remove the bean hopper. Then carefully unscrew the collar all the way out. You will see the grinding burrs here. This is where you can change them if needed - not our problem now. Lift out the button out, and there should be a spring too. The hole frequently gets packed with coffee grounds. You can use a drill bit - by hand - or a philips screwdriver (takes longer) to take the grounds out of the hole. Replace spring and button, working it up and down to ensure proper movement. Clean the threads of the collar with a brush and carefully screw back together. This step is important! You could ruin the grinder if the collar is not straight!
When you get it screwed in most of the way, start the grinder. Slowly screw it in until you hear a "zing" when the burrs touch. Stop and back off another 1/4 turn. This should be the espresso setting and the button should come up and lock the collar in place.
Posted on Jan 25, 2008
Our Silvia, almost 8 years old, is putting out shots too fast (10 to 15 seconds), even though we've been dialing down the grind on Rocky more fine, putting more coffee in, and tamping harder. We...
Try to redo what you have been doing, but set it to the extremes to see if everything is functioning. If you set the grind say to 4, it should come out very slow or maybe not at all.
Jul 11, 2011 | Rancilio Silvia Espresso Machine
Coffee exits portafilter too quickly. Rocky grinder with burrs set as close as possible. Grinders and rubber recently replaced.
Sounds like your group handle needs a new basket (the piece with all the small holes in it). Presuming that grind is set correctly and that coffee is being tamped enough? Sometimes as the basket gets older, the holes can get larger and coffee doesn't have enough time to infuse with the coffee before exiting.
Mar 30, 2011 | Rancilio Silvia Espresso Machine
In the past I have cleaned the grinder blades 4 times however this time I noticed some of the grind mixture winds up on the counter under the main motor of the unit. When I picked up the grinder and shook...
Have you tried to hoover up the grinds from time to time, from the grinder blades. The coffee beans and ground can gather under the blades from over time. It should not be a problem though.
For better crema you may want to replace the blades.You should replace every 3-6 years. Rancilio Rocky Grinder Flat blades
May 07, 2017 | Rancilio Rocky Doser Espresso Grinder...
Have Rancilio Rocky for about 3 months. Noticed grinds around base from time to time. Yesterday picked up machine, saw accumulation. Tapped base, more came out. Took off base, about 2 oz. of grinds inside....
Hi There could be a piece broken around the chute where it comes out of the grinder and enters the grounds chamber. There is a rectangular opening in the plastic that can get broken causing the grounds to enter the machine.
Feb 07, 2010 | Rancilio Rocky Doser Espresso Grinder...
Silvia pressure issue
The Silvia comes equipped with a "pressurestat" that may have gone out of adjustment. Do a google search on that and you will find numerous pictoral guides on how to do this. The owner's manual that came with the machine (they have electronic versions at espressotec.com, among other places) will also give you basic instructions. Good luck!
Aug 22, 2009 | Rancilio Silvia Espresso Machine
Rancilio rocky grinder setting
to get starting point you adjust burrs to touch each other. when they touch each other you have finest grinding, after you hear metal voice you turn back 3 dots and grind only for 1 dose. you check it, if it goes to slow, you go one more back and clean gruinder, THAN you grind 1 dose more. 2 or 3 times and you will get perfect grinding.
Mar 28, 2009 | Rancilio Rocky Espresso Coffee Grinder -...
I just got a used Rocky grinder. It works great but I read about
the grinding itself makes noise. if you have noise in empty spinning than you should consider changing bearings( 2 of them) in the motor.
during opening grinder pay attention to lower holder of burr which spins together with axis, try to be gentle with that part.
Jan 31, 2009 | Rancilio Rocky Espresso Coffee Grinder -...
Adjusting grind on Rancilio Rocky
  1. because it didn't work a wilde the upper burr holder could be jammed, carefully take id off, clean it good and then put it back until you touch lower burr with the upper.
  2. to get starting point you adjust burrs to touch each other. when they touch each other you have finest grinding, after you hear metal voice you turn back 3 dots and grind only for 1 dose. you check it, if it goes to slow, you go one more back and clean grinder, THAN you grind 1 dose more. 2 or 3 times and you will get perfect grinding.
Dec 09, 2008 | Rancilio Rocky Espresso Coffee Grinder -...
Rocky Calibration
  1. replacement of burrs after 500 kg grinded coffe
  2. if upper burr holder and the body of grinder does not hold stabile, teflon aplying does not help too much, it is only temporary solution. new upper bur holder would do better.
  3. before inserting upper burr holder you should check if lower burr is rotating syncronized, you should take a bit chalk and sof touch while burr rotates. after that you stop grinder and look do you have circle with same thiknes, that would give you idea where is the problem, if it is in lower burr.
Apr 07, 2008 | Rancilio (RAROCKYND) Grinder
Rancilio (RAROCKYND) Grinder Logo
229 people viewed this question
Top Rancilio Coffee Makers & Espresso Machines Experts
Marvin
Marvin
vilhj
Level 1 Expert
Craig Butler
Craig Butler
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
